Mounting AHRS & Magnetometer
pastormac62
PostPosted: Sun Apr 29, 2018 1:58 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
Hi Guys,
I putting in a Grand Rapids glass cockpit in my TR-1. Anyone have any thoughts on where to mount the AHRS and magnetometer?
To our success, Stephen McIntosh
Robert Reed
PostPosted: Sun Apr 29, 2018 2:35 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
I might not be the best one to answer your question since I am still at the 90% level but I put mine on a shelf behind the baggage compartment. Leveled from front to back and side to side as far from any potential interference as possible. Just bonded two angled alum pieces on each side and then a shelf between them.
See photo:
Hope this helps.
Bob Reed
From: "pastormac(at)comcast.net" <pastormac(at)comcast.net>
To: kis-list(at)matronics.com
Sent: Sunday, April 29, 2018 4:58 PM
Subject: KIS-List: Mounting AHRS & Magnetometer
--> KIS-List message posted by: pastormac(at)comcast.net (pastormac(at)comcast.net)
Hi Guys,
_-= --> http://www.matronics.com/Navigator?KIS-List
http://wiki.matronics.comhttp://www.=====
 Filesize:  249.21 KB
 Viewed:  7760 Time(s)
gbrighton(at)skymesh.com.
PostPosted: Sun Apr 29, 2018 4:32 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
G’Day guys ..,
I have a GRT Mini ... mounted on the panel ...( TR1 ) ... my set up is 50/50 .. (stream plus glass ) .. the Mini has integrated AHRS .. so that’s easy ... but yep have to mount the Magnetometer.. thinking inside Wing Tip fairing ... not operating as yet as still finishing up accessories of Engine install ( Subaru ) ... been a long process but nearing first start .... oil, Water, Fuel in this wk ... so ...,
The Mini is small ... which model did u choose ..? Reading the Manual is quite a “ head full “ .... ,
Graham Brighton
pastormac62
PostPosted: Sun Apr 29, 2018 5:35 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
Hi Graham,I have the 8.5 inch HXR and backup mini.
On Apr 29, 2018, at 6:34 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
See photo:
Hope this helps.
Bob Reed
From: "pastormac(at)comcast.net (pastormac(at)comcast.net)" <pastormac(at)comcast.net (pastormac(at)comcast.net)>
Subject: Mounting AHRS & Magnetometer
Hi Guys,
<IMG_1167.JPG>
wschertz343(at)gmail.com
PostPosted: Sun Apr 29, 2018 7:57 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
I put the magnetometer behind the bulkhead on a small fiberglass shelf. AHRS was in the panel unit. This has worked well.
Sent: Sunday, April 29, 2018 4:34 PM
Subject: Re: Mounting AHRS & Magnetometer
See photo:
Hope this helps.
Bob Reed
Hi Guys,
" wiki.matronics.com< >http: ? wiki.matronics.com ltp:>http://www.=====
 Filesize:  591.43 KB
mike(at)vision499.com
PostPosted: Tue May 01, 2018 3:32 pm    Post subject: Mounting AHRS & Magnetometer Reply with quote
I am going with the MGL LITE in a TR-4 that does not have a remote AHRS.
While still planning for a remote AHRS my thinking was to mount a back-up
battery under the passenger seat on Velcro and mount the AHRS on top of the
battery with a second layer of Velcro. The theory was that the combination
of the mass of the battery and the Velcro would dampen some of the
vibration. Having it under the seat would place it close to the roll centre.
My magnetometer is in the left hand tip of the horizontal stabiliser.
Nothing proven as I am not flying yet
Keep well
