CJ rear flap selector valve removal
glipaz
PostPosted: Tue Apr 03, 2018 9:28 pm    Post subject: CJ rear flap selector valve removal Reply with quote
To the brain trust: I would like to remove the GIB flap control valve. I already did the GIB gear valve but replaced it with a block. Question: do the remaining three air lines have to be connected or can I just cap each of the three lines? It seems to me that I can just cap them since the air is coming from the front valve.
Thanks, Gil
Ttail
PostPosted: Wed Apr 04, 2018 12:47 pm    Post subject: Re: CJ rear flap selector valve removal Reply with quote
Gil I have done the same and just capped the lines
 Filesize:  97.67 KB
 Viewed:  9202 Time(s)
glipaz
PostPosted: Wed Apr 04, 2018 1:36 pm    Post subject: Re: CJ rear flap selector valve removal Reply with quote
Thanks! Did you make those caps? If not, where can I get them?
Ttail
PostPosted: Wed Apr 04, 2018 9:16 pm    Post subject: Re: CJ rear flap selector valve removal Reply with quote
No an aero engineering establishment in Australia did them.
N642K
PostPosted: Fri Oct 26, 2018 5:08 am    Post subject: Re: CJ rear flap selector valve removal Reply with quote
I'm troubleshooting a flap issue this weekend. This idea really appeals to me. How do we get these plugs into our supply chain?
dsavarese0812(at)bellsout
PostPosted: Fri Oct 26, 2018 5:15 am    Post subject: CJ rear flap selector valve removal Reply with quote
Plugs? Do you mean the fittings that screw into the flap selector? If so, have you tried Doug Sapp?  He typically has some or all of the fittings in stock.
Dennis
To: yak-list(at)matronics.com
Sent: Friday, October 26, 2018 9:11 AM
Subject: Yak-List: Re: CJ rear flap selector valve removal
--> Yak-List message posted by: "N642K" <mdecanio(at)mac.com (mdecanio(at)mac.com)>
http://forums.matronics.com/viewtopic.php?p=484023#484023
http://www.matronics.comnbsp; - MATRONICS WEB FORUMS -http://wiki.matronics.com[/url]
http://www.matron===
N642K
PostPosted: Fri Oct 26, 2018 5:24 am    Post subject: Re: CJ rear flap selector valve removal Reply with quote
Doug Sapp - Do you carry plugs/caps for bypassing the rear flap handle?
