Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Fri Jun 08, 2018 12:15 pm Post subject: Fuel level indicator |
I have an external tube to check the fuel level (see pix). It's sometimes hard to see the fuel in the tube. I thought of adding a small ball float in the tube for visibility. I know J3's use a cork on the bottom of a wire for fuel level. Don't know if it is coated or sealed with anything? Any ideas from the group on what to use? Obviously must be compatible with fuel.
127.01 KB |
17907 Time(s) |
russk50(at)gmail.com Guest
Posted: Fri Jun 08, 2018 12:24 pm Post subject: Fuel level indicator |
Rex Rodebush - if you're really lucky you can find a bead from some sort of necklace that will be liquid-proof
end not dissolve in fuel — test it first!
| Quote: | On Jun 8, 2018, at 4:15 PM, Rex Rodebush <jrrodebush(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=480739#480739
http://forums.matronics.com//files/img_20180608_133656384_489.jpg
ceengland7(at)gmail.com Guest
Posted: Fri Jun 08, 2018 1:07 pm Post subject: Fuel level indicator |
On 6/8/2018 3:15 PM, Rex Rodebush wrote:
It's been done, so you wouldn't be the 1st. You do need to be sure it
can't hang up in the tube, block the fuel's movement in the tube, or
*escape the tube*. Depending on how the system is plumbed, you could
block the fuel vent, give yourself a false fuel level reading, or even
block fuel flow (if it escaped the tube).
Richard Pike
Posted: Fri Jun 08, 2018 1:20 pm Post subject: Re: Fuel level indicator |
This guy has an interesting idea - the pattern behind the tubing changes shape depending on whether there is fuel in front of it.
http://mybearhawkpatrol.com/finish/fuelsight.html
Or you could just go with this:
http://www.univair.com/piper/piper-pa-11/view-all/u10853-000-piper-fuel-gauge-float-ball/
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Rex Rodebush
Posted: Fri Jun 08, 2018 1:46 pm Post subject: Re: Fuel level indicator |
Richard, The Piper fuel ball looks perfect! I'll order one. Thanks!
Posted: Fri Jun 08, 2018 2:19 pm Post subject: Fuel level indicator |
Rex R/Kolbers:
Looks like you are using yellow Tygon type fuel line with a yellow
background.
My sight gauge is clear, for the most part, with Cub yellow fabric
background. Been working good for me since day one.
_________________ John Hauck
Titus, Alabama |
Posted: Fri Jun 08, 2018 2:21 pm Post subject: Fuel level indicator |
My sight gauge uses clear Tygon. Working fine since 1992.
Titus, Alabama |
Rex Rodebush
Posted: Fri Jun 08, 2018 4:23 pm Post subject: Re: Fuel level indicator |
John,
Wasn't aware that the tygon came in clear. The only one I could find was yellow from McMaster-Carr. I'll see if I can find the clear version. BTW, can't afford two balls, at my age one will be enough!
Rex Rodebush
Posted: Fri Jun 08, 2018 4:43 pm Post subject: Re: Fuel level indicator |
John,
The only Tygon that I can find that is recommended for gas is the yellow version. Do you change your gas gage line every few years or so? Do you know what type of Tygon you use?
Posted: Fri Jun 08, 2018 5:58 pm Post subject: Fuel level indicator |
The clear food grade should be fine. It is PVC.
john
Titus, Alabama |
Amazon is a wonderful thing. If you don't believe me, ask Larry Cottrell.
Do a Google search or go to this page to find all kinds and colors of Tygon:
https://www.amazon.com/Plastic-Tubing-Tygon/s?ie=UTF8&page=1&rh=n%3A16414401
%2Cp_4%3ATygon
Titus, Alabama |
Posted: Fri Jun 08, 2018 6:07 pm Post subject: Fuel level indicator |
Tygon (capitalized)
https://en.wikipedia.org/wiki/Tygon_tubing
%2Cp_4%3ATygon
byoungplumbing(at)gmail.c Guest
Posted: Sat Jun 09, 2018 1:05 pm Post subject: Fuel level indicator |
It's been so long I don't remember what I made the float out of. I don't think it was cork, maybe I carved it out of wood or found a plastic ball used a permanent marker to make it more visible. I do remember building a restriction that I fit inside the line that keep the float from sloshing out of the sight tube. Did this by cutting 2 sections of fuel tube 3/16 or so long pinched it and using a wire slid them down the sight tube to match the top and bottom of the fuel tank with the ball in-between. The fuel could get past the restriction to float the ball, and at the same time keep the ball out of the pumps and carbs where it could cause trouble.
Boyd Young
Mkiii utah
On Fri, Jun 8, 2018, 2:17 PM Rex Rodebush <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Rex Rodebush" <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)>
-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List
zeprep251(at)aol.com Guest
Posted: Sat Jun 09, 2018 1:45 pm Post subject: Fuel level indicator |
Russ, used to use shellac but modern fuel additives in car gas might affect it like they did the old sloshing compound.
| Quote: | On Jun 8, 2018, at 4:24 PM, Russ Kinne <russk50(at)gmail.com> wrote:
