gdhelton(at)gmail.com Guest
Posted: Wed May 09, 2018 1:10 pm Post subject: High Thrust Line Question |
I agree with you that the HKS is great engine. I considered it when I was shopping for a new engine for my original Firestar. But, after talking to Bryan at Kolb it wasn’t to be. He didn’t think the original Firestars had a strong enough cage assembly ( chromoly steel tubing wall thicknesses)to handle the torque that the HKS produces. I
went along with his opinion.
We used Belleville washers for many years in heavy equipment powershift transmissions as an alternative to the piston return springs inside the hydraulic clutch packs They worked great. They would fail eventually like anything else. But, it took ten of thousands of cycles. Good luck on the idea.
George Helton
1986 Firestar, FS100
14GDH
Mesick, Michigan
| Quote: | On May 9, 2018, at 3:54 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
The replacement gear set does not fit into the same gearbox case. So unfortunately I cannot just buy two new gears and slide them into place.
BUT... I am making progress towards one of the other potential solutions. After consulting with an experienced aircraft structures and metallurgy engineer, I believe I can make a simple prop extension that is held on with one central nut (a great big nut !) and remove the propeller before folding the wings.
The key to doing this SAFELY is called the Belleville Spring, or Belleville Washer. It is a conical spring steel washer that becomes flat (like a regular washer) as it is tightened, providing a known, reliable tension/compression force over a reasonable range of installation torques.
This means that I can install the propeller, tighten the nut until the Belleville Washer is more or less flat, and be confident that there is plenty of tension/compression in the propeller mounting without having to use a torque wrench, elaborate bolt stretch charts, etc. etc. This also provides a much more convenient and error-proof option instead of havign to torque six propeller bolts and safety wire the bolts, install six Cotter Pins, etc.
All of this means I will be hopefully able to use a 4, 5, or 6 blade prop with the thrust line within Kolb's recommended distance from the tailboom.
The only downside is that Kolbers around the world will never stop making fun of me for turning a simple airplane into a major engineering project
The HKS engine is a VERY good quality engine and I believe the other Kolb/HKS owners will agree they love the engine. If you wish to use this engine on a Kolb, don't hold my mis-adventures against the engine... just make darn sure you get the 2.58 gearbox !
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Wed, 5/9/18, George Helton <gdhelton(at)gmail.com> wrote:
Subject: Re: Re: High Thrust Line Question
Date: Wednesday, May 9, 2018, 11:37 AM
Bill, I know that this might sound
crazy but, can’t you just buy a different set of gears for
the gearbox? Being a mechanic may be a benefit here but I
can’t imagine that HKS can’t supply replacement parts.
The gearbox case doesn’t care what gears fit inside of it.
If they don’t, I’d sure shy away
from buying one.
George Helton
14GDH
Mesick, Michigan
> On May 9, 2018, at 2:18 PM, Bill
wrote:
> --> Kolb-List message posted
by: Bill Berle <victorbravo(at)sbcglobal.net>
> I have been pulling out what's
left of my hair over this issue. I really don't want to
quit, I LIKE the Kolb airframe and it will fit my mission
well. I like the HKS fuel economy and improved reliability.
I just wound up with the wrong gearbox on it and cannot
afford to change it.
> What I have learned thus far is:
> 1) My 3.47 to 1 gearbox really
wants to swing a larger propeller than what is
actually "correct" for the height of the thrust line
on the Kolb airframe.
> 2) Turning the gearbox upwards
will solve the prop diameter problem, but it creates a
thrust line that is higher than the Kolb factory thinks is
advisable.
> 3) I could easily go to a 4 or 5
blade propeller, solves the gearbox AND thrust line
problems, but that interferes with folding the wings.
> I have considered many possible
solutions or "work-arounds" :
> 1) Get a 5 blade propeller and
remove it after every flight, which would allow ALL of the
problems to be solved, at the cost of additional time and
effort every time I fly. This will cost the least of all the
"solutions".
> 2) Remove the wings after every
flight instead of folding the wings. This allows a 5 blade
propeller to be used but adds complexity and requires me to
build a complicated ground fixture to allow the wings to be
removed and installed by myself alone.
> 3) Make a folding propeller, like
the electric R/C model gliders have, where the blades fold
rearward. This solves all of the problems, no complex ground
equipment, but designing and manufacturing such a propeller
will be prohibitvely expensive.
> 4) Buy another gearbox from HKS.
This is the best solution mechanically, but I cannot afford
it.
> 5) Turn the gearbox upwards,
install the right propeller, and live with the possibly
dangerous or funky flight handling of the airplane.
> Any other/better/wiser/workable
ideas from the Kolb List are very very welcome!
> Bill Berle
> www.grantstar.net
for-profit entities
> To: kolb-list(at)matronics.com
> Date: Wednesday, May 9, 2018, 9:39
AM
by: George
> Well Bill, thanks for bringing up
the
> topic. I replaced my little Rotax
377 with new low rpm Hirth
> 2702 over the winter. I really
hadn’t measured the
> distance between the prop hub and
boom tube. You sparked my
> interest so I stopped by my hanger
this morning to check it
> out. The Hirth uses a G50 gearbox
with 2:29 to 1 ratio.
> which translates to 2400 rpm prop
speed (at) the engine’s
> max. HP rpm of 5500rpm.
> Anyway, it measures 35.5 inches.
This
> is on a Kolb original Firestar. I
did have to move the
> engine forward 2.625” to
compensate for the extra weight
> of the new gear box. I went with a
64” 3 blade Powerfin
> prop set at 6.4 degrees of pitch.
This setup gives me 3.5”
> of clearance from the boom tube.
Thanks for inspiring me to
> check it out. I’m sure
there is a good combination
> of prop out there for an HKS.
> George Helton
> 14GDH
> Mesick, Michigan
> Sent from my iPhone
>> On May 8, 2018, at 11:08 PM,
Bill
posted
>> Everybody THANK YOU for
taking
> time for this discussion.
>> I spoke to the Kolb factory
today
> by phone, and went out to the
local UL flying field to see
> an HKS engine run.
>> Duane and Bryan at Kolb were
asked
> one specific question by me:
What is the maximum
> number of inches allowable or
advisable between the center
> of the propeller and the top of
the tailboom?
>> Bryan said that 36 inches is
about
> standard for a "normal" Firestar,
and he would not want to
> fly an airplane with that distance
raised to 39 or 40
> inches.
>> I went back to my hangar and
> measured, and the distance on my
Firestar would be over 40
> or 41 inches if I turned the
gearbox upward. So if the Kolb
> factory owner says 40 inches is
too high, I can only be
> humble and assume that I wouldn't
want to fly it at 40
> inches either. If any of the
highly experienced Kolbers on
> this forum are flying with their
thrust line 40 inches above
> the tailboom, I REALLY would like
to know about it pronto.
>> As big of an ego as I have had
a
> few times in my life, and as much
as I think of myself as a
> reasonably skilled pilot, I
don't need to be a test
> pilot here and try to push any
envelope at this early stage.
> So if I can ask the Kolb ilst a
favor... if any of you are
> flying a Firestar with the engine
thrust line 39 or 40 or 41
> incvhes above the tailboom please
post this on the list and
> let me know ifyou have any issues
with the handling,
> pitch-over, etc.
>> Bill Berle
for light aircraft
>> www.grantstar.net
> for-profit entities
>> On Tue, 5/8/18, Richard Pike
> <thegreybaron(at)charter.net>
> wrote:
>> Subject: Re: High
>> Date: Tuesday, May 8, 2018,
4:38
> PM
posted
> by: "Richard
>> Pike" <thegreybaron(at)charter.net>
>> Bill; notice the extent to
which
> Rick
>> raised his engine. (Great
> pictures) Maybe you can leave the
>> gearbox down and raise the
engine
> up?
>> Richard Pike
>> Kolb MKIII N420P (420ldPoops)
>> Kingsport, TN 3TN0
>> Forgiving is tough, being
forgiven
> is
>> wonderful, and God's grace
really
> is amazing.
>> http://forums.matronics.com/viewtopic.php?p=479963#479963
>> The Kolb-List Email Forum -
>> Navigator to browse
>> List Un/Subscription,
>> 7-Day Browse, Chat, FAQ,
MATRONICS
> WEB FORUMS -
>> via the Web Forums!
>> - NEW
MATRONICS LIST
> WIKI -
>> Email List Wiki!
>> - List
Contribution
> Web Site -
>> support!
>> -Matt
Dralle, List
> Admin.
> Navigator to browse
> - MATRONICS
WEB FORUMS -
> via the Web Forums!
> - NEW MATRONICS LIST
WIKI -
> Email List Wiki!
> - List Contribution
Web Site -
> support!
> -Matt Dralle, List
Admin.
Navigator to browse
- MATRONICS WEB FORUMS -
via the Web Forums!
- NEW MATRONICS LIST WIKI -
Email List Wiki!
- List Contribution Web Site -
support!
-Matt Dralle, List Admin.
Posted: Wed May 09, 2018 3:21 pm Post subject: High Thrust Line Question |
A large Belleville washer is used in the slip clutches in the 912 series gear boxes.
_________________ John Hauck
Titus, Alabama |
Posted: Wed May 09, 2018 4:31 pm Post subject: High Thrust Line Question |
You’re right John. Actually Rotax has used them in their gearboxes for years in smaller version. They stacked them face to face in the anti-clatter mechanisms.
George Helton
14GDH
Mesick, Michigan
[quote] On May 9, 2018, at 7:20 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
neilsenrm(at)gmail.com Guest
Posted: Fri May 11, 2018 9:32 am Post subject: High Thrust Line Question |
Bill
I can only speak about the MKlll with a VW. I have run It with A 72 inch
prop with 7” clearance, 1” clearance, a 60” prop turning 3200 rpm and 72”
at 2000 rpm.
With a 72” prop and 7” clearance one person operation was fine but with two
I would run out of up elevator at full power.
The 60” prop turned large amount of power into noise. The three blade 2000
rpm 72” prop gives twice the thrust.
If you can fit a 70-74” prop depending on prop recommendations with close
to 1” clearance by raising the engine do it. If you keep the prop clearance
the same the apparent thrust line change is half the prop shaft change.
You might find the big reduction ratio a better overall fit.
Rick Neilsen
Redrive VW powered MKIII
On Wed, May 9, 2018 at 8:58 PM Bill Berle <victorbravo(at)sbcglobal.net> wrote:
the wings.
victorbravo(at)sbcglobal. Guest
Posted: Fri May 11, 2018 9:46 am Post subject: High Thrust Line Question |
THANK YOU Rick, I appreciate the feedback.
After all this enormous discussion and exchange of information, I am strongly leaning towards turning the gearbox upward and running a large propeller.
The reason for this is that I believe I would have an "out" if I needed it... if I do run out of elevator control because of the thrust line being high, I can find a fairly straightforward way to increase elevator authority to overcome it. I can increase the chord or span of the elevator, add VG's under the elevator, add the outboard part of the stabilizer to the movable part of the elevator (called an "aerodynamic balance" on Cub type aircraft), etc.
Onward !
Bill Berle
Date: Friday, May 11, 2018, 10:30 AM
Bill I
A 72 inch prop with 7” clearance, 1” clearance, a 60”
prop turning 3200 rpm and 72” at 2000
rpm.
operation was fine but with two I would run out of up
noise. The three blade 2000 rpm 72” prop gives twice the
thrust.
recommendations with close to 1” clearance by raising the
engine do it. If you keep the prop clearance the same the
change.
overall fit.
Rick Neilsen Redrive VW powered
MKIII
On Wed, May 9,
Bill Berle
www.grantstar.net
entities
for
parts.
it.
from buying one.
George Helton
14GDH
Mesick, Michigan
to
reliability.
thrust line
is
advisable.
the
the
"solutions".
blade
to
be
fold
ground
propeller
afford
it.
> Bill Berle
> www.grantstar.net
for-profit entities
AM
by: George
the
hadn’t measured the
This
> George Helton
> 14GDH
> Mesick, Michigan
> Sent from my iPhone
Bill
posted
taking
today
> an HKS engine run.
asked
What is the maximum
the tailboom?
about
raised to 39 or 40
> inches.
a
with the handling,
> pitch-over, etc.
>> Bill Berle
for light aircraft
>> www.grantstar.net
> for-profit entities
> wrote:
>> Subject: Re: High
4:38
> PM
posted
> by: "Richard
which
> Rick
engine
> up?
>> Richard Pike
>> Kingsport, TN 3TN0
forgiven
> is
really
> is amazing.
>> Navigator to browse
MATRONICS
> WEB FORUMS -
>> via the Web Forums!
>> - NEW
MATRONICS LIST
> WIKI -
>> Email List Wiki!
>> - List
Contribution
> Web Site -
>> support!
>> -Matt
Dralle, List
> Admin.
> Navigator to browse
> - MATRONICS
WEB FORUMS -
> via the Web Forums!
WIKI -
> Email List Wiki!
> - List Contribution
Web Site -
> support!
> -Matt Dralle, List
Admin.
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?Kolb-List
FORUMS -
eferrer"
target="_blank">http://forums.matronics.com
WIKI -
errer"
target="_blank">http://wiki.matronics.com
b Site -
rel="noreferrer"
Posted: Fri May 11, 2018 10:15 am Post subject: High Thrust Line Question |
Bill, I was wondering? Did you buy this HKS engine and gearbox combination from a HKS distributor? If so, is HKS in such a state of financial insecurity that it won’t even consider swapping the the gearbox you have for one you need for say a 20 to 30% restock or exchange fee? It sure disturbs me to think of that kind business practice. I’d think they would have a hard time selling engines in the future. I mean I understand that you ordered the wrong gearbox, but come on. Maybe I just spent to much time in sells, rental and customer service. -George-
| Quote: | On May 11, 2018, at 1:44 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Onward !
Bill Berle
Bill I
rpm.
thrust.
change.
overall fit.
MKIII
On Wed, May 9,
Bill Berle
www.grantstar.net
entities
for
parts.
it.
from buying one.
George Helton
14GDH
Mesick, Michigan
to
reliability.
thrust line
is
advisable.
the
the
"solutions".
blade
to
be
fold
ground
propeller
afford
it.
> Bill Berle
> www.grantstar.net
for-profit entities
AM
by: George
the
hadn’t measured the
This
> George Helton
> 14GDH
> Mesick, Michigan
> Sent from my iPhone
Bill
posted
taking
today
> an HKS engine run.
asked
What is the maximum
the tailboom?
about
raised to 39 or 40
> inches.
a
with the handling,
> pitch-over, etc.
>> Bill Berle
for light aircraft
>> www.grantstar.net
> for-profit entities
> wrote:
>> Subject: Re: High
4:38
> PM
posted
> by: "Richard
which
> Rick
engine
> up?
>> Richard Pike
>> Kingsport, TN 3TN0
forgiven
> is
really
> is amazing.
>> Navigator to browse
MATRONICS
> WEB FORUMS -
>> via the Web Forums!
>> - NEW
MATRONICS LIST
> WIKI -
>> Email List Wiki!
>> - List
Contribution
> Web Site -
>> support!
>> -Matt
Dralle, List
> Admin.
> Navigator to browse
> - MATRONICS
WEB FORUMS -
> via the Web Forums!
WIKI -
> Email List Wiki!
> - List Contribution
Web Site -
> support!
> -Matt Dralle, List
Admin.
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
FORUMS -
eferrer"
WIKI -
errer"
b Site -
rel="noreferrer"
mojavjoe
Posted: Fri May 11, 2018 4:11 pm Post subject: High Thrust Line Question |
BILL My two cents. On my FSII I could fold the wings with a two bladed prop horizontal by loosing the rear mount and lifting the engine slightly. Take a few measurements and you might be able to use a four bladed prop.
joe
| Quote: | On May 11, 2018 at 1:44 PM Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Onward !
Bill Berle
Bill I
rpm.
thrust.
change.
overall fit.
MKIII
On Wed, May 9,
Bill Berle
www.grantstar.net
entities
for
parts.
it.
from buying one.
George Helton
14GDH
Mesick, Michigan
to
reliability.
thrust line
is
advisable.
the
the
"solutions".
blade
to
be
fold
ground
propeller
afford
it.
> Bill Berle
> www.grantstar.net
for-profit entities
AM
by: George
the
hadn’t measured the
This
> George Helton
> 14GDH
> Mesick, Michigan
> Sent from my iPhone
Bill
posted
taking
today
> an HKS engine run.
asked
What is the maximum
the tailboom?
about
raised to 39 or 40
> inches.
a
with the handling,
> pitch-over, etc.
>> Bill Berle
for light aircraft
>> www.grantstar.net
> for-profit entities
> wrote:
>> Subject: Re: High
4:38
> PM
posted
> by: "Richard
which
> Rick
engine
> up?
>> Richard Pike
>> Kingsport, TN 3TN0
forgiven
> is
really
> is amazing.
>> Navigator to browse
MATRONICS
> WEB FORUMS -
>> via the Web Forums!
>> - NEW
MATRONICS LIST
> WIKI -
>> Email List Wiki!
>> - List
Contribution
> Web Site -
>> support!
>> -Matt
Dralle, List
> Admin.
> Navigator to browse
> - MATRONICS
WEB FORUMS -
> via the Web Forums!
WIKI -
> Email List Wiki!
> - List Contribution
Web Site -
> support!
> -Matt Dralle, List
Admin.
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
FORUMS -
eferrer"
WIKI -
errer"
b Site -
rel="noreferrer"
Richard Pike
Posted: Fri May 11, 2018 6:04 pm Post subject: Re: High Thrust Line Question |
Increasing the size/shape of the horizontal stab ought to solve a whole bunch of apparent control authority issues. It would not be a big deal to increase the chord of any Kolb horizontal stab, and it would not take but a little creative thinking to make it work very well and still retain the folding ability. As long as you keep the basic concepts the same, all you can do is make things better.
(Also - does nobody know how to edit/remove a whole boatload of previous/extraneous posts from their posts? So that we don't have posts that are full of scroll down/scroll down/scroll down extraneous/previous posts?
Not that I want to be the list Hall Monitor; but seriously? This is stuff that we knew how to deal with back in Windows 3.5!!)
Flame on...
Kingsport, TN 3TN0
Posted: Fri May 11, 2018 10:50 pm Post subject: High Thrust Line Question |
I bought my HKS engine used from a guy in Petaluma, CA who was using it on a weight shift trike. No dealer or distributor was involved. Jerry Olenik (one US dealer) was wonderful to me before he passed away, and Chris Gatin (other US dealer) was great as well. I have no complaints with anyone on the factory or dealer end of this.
Bill Berle
Date: Friday, May 11, 2018, 11:14 AM
feedback.
aircraft), etc.
> Onward !
> Bill Berle
> www.grantstar.net
for-profit entities
AM
> Bill I
2000
> rpm.
would run out of up
of power into
> thrust.
depending on prop
half the prop shaft
> change.
ratio a better
> overall fit.
> MKIII
> On Wed, May 9,
by:
is held on with one
etc.
within Kolb's
tailboom.
> Bill Berle
for light aircraft
> www.grantstar.net
> - winning
> entities
> wrote:
> Subject: Re: Re:
2018, 11:37 AM
posted by: George
sound
> for
> parts.
> it.
shy away
> from buying one.
> George Helton
> 14GDH
> Mesick, Michigan
> Sent from my iPhone
PM, Bill
> wrote:
> > --> Kolb-List
message posted
what's
> to
> reliability.
> > What I have learned
thus far is:
really
the height of the
> thrust line
upwards
> is
> advisable.
a 4 or 5
> problems, but that
possible
> > 1) Get a 5 blade
propeller and
> the
> the
> "solutions".
> > 2) Remove the wings
after every
> blade
> to
> be
myself alone.
> > 3) Make a folding
propeller, like
> fold
> ground
> propeller
expensive.
from HKS.
> afford
> it.
> > 5) Turn the gearbox
upwards,
> > Any
very very welcome!
> > Bill Berle
> > www.grantstar.net
> for-profit entities
Helton
> wrote:
> > Subject: Re: Kolb-List:
Re: High
2018, 9:39
> AM
> > --> Kolb-List
message posted
> by: George
bringing up
> the
little Rotax
really
> hadn’t measured the
prop hub and
by my hanger
G50 gearbox
> > which translates to
2400 rpm prop
> > Anyway, it measures
35.5 inches.
> This
Firestar. I
to
weight
went with a
of pitch.
boom tube.
> > check it out.
I’m sure
an HKS.
> > George Helton
> > 14GDH
> > Mesick, Michigan
> > Sent from my iPhone
> >> On May 8, 2018, at
11:08 PM,
> Bill
> > wrote:
> >> --> Kolb-List
message
> posted
> >> Everybody THANK YOU
for
> taking
> > time for this
discussion.
> >> I spoke to the Kolb
factory
> today
to the
see
> > an HKS engine run.
> >> Duane and Bryan at
Kolb were
> asked
by me:
> What is the maximum
> > number of inches
allowable or
center
the top of
> the tailboom?
> >> Bryan said that 36
inches is
> about
Firestar,
that distance
> raised to 39 or 40
> > inches.
> >> I went back to my
hangar and
> > measured, and the
distance on my
> > or 41 inches if I
turned the
Kolb
inches is
I wouldn't
of the
on
with their
would like
> >> As big of an ego as
I have had
> a
and as much
> > reasonably
skilled pilot, I
push any
stage.
> > So if I can ask the
Kolb ilst a
the engine
> > incvhes above the
tailboom please
any issues
> with the handling,
> > pitch-over, etc.
> >> Bill Berle
> > safety &
performance upgrade
> for light aircraft
www.grantstar.net
non-profit and
> > for-profit entities
> >> On Tue, 5/8/18,
Richard Pike
> > wrote:
> >> Subject: Kolb-List:
Re: High
> >> Date: Tuesday, May
8, 2018,
> 4:38
> > PM
> >> --> Kolb-List
message
> posted
> > by: "Richard
> >> Bill; notice the
extent to
> which
> > Rick
> >> raised his engine.
(Great
leave the
> >> gearbox down and
raise the
> engine
> > up?
> >> Richard Pike
> >> Kolb MKIII N420P
(420ldPoops)
> >> Kingsport, TN 3TN0
> >> Forgiving is tough,
being
> forgiven
> > is
> >> wonderful, and
God's grace
> really
> > is amazing.
> >> Read this topic
online here:
> >> The Kolb-List Email
Forum -
> >> Navigator to
browse
> >> List
Un/Subscription,
> >> 7-Day Browse, Chat,
FAQ,
> MATRONICS
> > WEB FORUMS -
> >> via the Web
Forums!
- NEW
> MATRONICS LIST
> > WIKI -
> >> Email List Wiki!
List
> Contribution
> > Web Site -
> >> support!
-Matt
> Dralle, List
> > Admin.
> > The Kolb-List Email
Forum -
> > Navigator to browse
> > 7-Day Browse, Chat,
FAQ,
MATRONICS
> WEB FORUMS -
> > via the Web Forums!
> > - NEW
MATRONICS LIST
> WIKI -
> > Email List Wiki!
> > - List
Contribution
> Web Site -
> > support!
> > -Matt
Dralle, List
> Admin.
> Navigator to browse
> - MATRONICS
WEB FORUMS -
> via the Web Forums!
> - NEW
> Email List Wiki!
> - List Contribution
Web Site -
> support!
> -Matt Dralle,
List Admin.
> FORUMS -
> eferrer"
> WIKI -
> errer"
> b Site -
> rel="noreferrer"
> target="_blank">http://www.matronics.com/contribution
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
Posted: Fri May 11, 2018 11:09 pm Post subject: High Thrust Line Question |
I looked at the stabilizer and elevator today and it seems that IF I had to enlarge the elevator area it would not be a difficult project. The worst thing that could happen is that I might have to move the outboard elevator hinge inboard 3 or 4 inches.
No modifications would be needed (or advisable) to the Kolb folding elevatorcontrol mechanism, the brace wires, the weight of the elevator behind the hinge line, etc. On high speed aircraft changing the space between the hinges can allow oscillation/flutter to develop, but on a <100 MPH airplane that is a very low probability.
Today I more or less finalized the straps and wood saddle blocks to mount my muffler under the tailboom. I bought real surplus aerospace hoop clamps which will strap the muffler in place, and had to shorten them by an inch or two and rivet them back together. Managed to find rubber C channel that fits over the straps the same way as the rubber channel on a padded Adel clamp. The rubber even matches the color of the airplane ! So all that is left on that mini-project is repainting the saddle blocks with good old Aerospace-Oleum rattle can paint.
Next project is weight and balance, finding where the battery needs to go or where it should not go. After that, the gearbox rotation and prop selection process. After that comes finalizing the electrical wiring, and after that is engine start and figuring out if it runs correctly.
Bill Berle
On Fri, 5/11/18, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Re: High Thrust Line Question
Date: Friday, May 11, 2018, 7:04 PM
make things better.
posts?
Flame on...
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=480082#480082
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
