Endurance test
wdaniell.longport(at)gmai
PostPosted: Sat Jun 30, 2018 2:11 pm    Post subject: Endurance test Reply with quote
FWIW today I took flew 338nm starting with 27 gals and landed with 11.5.
2:50 flight time according to my dynon....
William Daniell
LONGPORT
+57 310 295 0744
rowlandcarson(at)gmail.co
PostPosted: Sun Jul 01, 2018 10:56 am    Post subject: Endurance test Reply with quote
On 2018-06-30, at 23:10, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
FWIW today I took flew 338nm starting with 27 gals and landed with 11.5. 2:50 flight time according to my dynon….
William - my worst personal Europa endurance test was right-seat in Tim Houlihan’s G-BZTH when I drank a bottle of water while hanging around waiting for his flight plan to mature - and then omitted to make a pre-takeoff rudder inspection. The flight was only 2 hours but it seemed a lot longer! I could not persuade Tim to deviate from his flight plan for a comfort stop.
Attached is a plot of a longer flight in the same aircraft which was MUCH more comfortable, thanks to better preflight actions. I can’t remember how much fuel was left at landing, but we were both comfortabe with it. 407.32 statute miles = 353.95 nautical miles, flight time 3:20.
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk| Skype, Twitter: rowland_carson Facebook: Rowland Carson
[img]cid:A7633EB1-9032-4E27-9417-9272D09FF351(at)home[/img]
 Filesize:  261.77 KB
 Viewed:  5776 Time(s)
PostPosted: Mon Jul 02, 2018 5:11 am    Post subject: Endurance test Reply with quote
So it was like a car trip when dad wont stop.
I have a peepee tube....i need coffee in the mornings with predictable results 45 mins later.   Its not an entirely "watertight" process so I plan to add adult diapers for the longer legs required to get me to miami.....
By the way id like see see designs for relief tubes....perhaps offline as this is a family show.
I have a 10 gal turtlepack bladder in cradle that is strapped to the tie bar.   The fuel is fed to the tank via a facet pump.   I made a push button operating switch per buds comments.     I transferred the fuel every 20 mins, you can feel the pump operating and  you can see the fuel rising up the cobra.   The pump feels different when sucking air and when the fuel in the bladder is expended....
Will
William Daniell
LONGPORT
+57 310 295 0744
On Sun, Jul 1, 2018, 13:59 Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> wrote:
in friendship
Rowland
 Filesize:  261.77 KB
 Viewed:  5753 Time(s)
creightonious
PostPosted: Tue Jul 03, 2018 4:13 am    Post subject: Endurance Test Reply with quote
The relief tube problem in the Europa is simplicity itself.
You will need a funnel of about 12-15cm diameter, 500mm of tubing which will fit over the funnel outlet and 2 zip ties. (The funnels with a flat side are best)
Drill a hole the outside diameter of the tube in the underseat storage. Install one zip tie a cm or 2 from the tube’s end and insert the tube into the hole. Install the second zip tie near the end of the tube outside (the zip ties keep the tube in place). The funnel stows under the seat, tubing around the front of the stick.
I’ve used this for 3 years on some of our 6+ hour legs.
Having an autopilot servo under the seat may complicate the installation slightly, but we’re experimenters and this should pose no problem.
Creighton A-009
On Jul 3, 2018, at 2:34 AM, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-07-02&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-07-02&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Mon 07/02/18: 3
Today's Message Index:
1. 02:13 AM - Czech Trip - possible spare seat (davidjoyce(at)doctors.org.uk)
2. 06:11 AM - Re: Endurance test (William Daniell)
3. 09:19 AM - Re: Jamar Brake Cylinder (willydewey)
________________________________ Message 1 _____________________________________
Time: 02:13:43 AM PST US
Subject: Czech Trip - possible spare seat
Just a reminder that the Czech trip is due to start on Sunday 15/7/18. I
have four plane signed up for this and there is a possibility that one
of these may be able to offer a spare seat. Anyone interested (in the
spare seat or the trip) come back to me soonest. Regards, David Joyce,
G-XSDJ
________________________________ Message 2 _____________________________________
Time: 06:11:37 AM PST US
From: William Daniell <wdaniell.longport(at)gmail.com>
Subject: Re: Endurance test
Will
William Daniell
LONGPORT
+57 310 295 0744
> On Sun, Jul 1, 2018, 13:59 Rowland Carson <rowlandcarson(at)gmail.com> wrote:
> On 2018-06-30, at 23:10, William Daniell <wdaniell.longport(at)gmail.com>
> Houlihan=99s G-BZTH when I drank a bottle of water while hanging ar
ound
a
a
> comfort stop.
> more comfortable, thanks to better preflight actions. I can=99t rem
ember how
> in friendship
> Rowland
________________________________ Message 3 _____________________________________
Time: 09:19:47 AM PST US
Subject: Re: Jamar Brake Cylinder
with compressed air from a large tire with the reservoir absolutely topped up It
was a one hit solution for me!!
would have been nicer if the reservoir was a tad larger
Give a wise man knowledge and he will be yet wiser
http://forums.matronics.com/viewtopic.php?p=481346#481346
Creighton Smith
A 036
PostPosted: Tue Jul 03, 2018 7:30 am    Post subject: Endurance Test Reply with quote
thanks
I imagine the suction from the airstream helps.....
William Daniell
LONGPORT
+57 310 295 0744
side are best)
