Posted: Thu Oct 18, 2018 10:48 am Post subject: New Z-figure |
| Quote: | | Quote: | The proposed new z-figure will offer all the advantages
of Z-12 (originally designed for TC aircraft) and
Z-13 combined. |
What's the timeframe on this being published?
--Rick |
I've been stirring that pot for several weeks and
I think I'm getting close. Here's revision 3
to the drawing . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z02P3_Preliminary.pdf
Critical review most welcome . . .
markwheelermd(at)icloud.c Guest
Posted: Thu Oct 18, 2018 11:46 am Post subject: New Z-figure |
Bob,Is it possible to obtain a software version of your electric symbols if we want to spin our own variant of your z-diagrams?
Mark
On Oct 18, 2018, at 11:47 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | | Quote: | | Quote: | The proposed new z-figure will offer all the advantages
Z-13 combined. |
--Rick |
Posted: Thu Oct 18, 2018 12:32 pm Post subject: New Z-figure |
At 02:46 PM 10/18/2018, you wrote:
| Quote: | Bob,
Mark |
https://tinyurl.com/og7ztjl
Posted: Thu Oct 18, 2018 1:22 pm Post subject: New Z-figure |
Thank you!! | Quote: | On Oct 18, 2018, at 1:31 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
At 02:46 PM 10/18/2018, you wrote: | Quote: | | Bob, Is it possible to obtain a software version of your electric symbols if we want to spin our own variant of your z-diagrams? Mark | https://tinyurl.com/og7ztjl
ceengland7(at)gmail.com Guest
Posted: Thu Oct 18, 2018 6:32 pm Post subject: New Z-figure |
Z-13 combined. |
--Rick |
Bob . . . | Assuming this the one for electronic injection electrically dependent engines, is there any merit in a separate bus for the engine? I'm trying to do this in my auto-conversion powered RV-7. My desire and logic (or what I hope is logic ) is that the airframe can go dark and the engine will still run, with an alternator charging the battery. I'm trying to mimic what you see in a 'typical' airframe with a magneto ignition a/c engine, where the master can be flipped off and the engine still runs.
I have a high current 'engine master' switch that directly connects the battery to the engine bus, and a conventional looking master contactor that feeds the 'aircraft bus'. Only the starter is fed by the master contactor; all other engine functions are fed by the engine master switch. One alternator conventionally feeds the load side of the master contactor; the other (identical model) alternator feeds through its alternator contactor to the battery side of the master contactor. There is a high current crossfeed switch between the two buses, to cover the possibility of 'engine master' switch failure.
Am I overthinking it?
Posted: Thu Oct 18, 2018 8:00 pm Post subject: New Z-figure |
| Quote: | I have a high current 'engine master' switch that directly connects the battery to the engine bus, and a conventional looking master contactor that feeds the 'aircraft bus'. Only the starter is fed by the master contactor; all other engine functions are fed by the engine master switch. One alternator conventionally feeds the load side of the master contactor; the other (identical model) alternator feeds through its alternator contactor to the battery side of the master contactor. There is a high current crossfeed switch between the two buses, to cover the possibility of 'engine master' switch failure.
If it were my airplane, I'd run engine critical loads
directly from the battery bus with each of those loads
enjoying it's own feeder protection and switch. This
keeps the engine running with all other switches off.
No relays or contactors in series with the feeders. The
Z02 battery bus enjoys THREE energy sources with minimal
sharing of hardware. All three sources are pre-flight
testable.`
Av8rrob
Posted: Fri Oct 19, 2018 3:42 am Post subject: Re: New Z-figure |
Bob, is is possible to change the switch configuration from off/bat/ bat+ pri alt , to off/batt/ batt +alt; then change the second switch to selecting either primary or secondary alternator? It would seem to be a bit easier operationaly that way. What do you think?
Rob
Posted: Fri Oct 19, 2018 4:28 am Post subject: New Z-figure |
At 06:42 AM 10/19/2018, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Av8rrob" <av8rrob(at)gmail.com>
Bob, is is possible to change the switch configuration from off/bat/ bat+ pri alt , to off/batt/ batt +alt; then change the second switch to selecting either primary or secondary alternator? It would seem to be a bit easier operationaly that way. What do you think? |
That 'mixes' controls between two systems which,
by legacy design goals, should be as independent
from each other as possible.
Posted: Fri Oct 19, 2018 4:29 am Post subject: New Z-figure |
At 10:59 PM 10/18/2018, you wrote:
| Quote: | | Quote: | I have a high current 'engine master' switch that directly connects the battery to the engine bus, and a conventional looking master contactor that feeds the 'aircraft bus'. Only the starter is fed by the master contactor; all other engine functions are fed by the engine master switch. One alternator conventionally feeds the load side of the master contactor; the other (identical model) alternator feeds through its alternator contactor to the battery side of the master contactor. There is a high current crossfeed switch between the two buses, to cover the possibility of 'engine master' switch failure.
testable.` |
Can you describe the engine's electrical
feeders?
Does the system have any redundant features
like pri/sec ECU, dual fuel pumps, etc?
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Fri Oct 19, 2018 5:07 am Post subject: New Z-figure |
I have always wondered why the feed to the main alternator field
breaker are different sizes on each side of the breaker. This is
unchanged from earlier versions.
I assume the Ebus brown out booster is significantly cheaper than the
TCW Intelligent Power Stabilizer ?
I don't know what the internal failure modes are, but their wiring
diagram shows it directly wired in at all times, rather than being
switched out with a relay.
The think the biggest advantage of the IPS is that it boosts the
voltage as the battery sags after an alternator failure, which doesn't
apply to this architecture, but it does supply a boost during starting.
Jeff Page
Dream Aircraft Tundra #10
| Quote: | Time: 11:48:16 AM PST US
Subject: New Z-figure
>> Z-13 combined.
> --Rick
Posted: Fri Oct 19, 2018 5:38 am Post subject: New Z-figure |
On Fri, Oct 19, 2018 at 7:33 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
testable.` |
feeders?
| Please forgive the rough looking drawing; I've never had time to learn a cad program, so I tweaked a z drawing with MS Paint to create the attached. Ignore the fused feeder values on the engine bus; most are artifacts from my cut & paste operation. Both alternators in the drawing are auto-style internally regulated; the engine comes with an IR alternator, and I just hung a 2nd where the air conditioner compressor used to reside. As yet unresolved in this draft is the fact that both OV modules can 'see' both alternators. My original intent was to run both alternators all the time, but I may modify that idea to primary/backup.
My controller (from Real World Solutions, specifically for Mazda rotary engines) does have primary/secondary controllers in one box, but a single power feed to the controllers. The RWS controllers have been set up this way for over 20 years. Over the years, multiple fliers have had controller issues requiring switching to the backup controller, but none have ever had a power supply failure to the box caused by an issue with one controller. If the controller box had separate power feeds to each controller, it would obviously beg for running one from the a/c bus, but I'm not sure that would be a good thing, from the standpoint of trying to keep the systems similar (as possible) to old habit driven pilots. The controllers' control of the injectors & ignition coils is switched by an external control, which drives a bank of internal relays to do the switching (I believe this is how the ones for a/c engines do it, as well). Power to each injector & coil is individually fused; the controller switches the ground side of the injectors/coils. There are dual Walbro high pressure fuel pumps, each with it's own fuse/switch.
The choice to have an engine master was driven by the same logic mentioned earlier. Just as the airframe can go dark without affecting the engine, a typical a/c can shut off the engine by turning a key or flipping a pair of mag switches. The engine master switch is my 'mag switch'. But I'm not married to this, is there good reason to change?
If the above isn't clear, I can try to do a rough drawing of power flow to the engine's power feeders.
141.24 KB |
17554 Time(s) |
Posted: Fri Oct 19, 2018 5:48 am Post subject: New Z-figure |
At 08:06 AM 10/19/2018, you wrote:
| Quote: | --> AeroElectric-List message posted by: Jeff Page <jpx(at)qenesis.com>
unchanged from earlier versions. |
Because the hot side is a bus extension with recommended
protection. 20AWG fuselinkwire is readily available now
so a 20GFLW followed by a 16AWG extension is called for
up to the breaker. After that, it's just alternator field
loads.
| Quote: | I assume the Ebus brown out booster is significantly cheaper than the
TCW Intelligent Power Stabilizer |
Yes . . . $10 vs. $hundreds$
| Quote: | I don't know what the internal failure modes are, but their wiring
switched out with a relay. |
? It's expected to funtion and powered only while
the starter button is depressed. Given that it functions
ONLY during cranking, then there are no significant
failure modes. It gets pre-flight tested but is not
needed in flight. If it craps, there are no safety
implications to the rest of the ship's electro-whizzies
or comfortable termination of flight.
| Quote: | The think the biggest advantage of the IPS is that it boosts the
apply to this architecture, but it does supply a boost during starting. |
Yes . . . and why do you want to boost the voltage with
a dead alternator? Recall that the brown-out issue is
based on battery voltage sagging BELOW a brown-out threshold
of the electro-whizzy during starter inrush. Except while
cranking, the battery is expected to supply the legacy
adopted and understood supply voltage of 10-12 volts.
By the time a battery drops to 10.5 or thereabouts, it's
95% used up. All electro-whizzies qualified for aircraft
operate quite happily down to 10.5 and usually below . . .
so boosting bus voltage during alternator out conditions
only adds complexity and increased energy consumption.
When the brown-out issue first reared its ugly head
about 10 years ago, the energy budget for preventing
brown-out reset was small. The resourceful Eric Jones
crafted an array of super-caps that would grunt loads
to the victimized devices for the few milliseconds that
the battery was suffering starter-sag.
But it seems that more and more devices are being
offered to the OBAM aviation community that suffer
the same short coming. So assuming the builder objects
to brown-out resets. then its left to us to craft
a band-aid to accomplish a design goal that should
have been built into the electro-whizzy in the first
place. The capacitor array is less practical and
more expensive than the architecture proposed in
Z02. MUCH less expensive than the TCW approach.
Posted: Fri Oct 19, 2018 5:51 am Post subject: New Z-figure |
Jeff, that 'after alternator failure' voltage boost might buy you a few seconds (as in less than 10) longer operation beyond typical low voltage shutdown. When the energy is depleted from the battery, it's gone. Using a 'switcher' on a virtually dead battery when it's down to 9 or 10 volts will just drive it down to low single digit volts almost instantly.
On Fri, Oct 19, 2018 at 8:13 AM Jeff Page <jpx(at)qenesis.com (jpx(at)qenesis.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Jeff Page <jpx(at)qenesis.com (jpx(at)qenesis.com)>
Jeff Page
> From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
>>> Z-13 combined.
>> --Rick
> Bob . . .
Posted: Fri Oct 19, 2018 7:19 am Post subject: Re: New Z-figure |
Charlie,
I suggest that the bus tie-switch be replaced by a DPDT switch.
Connect the N.C. second half of the switch in series with the start push
button. Doing that will disable the starter if the bus-tie switch is turned on.
The purpose is to prevent starter current from taking a parallel path from
the battery to the engine bus to the main bus to the starter.
_________________ Joe Gores
Posted: Fri Oct 19, 2018 7:35 am Post subject: Re: New Z-figure |
Jeff, the brownout booster (DC-DC converter) is only energized while the relay
is energized (except for milliseconds through diode). The relay is only
energized while the start button is pressed (except for milliseconds dropout delay).
_________________ Joe Gores |
Posted: Fri Oct 19, 2018 8:40 am Post subject: New Z-figure |
On 10/19/2018 10:19 AM, user9253 wrote:
Charlie,
I suggest that the bus tie-switch be replaced by a DPDT switch. Connect the N.C. second half of the switch in series with the start push button. Doing that will disable the starter if the bus-tie switch is turned on. The purpose is to prevent starter current from taking a parallel path from the battery to the engine bus to the main bus to the starter.
Joe Gores
Hi Joe,
Good idea. I think we may have discussed that issue in the past; I just
haven't revised the rough draft. The -7 project has been stagnant for
several months while I dealt with family illnesses and built a hangar door.
