art(at)zemon.name Guest
Posted: Mon Mar 12, 2018 4:06 am Post subject: Dynon Pitot Heat Warning with MGL EFIS |
Folks,
I am installing a Dynon heated pitot tube. The controller has a pin which gets grounded if the heater is turned on and fails. This is supposed to drive a warning lamp. See "pitot heat warn" on the attached diagram.
I want to replace the pitot heat warn lamp with an indicator on my MGL EFIS. The EFIS has eight analog inputs (see A1 through A8 on page 6 of the attached iBOX V1 installation manual) and also has four balanced analog inputs (see 1+,1- through 4+,4-) on page 7.
This would be easy for me if INST-4-G from the Dynon controller was either grounded or at some positive voltage. But if I understand correctly, that wire is either grounded or open. How do I hook this to my EFIS?
-- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
 Download |
| Filename: |
pitot.pdf |
28.13 KB |
| Downloaded: |
993 Time(s) |
 Download |
| Filename: |
iBOX_V1_installation_manual.pdf |
250.25 KB |
| Downloaded: |
1078 Time(s) |
Posted: Mon Mar 12, 2018 4:59 am Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS |
Connect a pull-up resistor, perhaps 1K Ω or more, between a positive source and the Dynon alarm wire.
_________________ Joe Gores |
Posted: Mon Mar 12, 2018 5:33 am Post subject: Dynon Pitot Heat Warning with MGL EFIS |
Joe,
What do I connect to the EFIS?
-- Art Z.
On Mon, Mar 12, 2018 at 7:59 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Connect a pull-up resistor, perhaps 1K Ω or more, between a positive source and the Dynon alarm wire. |
Posted: Mon Mar 12, 2018 7:11 am Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS |
A picture is worth a thousand words.
81.66 KB |
12563 Time(s) |
Posted: Mon Mar 12, 2018 8:13 am Post subject: Dynon Pitot Heat Warning with MGL EFIS |
Joe,
Got it. That'll work. Thank you.
-- Art Z.
On Mon, Mar 12, 2018 at 10:11 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
A picture is worth a thousand words. |
Posted: Mon Mar 12, 2018 12:46 pm Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS |
I would try it without the pull-up resistor first. It might not be needed.
BARRY CHECK 6
Posted: Mon Mar 12, 2018 2:02 pm Post subject: Dynon Pitot Heat Warning with MGL EFIS |
How would you do that if the reference is ground?
On Monday, March 12, 2018, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=478626#478626
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
lank">http://wiki.matronics.com
Barry
"Chop'd Liver"
If you wash your hands before you go to the bathroom you may have the makings of a Crew Chief.
