Voltage regulator wiring with fault indication.
schu(at)schu.net
PostPosted: Fri Jul 20, 2018 12:27 pm    Post subject: Voltage regulator wiring with fault indication. Reply with quote
On 7/20/18 12:08 PM, Robert L. Nuckolls, III wrote:
At 11:59 AM 7/20/2018, you wrote:
--> AeroElectric-List message posted by: Matthew Schumacher <schu(at)schu.net> (schu(at)schu.net)
I've been trying to figure out why Bob doesn't show the "I" terminal used in Z11.  Looking further it seems there are multiple ways to wire a ford regulator:
http://www.erareplicas.com/427man/wiring/alt.htm
So why not wire it the second way so that we have a alternator out indication?  Someone please tell me what I'm missing.
<snip>
It's MUCH simpler and universally accurate to
incorporate ACTIVE NOTIFICATION OF LOW VOLTAGE.
This feature's utility is unambiguous. The
light CANNOT go dark unless the altenrator is
working.
Thanks for the clarification. That helps a lot!
