Flibob
Posted: Wed May 09, 2018 5:25 pm Post subject: Chinese rebuild engine |
I just got through replacing my 1400 hour Hosai engine. Old engine ran good but new engine just sitting in the back of hangar didn't make sense.
Got it installed now for the run in. Chinese Manuel just says install engine. I assume all stops are correctly set so cables and levers should be adjusted. On the first start seemed that a mag was off. Will run with start button and pumping on primer. But, stops when button is released or prime stops. Any ideas.
pilotdog57(at)aol.com Guest
Posted: Wed May 09, 2018 6:29 pm Post subject: Chinese rebuild engine |
Check for preserving packing material inside the carburetor.
http://forums.matronics.com/viewtopic.php?p=480008#480008
ldakos(at)bigpond.net.au Guest
Posted: Wed May 09, 2018 7:06 pm Post subject: Chinese rebuild engine |
Have a look inside carbie for a little cap over jet.
wlannon(at)shaw.ca Guest
Posted: Wed May 09, 2018 7:47 pm Post subject: Chinese rebuild engine |
The Chinese do not say "just install the engine" Did you follow the manual
de-inhibiting process?
What you describe is probably a non functioning carburettor. Two items
here: 1. Carb is full of inhibiting oil and/or: 2. They sometimes put a
protective "condom" over the ambient pressure sensing tube in the carb
throat.
With item 1. only it will start eventually and run like a shit box. With
item 2 it will never start.
In addition they also usually protect the magneto points with a small piece
of oiled paper or cloth between the points. These have to be removed and
the points thoroughly cleaned of oil.
Walt
cjpilot710(at)aol.com Guest
Posted: Thu May 10, 2018 2:22 am Post subject: Chinese rebuild engine |
I agree with Walt. Also check that you turn the main fuel valve open. Jim "Pappy" Goolsby
Flibob
Posted: Thu May 10, 2018 3:23 am Post subject: Chinese rebuild engine |
Thanks Walt as usual you are a great help.
GiddyUp,
On May 9, 2018, at 11:45 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
The Chinese do not say "just install the engine" Did you follow the manual de-inhibiting process?
What you describe is probably a non functioning carburettor. Two items here: 1. Carb is full of inhibiting oil and/or: 2. They sometimes put a protective "condom" over the ambient pressure sensing tube in the carb throat.
With item 1. only it will start eventually and run like a shit box. With item 2 it will never start.
In addition they also usually protect the magneto points with a small piece of oiled paper or cloth between the points. These have to be removed and the points thoroughly cleaned of oil.
Walt
Viperdoc
Posted: Thu May 10, 2018 4:46 pm Post subject: Chinese rebuild engine |
Fuel pressure? On the YAK the fuel pump can be installed 180 out. Will not run. Well at least mine did not until I reversed it.
Doc
_________________ Viperdoc |
Viperdoc
Posted: Thu May 10, 2018 5:03 pm Post subject: Chinese rebuild engine |
Never mind. Seems the Chinese have different way of pickling there engines. Condoms on jets. Who woulda thunk it? Oiled gauze between the points is similar to The YAK.they put something like a silicon grease on theirs. Can misfire like a son of a gun if you don’t get every nanogram off the points.
Doc
| Quote: | On May 10, 2018, at 7:44 PM, Roger Kemp <f16viperdoc(at)me.com> wrote:
Doc
Flibob
Posted: Thu May 31, 2018 2:22 pm Post subject: Re: Chinese rebuild engine |
Still working on this engine. Starts but won't run unless 1. Throttle is pumped constantly or 2 wobble is pumped or 3 primer is pumped. Any of which will keep engine running at 1500 +\_.
I have taken the carberater and fuel pump off running engine with no effect. Also cleaned points in both mags.
Any ideas?
Posted: Thu May 31, 2018 5:07 pm Post subject: Chinese rebuild engine |
Serious look into the mags. Check to make sure points are clean and dry. CJ point gap, .010-.014. Check timing. Note what number is stamped in the cover mating surface and correlate that number to timing chart. Once timing has been checked, then check the rotor leading finger in the counterclockwise rotation position alignment to the scribed mark on the cover mating surface. It close to the HV stick.
Dennis
| Quote: | On May 31, 2018, at 6:22 PM, Flibob <Flibob(at)att.net> wrote:
Still working on this engine. Starts but won't run unless 1. Throttle is pumped constantly or 2 wobble is pumped or 3 primer is pumped. Any of which will keep engine running at 1500 +_.
Any ideas?
http://forums.matronics.com/viewtopic.php?p=480534#480534
Flibob
Posted: Thu May 31, 2018 5:37 pm Post subject: Chinese rebuild engine |
Thanks Dennis
GiddyUp,
On May 31, 2018, at 9:07 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
Any ideas?
Posted: Thu May 31, 2018 5:56 pm Post subject: Chinese rebuild engine |
The engine was most likely overhauled about 30 years ago. The inhibiting
oil, in normal circumstances for a military operation, would be cleaned out
and re-applied in an absolute maximum of 6 years. It is "running" on the
start solenoid and the primer NOT the carburettor.
You must follow the de-inhibiting process in the manual TO THE LETTER and
beyond since the oil has long since turned to hard grease. Particularly
true for the carburettor but applies to everthing they list in the manual.
Once you get serious and spend a few days on due diligence it will start and
run like a top. Do not mess with the point gap setting. The factory will
have set these
at exactly 0.3 mm (0.012"). Just make sure they are perfectly clean
Of course you have already confirmed that the carburetor ambient air tube in
the carb. throat is not blocked.
Cheers;
Walt
Posted: Thu May 31, 2018 6:26 pm Post subject: Chinese rebuild engine |
I spoke to Bob this afternoon and he said he removed and replaced the carburetor using the one from the old engine and there was no difference in the way it ran.
Dennis
To: yak-list(at)matronics.com
Sent: Thursday, May 31, 2018 9:59 PM
Subject: Re: Re: Chinese rebuild engine
--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
have set these
Cheers;
Walt
Posted: Thu May 31, 2018 6:28 pm Post subject: Chinese rebuild engine |
Posted: Fri Jun 01, 2018 12:53 am Post subject: Chinese rebuild engine |
Just a question what about the fuel pump?
Flibob
Posted: Fri Jun 01, 2018 3:09 am Post subject: Chinese rebuild engine |
Lou, I replaced the new fuel pump with the pump off the old working engine no effect.
GiddyUp,
Clouddog
Posted: Fri Jun 01, 2018 5:05 am Post subject: Chinese rebuild engine |
Is there any possible way the mixture control can be installed backwards or it has something to do with the mixture in some way? Just a stupid thought. Heck, push the mixture lever full forward and see what happens. I know, dumb idea and impossible to rig backwards.
On Fri, Jun 1, 2018, 6:14 AM Bob Graves <flibob(at)att.net (flibob(at)att.net)> wrote:
[quote]--> Yak-List message posted by: Bob Graves <flibob(at)att.net (flibob(at)att.net)>
GiddyUp,
On Jun 1, 2018, at 4:53 AM, Lou Dakos <ldakos(at)bigpond.net.au (ldakos(at)bigpond.net.au)> wrote:
--> Yak-List message posted by: "Lou Dakos" <ldakos(at)bigpond.net.au (ldakos(at)bigpond.net.au)>
Posted: Fri Jun 01, 2018 7:24 am Post subject: Chinese rebuild engine |
It might be worthwhile to pull the fuel line off the carb and then crank the engine to see what kind of flow you get out of the line/hose. If you have a clog or flow inhibition in any of the fuel filters or fuel lines, you will still get good pressure indications if there is even the most tiny of openings. It appears clear that when the engine gets fuel from prime, it runs. Also be careful to check that the return line from the carb back to the tank (if the CJ has one, I am not sure) because if that line is clogged, the carb will also not operate correctly. Since the carb and fuel pump have been replaced, fuel flow (not pressure but flow) seems to be highly suspect.
Mark
Flibob
Posted: Fri Jun 01, 2018 8:10 am Post subject: Chinese rebuild engine |
Thanks Mark
[quote] On Jun 1, 2018, at 11:24 AM, Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil> wrote:
Mark
Flibob
Posted: Sat Jun 02, 2018 1:12 pm Post subject: Re: Chinese rebuild engine |
Any ideas?
