rv10free2fly(at)yahoo.com Guest
Posted: Fri Jan 26, 2018 4:12 pm Post subject: SureFly Electronic Ignition |
Has anyone installed the SureFly electronic ignition system on their RV-10?
Warm regards
Patrick
Nick Leonard
Joined: 18 Jun 2007 Posts: 35 Location: Sacramento, CA
Posted: Sat Jan 27, 2018 4:57 am Post subject: Re: SureFly Electronic Ignition |
Yes, good results and superior support.
_________________ Nick Leonard
RV-10 (40015) Flying |
dmasys
Posted: Sun Jan 28, 2018 11:16 am Post subject: SureFly Electronic Ignition |
Second that. Have about 100 hrs. on the Surefly replacing the right mag. I removed the jumper on ignition switch that grounds the right mag at startup, so both the left mag with SlickStart and the right Surefly unit are firing at TDC during cranking. Totally solved my decade-long hot start problem on the IO-540. CHTs have been normal in all phases of flight, and the bird is about 2 kts faster in cruise. Effect most noticeable when running above 9K density altitude with MP settings below 22". Good stuff.
-Dan Masys
N104LD 1100 hrs.
| Quote: | Time: 04:57:53 AM PST US
Subject: Re: SureFly Electronic Ignition
Nick Leonard
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Mon Feb 19, 2018 7:00 am Post subject: Re: SureFly Electronic Ignition |
I have over 180 hours on the SureFly electronic ignitions and they have performed well. So well, I installed 2. (I have 2 independent electrical systems with 2 alternators and 2 batteries.)
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
Posted: Mon Feb 19, 2018 7:11 pm Post subject: SureFly Electronic Ignition |
Any pictures of the ignition system installations please Dave?
Warm regards
Patrick
| Quote: | On 20 Feb 2018, at 01:30, nukeflyboy <flymoore(at)charter.net> wrote:
Dave Moore
RV-6 built and sold
http://forums.matronics.com/viewtopic.php?p=478109#478109
nukeflyboy
Posted: Wed Feb 21, 2018 6:00 am Post subject: Re: SureFly Electronic Ignition |
Sorry, no photos. The installation is easy. Swap your mag for the unit and add a power source. Used same harness as the mag. Can use fine wire Tempest plugs or keep the heavy ones.
RV-6 built and sold
