ceengland7(at)gmail.com Guest
Posted: Thu Jun 07, 2018 6:22 pm Post subject: Placement options for CHT probe |
On 6/7/2018 8:35 PM, John Fitt wrote:
| Quote: | Greetings from Sebastopol, CA
Has anybody used a cylinder head bolt ( immediately next to a spark plug) instead of the probe ring
under the plug? I am currently using the cylinder head bolts, wanting to eliminate the wear and tear
on the probe ring when checking/changing plugs. Seems that the temp. readings are lower- maybe due to the heat lost near a fin?
FSII 503 dcdi
EIS monitor
CHT runs around 100-120 deg
John Fitt
| From the Lycoming world: Washer-based cht probes on the plugs always indicate significantly higher than probes screwed into the heads. The plug is the hottest spot in the cylinder.
rascaljohn
Posted: Thu Jun 07, 2018 8:23 pm Post subject: Placement options for CHT probe |
Thanks for the reply. Any way to save on the wear and tear?
On Jun 7, 2018, at 7:22 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
FSII 503 dcdi
EIS monitor
John Fitt
gdhelton(at)gmail.com Guest
Posted: Fri Jun 08, 2018 7:32 am Post subject: Placement options for CHT probe |
Your CHT seems very low. Do you have your EIS set for centigrade or Fahrenheit?The most common cause for the disfigurement of spark-plug base rings is over- torque of spark plugs. I was surprised to find out that my engine ( 40hp Hirth 2702 ) only requires 108 inch pounds ( yes, inch pounds) of torque and with the spark-plugs seal ring installed with no anti- sieze compound.
George H.
Mesick, Michigan
On Jun 8, 2018, at 12:23 AM, John Fitt <jpfitt(at)sbcglobal.net (jpfitt(at)sbcglobal.net)> wrote:
| Quote: | Thanks for the reply. Any way to save on the wear and tear?
FSII 503 dcdi
EIS monitor
John Fitt
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sat Jun 09, 2018 3:18 am Post subject: Re: Placement options for CHT probe |
Why don't you do a side-by-side test / comparison with the CHT probes in both locations on the same cylinder? A double throw switch temporarily wired in would give you an immediate comparison.
_________________ Jerry King |
