Valves visual inspection
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
javiercarrascob
PostPosted: Wed Jul 18, 2018 6:58 am    Post subject: Valves visual inspection Reply with quote
Hello everyone,
It is annual inspection for my Yak-55, M-14P.
I have read a lot about the sticky valve issue, and asked the mechanics to check on them.
He said that he needs to remove the cylinder top covers, remove the spring and manually move them.
If the stick then he will remove the valve and clean the shaft.
Have any of you done the same procedure, agree/disagree or have any other suggestion to things to check for while he is at it?
Javier Carrasco
Yak-55 N5245H
Sent from Mail for Windows 10
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
