Weak Air Compressor?
twvandusen
PostPosted: Mon Sep 10, 2018 5:58 pm    Post subject: Weak Air Compressor? Reply with quote
After 14 months of working the problem, my Nanchang finally received it's U.S. Airworthiness Certificate. We fixed several air leaks in a recent annual inspection but during a recent runup I couldn't achieve the required 30 ATMs for takeoff. The system still leaks some but it may also be a weak air compressor. Is there a way to test the compressor? What are the limits? Thanks everyone!
draftsjust417(at)gmail.co
PostPosted: Mon Sep 10, 2018 6:12 pm    Post subject: Weak Air Compressor? Reply with quote
As an aside, I noticed a similar problem in my CJ6, and discovered 1 of my old landing gear hoses has a small longitudinal rupture that hissed out air beyond what the compressor could make up for.Readily checked and easily fixed, just an idea.
Congrats on certification!
Justin Drafts
N280NC
On Tue, Sep 11, 2018 at 6:28 AM, twvandusen <twvandusen(at)gmail.com (twvandusen(at)gmail.com)> wrote:
--> Yak-List message posted by: "twvandusen" <twvandusen(at)gmail.com (twvandusen(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=483084#483084
glipaz
PostPosted: Mon Sep 10, 2018 11:08 pm    Post subject: Re: Weak Air Compressor? Reply with quote
Were you making over 30atm before? If not then maybe your pressure relief pop off valve needs adjusting and is set too low. If you were making over 30atm before and are not now then you are likely leaking air in the hard line from the compressor to the snot bottle or the snot bottle itself is leaking air. The banjo fitting on the compressor can leak. Try tightening it or replace the crush washers on it and tighten. If not then the flares on the hard line coming from the compressor might have a small crack and will leak. If not, then test the fittings on the snot bottle and make sure the valve on the snot bottle is not leaking. If it is the valve then disassemble and clean it or replace it with a swagelock SS valve as has been described here before.
dsavarese0812(at)bellsout
PostPosted: Tue Sep 11, 2018 5:47 am    Post subject: Weak Air Compressor? Reply with quote
Did you attempt to adjust the pressure relief valve on the firewall (Pop Off Valve) break-over pressure? It is adjustable. A "rule of thumb" adjustment is 5 ATM's for each 1/2 turn. Adjust to 50-55 ATM's.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, September 10, 2018 10:02 PM
Subject: Yak-List: Weak Air Compressor?
http:p;   -Matt Dralle, List Admin.
Clouddog
PostPosted: Tue Sep 11, 2018 6:56 am    Post subject: Weak Air Compressor? Reply with quote
Another area to look at is the banjo fitting on the compressor. It has a valve that can carbon up. Suggest you take off the banjo fitting and check and clean the valve. Also when I did mine, I didn't get the crush washer tight enough and had a small leak at the banjo fitting when I reinstalled it. I tightened up the fitting and Wa-la..... air!
Greg Wrobel
On Mon, Sep 10, 2018, 21:04 twvandusen <twvandusen(at)gmail.com (twvandusen(at)gmail.com)> wrote:
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
PostPosted: Tue Sep 11, 2018 7:11 am    Post subject: Weak Air Compressor? Reply with quote
Another thing that is easy to do and can make a huge difference on how fast the air tank will charge is to remove the "snot" bottle from the firewall and flush it out completely either with avgas or mineral spirits. Fill the snot bottle with flushing liquid and shake well. Flush all three orifices; input, output and drain.  Once you see the flushing liquid run clear out of all 3, dry it out with shop pressure and reinstall. You'll be amazed how much faster your air bottle (or bottles if you have a CJ) will charge.
Dennis
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Tuesday, September 11, 2018 9:51 AM
Subject: Re: Weak Air Compressor?
Dennis
Subject: Weak Air Compressor?
PostPosted: Tue Sep 11, 2018 7:13 am    Post subject: Weak Air Compressor? Reply with quote
Excellent point Greg. Especially about the crush washers.
Dennis
Sent: Tuesday, September 11, 2018 11:00 AM
Greg Wrobel
dougsappllc(at)gmail.com
PostPosted: Tue Sep 11, 2018 8:02 am    Post subject: Weak Air Compressor? Reply with quote
Weak compressor:1. Check poppet valve and seat for carbon build up
2. Change out the poppet valve spring for a new one.
3. DO NOT try to reuse the banjo crush washers, order up a set of new.
4. Make 100% sure that your snot valve is fully closed (50% of the time this is the problem)
5. Pressurize the line from snot valve to compressor banjo and check for cracks or leaks
6. Don't think your doing it a favor by squirting WD-40 or MMM into the filter, your not.  It will just carbon up the poppet valve.
7. Give me a call and I'll loan you my KY2 compressor test kit.
Good luck,
Doug
On Tue, Sep 11, 2018 at 7:56 AM, Greg Wrobel <clouddog22(at)gmail.com (clouddog22(at)gmail.com)> wrote:
Greg Wrobel
mark.bitterlich(at)navy.m
PostPosted: Tue Sep 11, 2018 1:46 pm    Post subject: Weak Air Compressor? Reply with quote
Something that you will use more than once is a hose/line/fittings that allow you to disconnect the line at the compressor and convert to standard AN fitting. Then use any kind of compressed air, or nitrogen (never oxygen) and pump it up to 700 psi and listen for leaks. You'll find them. If you have none, suspect compressor or check valve in the banjo fitting.
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of A. Dennis Savarese [dsavarese0812(at)bellsouth.net]
Sent: Tuesday, September 11, 2018 9:47 AM
Subject: [Non-DoD Source] Re: Weak Air Compressor?
Dennis
k7wx
PostPosted: Tue Sep 11, 2018 9:51 pm    Post subject: Weak Air Compressor? Reply with quote
Another way to find leaks is to use a hand held ultrasonic leak detector. We have four CJs in one hangar and this piece of equipment is shared by everyone. It’s capable of uncovering even the smallest leak. And a large leak sounds like a hurricane. Here's an image of what we use. Worth every penny when a pneumatic system starts acting up and the cause is not obvious. These are available on Amazon.
Warren Hill
N464TW
Mesa, AZ
[img]cid:C95F8384-4E23-4107-B001-7D378A63B489[/img]
On Sep 11, 2018, at 7:56 AM, Greg Wrobel <clouddog22(at)gmail.com (clouddog22(at)gmail.com)> wrote:
Greg Wrobel
--> Yak-List message posted by: "twvandusen" <twvandusen(at)gmail.com (twvandusen(at)gmail.com)> After 14 months of working the problem, my Nanchang finally received it's U.S. Airworthiness Certificate. We fixed several air leaks in a recent annual inspection but during a recent runup I couldn't achieve the required 30 ATMs for takeoff. The system still leaks some but it may also be a weak air compressor. Is there a way to test the compressor? What are the limits? Thanks everyone! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483084#483084 =========== List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - eferrer noreferrer" target="_blank">http://forums.matronics.com =========== WIKI - errer noreferrer" target="_blank">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution ===========
 Filesize:  316.15 KB
 Viewed:  12235 Time(s)
k7wx
PostPosted: Wed Sep 12, 2018 7:13 am    Post subject: Weak Air Compressor? Reply with quote
Another way to find leaks is to use a hand held ultrasonic leak detector. We have four CJs in one hangar and this equipment is shared by everyone. It’s capable of uncovering even the smallest leak. Worth every penny when the pneumatic system is acting up and the cause is not obvious. There are several different models available on Amazon.
Warren Hill
N464TW
Mesa, AZ
Greg Wrobel
twvandusen
PostPosted: Wed Sep 12, 2018 9:45 am    Post subject: Re: Weak Air Compressor? Reply with quote
Thanks everyone for taking the time to help me out. I'll be home later in the week and will be able to apply some of these ideas to my Nanchang. I'll keep you all informed of the results.
