Posted: Fri May 11, 2018 8:30 am Post subject: Faston / Aveo Tab Terminals |
At 08:56 AM 5/11/2018, you wrote:
| Quote: | Bob:
You are mixing Apples and Apple Sauce and coming up with Lumpy Apple Sauce.
Those are PINS not Lugs. |
okay . . .
| Quote: | | The Pins are supported by the connector. |
yes . . .
| Quote: | | The Lugs are hanging out into the air. No support! |
that's what double wall heat shrink is for . . .
| Quote: | | And that is why PIDG type Lugs are preferred! |
preferred but not necessarily required . . .
especially when using 'softer' fat wires
for battery/starter circuits.
[img]cid:7.1.0.9.0.20180511112547.0595a938(at)aeroelectric.com.2[/img]
146.08 KB |
1909 Time(s) |
Posted: Fri May 11, 2018 8:35 am Post subject: Faston / Aveo Tab Terminals |
At 10:29 AM 5/11/2018, you wrote:
| Quote: | Why are you installing "lugs" that are hanging out into the air?
Me thinks the problem with lugs is caused by the problem of not following another good practice, which is that the wire should be tied down in some manner to isolate the crimp connection from vibration. You have to analyze the whole system. Not just one connector style.
Agreed. Nearly all creative arts from cooking to building
airplanes, building houses and certainly all engineering
is a study in (1) properties of materials and (2) management of
energy as a SYSTEM. Policy and procedure can be exceedingly
helpful (as long as it is correct . . . remember the AC43.13
fiasco of about 15 years back?) but it can never replace
understanding of the physics.
alec(at)alecmyers.com Guest
Posted: Fri May 11, 2018 8:42 am Post subject: Faston / Aveo Tab Terminals |
Both molex .062 type and AMP mate-n-lok connectors have wrapover insulation supports on the pins, and manage well without further support from the back shell. That is considered adequate, with appropriate wire support in the bundle.
On May 11, 2018, at 12:34, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
