The Firefly is painted
Richard Pike
PostPosted: Sat Mar 10, 2018 3:17 pm    Post subject: The Firefly is painted Reply with quote
Finished painting the Firefly today, put it together, and was hoping to fly it, but then the front started moving in, the wind came up, and having to land with a stiff tailwind seemed like not a good idea. So we took some pictures and put it away. All we have left to do is add the VG's, and some home made strobes that ought to weigh less than 5 ounces. (I'll do a separate post on that after it is done) Best of all, we are still within legal specs for Part 103 - WOOT! Here are the pictures.
 Filesize:  293.76 KB
 Viewed:  10117 Time(s)
 Filesize:  265.6 KB
 Filesize:  287.25 KB
 Filesize:  272.57 KB
 Filesize:  235.09 KB
 Filesize:  160.11 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Sat Mar 10, 2018 3:29 pm    Post subject: The Firefly is painted Reply with quote
Not easy to come under the weight limit. I could never accomplish that.
Richard Pike
PostPosted: Sat Mar 10, 2018 5:04 pm    Post subject: Re: The Firefly is painted Reply with quote
Titus, Alabama--
You are right; it was not easy. That is why we sold the 447 and replaced it with a 277 free air. The 447 weighed 59.1 pounds, the 277; 42.5 pounds. Not having the fan or cooling shroud on the 277 saved a bit more, but not sure how much. We are also using a hand deployed parachute and counting the weight that the FAA allows for that. Since the chute and hardware only weighs 9 pounds and you are allowed to count 24, that gives us another 15 pounds to subtract from the actual weight. Something that is not helping is that we are still using the original wing fabric and paint, plus our repaint. If we stripped the wings and recovered it with Oratex, we could probably make weight w/o having to count the parachute. But right now, we don't care.
Richard Pike
Kingsport, TN 3TN0
japowell
PostPosted: Sat Mar 10, 2018 5:46 pm    Post subject: Re: The Firefly is painted Reply with quote
Looking good Richard. Weight is hard to shed easily. Mine still weighs in at about the same weight as when Vince had it. Haven't been able to get anything done on mine since first of the year. I fell on the ice the last of Jan and broke my left ankle. Hopefully spring will be better.
Jim P
WAR EAGLE
lambdinwilliam(at)gmail.c
PostPosted: Sun Mar 11, 2018 4:04 am    Post subject: The Firefly is painted Reply with quote
Really nice job, Richard! And made the 103 weight too!
Enjoy,
Lanny
On Mar 10, 2018, at 6:17 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=478562#478562
http://forums.matronics.com//files/p1060591_medium_275.jpg
http://forums.matronics.com//files/p1060589_medium_161.jpg
http://forums.matronics.com//files/p1060584_medium_153.jpg
http://forums.matronics.com//files/p1060596_medium_207.jpg
http://forums.matronics.com//files/p1060594_medium_241.jpg
http://forums.matronics.com//files/p1060598_medium_544.jpg
rmaccrone(at)att.net
PostPosted: Sun Mar 11, 2018 8:13 am    Post subject: The Firefly is painted Reply with quote
Beautiful airplane!!! I sure enjoy reading about how you kept the weight
down. Outstanding job!!!
lcottrell
PostPosted: Sun Mar 11, 2018 8:25 am    Post subject: The Firefly is painted Reply with quote
Its obvious that the Rev likes blue. I do as well. It looks really good. I do have a question about the silencer. I was wondering the reasoning behind installing it vertically rather than horizontal. Clearance perhaps. It looks better on your plane than it ever did on my shelf, what ever the configurationLarry.
On Sun, Mar 11, 2018 at 10:12 AM, Rick MacCrone <rmaccrone(at)att.net (rmaccrone(at)att.net)> wrote:
[quote]--> Kolb-List message posted by: "Rick MacCrone" <rmaccrone(at)att.net (rmaccrone(at)att.net)>
Richard Pike
PostPosted: Sun Mar 11, 2018 10:40 am    Post subject: Re: The Firefly is painted Reply with quote
lcottrell wrote:
Its obvious that the Rev likes blue. I do as well. It looks really good. I do have a question about the silencer. I was wondering the reasoning behind installing it vertically rather than horizontal. Clearance perhaps. It looks better on your plane than it ever did on my shelf, what ever the configuration.
Larry.
It is because the 277 lacks sufficient mounting points to tie the silencer in place at the mag end, so the silencer had to end up with all it's mounting points as close as possible to the PTO end.
Picture the silencer in different locations, then look at the engine and the potential silencer mounting points, and there are not many options. Probably could have mounted it down/horizontal with the air filter at the mag end and made it work, but we took the path of least resistance. (Also known as not having to work across the top of the wing while fabricating parts) (I'm not getting any younger/more flexible)
 Filesize:  205.13 KB
 Viewed:  9905 Time(s)
 Filesize:  150.71 KB
Richard Pike
Kingsport, TN 3TN0
