Jay Hodge
Posted: Sat Mar 10, 2018 6:12 am Post subject: Sukhoi iris |
Hey Guys,
I have a Yak 55M that does not have an iris or shutters installed. I found an iris from a Suk, and would like to install that. Anybody done this before? Any problems I should know about?
Jay
Vic
Joined: 12 Aug 2008 Posts: 117 Location: Southern Bavaria
Posted: Sat Mar 10, 2018 6:03 pm Post subject: Re: Sukhoi iris |
I have replaced the Yak shutters on the 18 T with a Sukhoi iris for easy access and better view of the engine. Expect to be faced with a LOT of friction in the actuating linkages and lever. I do not know how the system works on a Sukhoi but anyway we fitted a longer lever and bigger knob in the cockpit for that reason so be prepared for some troubles.
Vic
765 KB |
7297 Time(s) |
Jay Hodge
Posted: Mon Mar 12, 2018 1:11 am Post subject: Re: Sukhoi iris |
Vic
Thanks for the reply. Other than the friction problem, everything sort of fits right up?
Jay
Vic
Posted: Mon Mar 12, 2018 4:49 am Post subject: Re: Sukhoi iris |
Hi Jay,
to be open, there are a few bits you have to work out from your side: Seems I did two new brackets to mount the iris to the engine, plus a new lever, see photo. I believe my shutters came from a Sukhoi but don“t know why there is a difference, variations of M 14 gearbox castings ?
Then you will design an extra mechanism for actuating the iris. The high friction prevented using the original push-pull cable in the 18 T, so I made up a twin pull bowden system with two cables and torque rod from fire wall to the iris, sorry, no photos at hand. Does anybody know how the system looks in a Sukhoi ? Maybe you will come up with something else, depending on conditions in your aircraft. At least you got the warning to know where problems might be and fabricate a good system from the start. I tried hydraulics first, but that was not quick and easy and had snags in detail as well.
Vic
573.01 KB |
7262 Time(s) |
552.02 KB |
7262 Time(s) |
