Starting the Engine Reboots the EFIS
Goto page 1, 2, 3  Next
art(at)zemon.name
PostPosted: Mon May 14, 2018 3:52 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Folks,
I am finally to the point on my project of starting the engine. When I first engage the starter, voltage drops so low that my EFIS reboots. The EFIS immediately reboots, less than 1 second later, but it takes several seconds for the engine instruments to come back online.
It is a 12 volt system. During engine start, the equipment is drawing about 5 amps (other than the starter motor). I need about 9 volts to keep the EFIS from rebooting.
I am using figure Z-12 with very minor modifications: replaced the ammeter shunts with hall effect sensors and rearranged the switches a bit. You can see my modified diagram here: engine.pdf
What would be the simplest way to fix this issue?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
cluros(at)gmail.com
PostPosted: Mon May 14, 2018 4:11 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Battery for the EFIS? Does MGL make a backup battery for your engine monitor?
On Mon, May 14, 2018 at 4:51 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
    -- Art Z.
art(at)zemon.name
PostPosted: Mon May 14, 2018 4:40 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Sebastien,
MGL sells the AvioGuard, a DC-to-DC converting power supply for isolating the avionics from the rest of the aircraft system. It supports a backup battery. Cost would be $450 + the battery.
I am hoping for a less expensive solution.
    -- Art Z.
On Mon, May 14, 2018 at 7:09 PM, Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
Folks,
brian.lester(at)gmail.com
PostPosted: Mon May 14, 2018 4:58 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
What about something like this?
http://www.tcwtech.com/ibbs_integrated_backup_battery_system_3ah_6ah.html
As long as the rest of your system meets your needs this will at least fix the voltage drop issue for the EFIS.
On Mon, May 14, 2018 at 8:45 PM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Sebastien,
    -- Art Z.
Folks,
ceengland7(at)gmail.com
PostPosted: Mon May 14, 2018 5:00 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Ebay for a 'boot/buck switching regulator' sized for your needs (likely way less than$30), and an aux battery sized the same way. Create a 'mini' bus for the items you want to isolate.
If all you want is brownout protection, a little 2 or 3 AH battery shoul be more than enough.
There are other commercial products available that do the same thing, but obviously you will pay more.
On May 14, 2018, at 7:45 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Sebastien,
-- Art Z.
Folks,
stuart(at)stuarthutchison
PostPosted: Mon May 14, 2018 5:29 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
I can’t help wondering if your primary battery is aged and below par Art, but I second the IBBS from TCW Tech.
Installed in parallel with a decent Schottky diode (bought mine from Eric at http://periheliondesign.com/) it’s a simple way to overcome voltage sag on the bus during start and provides alternate power (hardwired to essential items of your choosing) in an emergency.
Cheers, Stu
On 15 May 2018, at 10:56, Brian Lester <brian.lester(at)gmail.com (brian.lester(at)gmail.com)> wrote:
What about something like this? art(at)zemon.name (art(at)zemon.name)> wrote:
Sebastien,
-- Art Z.
Folks,
-- https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
art(at)zemon.name
PostPosted: Mon May 14, 2018 5:49 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Charlie,
That sounds like exactly what I need: brownout protection for one to two seconds. Is this the sort of regulator that I need? https://www.ebay.com/itm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-Converter-Const/152990560495
    -- Art Z.
On Mon, May 14, 2018 at 7:59 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Sebastien,
    -- Art Z.
Folks,
Bob McC
PostPosted: Mon May 14, 2018 6:08 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Read the specifications carefully as the following statement from their specs might be an issue.
"Please note: the negative of input and output wiring cannot be common ground."
Bob McC [quote] --------
Bob McC
Falco #908
(just starting)
PostPosted: Mon May 14, 2018 6:10 pm    Post subject: Re: Starting the Engine Reboots the EFIS Reply with quote
Here is circuit. A disadvantage is 1/2 volt drop across the Schottky diode.
But if the aircraft electrical system voltage is 14.2 or higher, it should be OK.
Diode part number: 747-DSA300i45NA
If the voltage drop across the diode is not desired, normally closed relay
contacts could be connected in parallel with the diode. Energize the relay
with the start push button.
 Filesize:  41.54 KB
 Viewed:  23057 Time(s)
Joe Gores
Tim Olson
PostPosted: Mon May 14, 2018 6:14 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Check out TCWTechs stuff. They have both backup batteries, and
a power stabilizer that they offer that would do the trick.
On 5/14/2018 7:38 PM, Art Zemon wrote:
Sebastien,
    -- Art Z.
monitor?
<mailto:art(at)zemon.name>> wrote:
Folks,
I am /finally/ to the point on my project of starting the
<https://drive.google.com/file/d/12DhiCdTSuUNvlsmBK027yQ1mDDy5eRUl/view?usp=sharing>
what am I? And if not now, when?" Hillel/
PostPosted: Mon May 14, 2018 6:41 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
That one appears to be buck only. Should still work fine if you only expect brownout protection. It can't do full charge voltage, but can likely do around 13-13.5v when fed 14.5 by the alternator.
But if you're doing that, it would be simpler and cheaper to just use a fat schottsky diode. Again, ebay for the best price.
On May 14, 2018, at 8:53 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Charlie,
-- Art Z.
Sebastien,
  -- Art Z.
Folks,
PostPosted: Mon May 14, 2018 6:43 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Ooh, good catch!
On May 14, 2018, at 9:13 PM, Robert McCallum <robert.mccallum2(at)sympatico.ca (robert.mccallum2(at)sympatico.ca)> wrote:[quote]
Bob McC
[quote] --------
yellowduckduo(at)gmail.co
PostPosted: Mon May 14, 2018 7:03 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Don't you want a boost converter instead of a buck converter?
Ken
On 14/05/2018 10:41 PM, Charlie England wrote:
[quote] Ooh, good catch!
<robert.mccallum2(at)sympatico.ca <mailto:robert.mccallum2(at)sympatico.ca>>
common ground."
Bob McC
rick(at)beebe.org
PostPosted: Mon May 14, 2018 7:21 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Eric Page, who's on this list, created a device to protect against this
using a large capacitor. He modified an earlier design by Eric Jones. I
bought one from him. It works great on my bench. Should be going in the
plane in the next week or so. His original email is quoted below:
--Rick
I’m starting a new thread on this topic in case anyone who might be
interested missed the recent discussion, here:
http://forum.matronics.com/viewtopic.php?t=16768062
To recap, I’ve adapted Eric Jones’ design for a voltage slump
eliminator (a device to prevent EFIS/EMS brownout/reboot during engine
start) and designed a circuit board for it. The schematic (.PDF) is here:
http://forum.matronics.com/download.php?id=44878
An archive (.ZIP) containing the full design files can be downloaded here:
https://preview.tinyurl.com/yajod9m6
So far one member of the forum has expressed a desire for me to build
one of these for him, so I’ve ordered a batch of circuit boards. If
anyone else wants a complete unit, please let me know so I can order all
of the components at once. You can reply to this thread or contact me
directly.
The cost should be about $35 each, plus postage to your address. I’ll
send a PayPal invoice, along with copies of my receipts, once I know the
exact amount for each device and I have them ready to mail.
I’m happy to part with bare circuit boards as well; again, for my cost
($0.55/ea) plus postage.
Eric
P.S. For anyone seeing this in the future, you can contact me directly
to see if I have any circuit boards on hand. The PDF schematic file
contains a link to Digi-Key that will load a shopping cart with all
necessary components.
On 05/14/2018 07:51 PM, Art Zemon wrote:
Folks,
I am /finally/ to the point on my project of starting the engine. When I
    -- Art Z.
PostPosted: Mon May 14, 2018 9:11 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
See my 1st answer. Smile
Boost only woul not be a good idea; that implies a set point higher than alternator voltage.
On May 14, 2018, at 10:07 PM, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:[quote] [quote]--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com>
Ken
common ground."
Bob McC
[quote] --------
jan_de_jong(at)casema.nl
PostPosted: Mon May 14, 2018 11:26 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
I would go for this Voltage Slump Eliminator first -  a passive device.
Switchers must be designed to generate little radiated and conducted
interference - see the discussions on usb-charging.
Jan de Jong
this using a large capacitor. He modified an earlier design by Eric
Jones. I bought one from him. It works great on my bench. Should be
going in the plane in the next week or so. His original email is
quoted below:
--Rick
here:
here:
all of the components at once.  You can reply to this thread or
contact me directly.
I’ll send a PayPal invoice, along with copies of my receipts, once I
know the exact amount for each device and I have them ready to mail.
cost ($0.55/ea) plus postage.
Eric
directly to see if I have any circuit boards on hand.  The PDF
schematic file contains a link to Digi-Key that will load a shopping
cart with all necessary components.
> Folks,
>      -- Art Z.
glastar(at)gmx.net
PostPosted: Mon May 14, 2018 11:45 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Art,
I had a similar issue not sure it is related to yours, my grounding
strap was connected to the engine case but I forgot to clean the paint
of the case, this made for a bad ground (you could feel all the control
lines to the engine heated up). Jump the negative pole of your battery
to your exhaust and try again, my engine started immediately after that
so I did know where to search.
Again, not sure it is related to your case but an easy test.
Cheers Werner
On 15.05.2018 01:51, Art Zemon wrote:
Folks,
echristley(at)att.net
PostPosted: Tue May 15, 2018 5:48 am    Post subject: Starting the Engine Reboots the EFIS Reply with quote
For a more DIY experience:
DC/DC Converters | MPJA.COM
<![endif]--> <![endif]-->
<![endif]--> DC/DC Converters | MPJA.COM
On Monday, May 14, 2018 10:09 PM, Robert McCallum <robert.mccallum2(at)sympatico.ca> wrote:
Bob McC
[quote] --------
BARRY CHECK 6
PostPosted: Tue May 15, 2018 7:46 am    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Art:
The  simplest thing that would not cost you a penny is to:  Turn the Avionics on AFTER you start the engine.
But, I'm guessing that is not the way you want to go.
Bob must have some reason why grounds cannot be common.  Try his notes second if you do not want to change your starting procedure.
Side Note:  The 5 Amps you mention on draw are probably the constant current draw and not the peak draw.  Just for S&G's consider the peak to be 3 times the constant.  Now how would that affect your system?
Side Note:  What does the Battery voltage drop to when you hit the starter?  Some starters post notes that if the voltage drops below 10 VDC the charging system or battery or starter connection should be looked into.
The idea of a DC to DC battery backup would work but I do not see why you have to go that elaborate or anywhere that costly.  A simple standby battery and a relay that is energized when the Starter Relay is energized just to supply power to the Avionics would work.  If you think a mechanical relay would be too slow in transferring power you could use a solid-state relay.
As a side benefit the battery could be used as emergency avionics buss power. All that would be needed is a desperate Switch to energizer the Avionics relay.
Good Luck OM,
Barry
On Mon, May 14, 2018 at 7:51 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
    -- Art Z.
art(at)zemon.name
PostPosted: Tue May 15, 2018 1:05 pm    Post subject: Starting the Engine Reboots the EFIS Reply with quote
Barry,
The EFIS is my engine instruments. If the EFIS is off (or rebooting) then I do not have an oil pressure gauge.
    -- Art Z.
On Tue, May 15, 2018 at 10:44 AM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
Page 1 of 3
