gill shutter anti-chafe strip
jonboede(at)hotmail.com
PostPosted: Mon Apr 30, 2018 1:37 pm    Post subject: gill shutter anti-chafe strip Reply with quote
Around the gill shutter ring is an anti-chafing strip that (having discussed it with Doug Sapp) is secured by the plates riveted to the ring. So it's not a separate, replaceable part.
My gill shutters are in fabulous shape. My anti-chafing strip is not.
Anybody got any ideas for replacing it with some kind of modern material and glue that would hold up?
Jon
hkgibby(at)yahoo.com
PostPosted: Mon Apr 30, 2018 2:30 pm    Post subject: gill shutter anti-chafe strip Reply with quote
Jon-
I used some felt strip (2x120”, 3/16” thick) from Grainger (Item #2FJB9) and Polycord waxed thread (.030) from www.mainethread.com. and my better half sewed it on. Works fine but one corner needs re-sewing, but afraid to tell wife her work was sub par, ha, ha!😅 so it’s flapping around a little on one end, but only on a cowl off engine run - Hoot
[img]cid:6E269406-B719-4B36-AA5B-11FF0D5CDC29[/img]
[img]cid:08135519-8DBE-4F0B-AF3A-7FB0285761B1[/img]
On Apr 30, 2018, at 5:35 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Jon
=================================== //www.matronics.com/Navigator?Yak-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
 Filesize:  421.44 KB
 Viewed:  4230 Time(s)
 Filesize:  488.96 KB
romaine_richard(at)yahoo.
PostPosted: Tue May 01, 2018 1:31 am    Post subject: gill shutter anti-chafe strip Reply with quote
I’ve used cowhide leather strap as an anti-chafe on wire/hose, cowl rub areas and when layered, as baffle seal. Survives our sometimes oil rich environment and easy to cut, drill/punch and pop-rivet/zip tie. Fairly cheap too. “Wanderingbull.com”
Rich
yakman285(at)gmail.com
PostPosted: Tue May 01, 2018 1:56 am    Post subject: gill shutter anti-chafe strip Reply with quote
I use a bicycle inner tube, cutting out the stem and trimming to fit. No need to sew or use any screws. Stretches to hold into place.
Craig Payne
jill(at)m-14p.com
PostPosted: Tue May 01, 2018 4:39 am    Post subject: gill shutter anti-chafe strip Reply with quote
Jon and Group,
We use a convertible top material for the Yaks. I don't know if our cushion
rings would fit the Huosai/CJ ring.
The axles will loosen up and need to be checked on condition inspection, at
least. I would not cover those up with material. Don;t negate the
importance of the seal for the proper fit and seal of the cowling. You can
easily spend 1/2 a day rigging the louvers and cowling. Indications of poor
fit are cracked louver blades, sagging cowl lord mounts and cowl halves
chewing one another up because of overlap.
Jill Gernetzke
M-14P, Inc.
4905 Flightline Drive
Kingman, AZ 86401
928-681-4400
www.m-14p.com
