AeroElectric-List Digest: 24 Msgs - 08/23/18
bobbypaulk(at)comcast.net
PostPosted: Fri Aug 24, 2018 10:46 am    Post subject: AeroElectric-List Digest: 24 Msgs - 08/23/18 Reply with quote
Guys
The Jabiru engine uses a
Kubota RP201-53710 regulator.
I got rid of the Dynamo and regulator and installed a 40 amp. alternator.
The Dynamo will not charge while taxiing and if you have any load at all your battery could be down when you try to leave. The new Honda ignition coils are far better than the originals and will help with starting also.
Bobby
Jabiru 3300
302 hours
Zenith 601
