diode on starter contactor
Goto page Previous  1, 2
Eric M. Jones
PostPosted: Thu Jan 18, 2018 1:40 pm    Post subject: diode on starter contactor Reply with quote
This subject has been discussed here for years.
My opinion and what I have suggested for years is that the current best
practice is to use bidirectional zener diodes. Regular diodes are
problematic. See attached.
You can use what I suggest or slightly heavier ones for better
mechanical properties. (I am currently shipping the 5KE20CA parts).
Eric M. Jones
-Bought a 177RG Cardinal.
SnapJacks.pdf
 Filename:  SnapJacks.pdf
 Filesize:  82.17 KB
 Downloaded:  666 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
alec(at)alecmyers.com
PostPosted: Thu Jan 18, 2018 1:56 pm    Post subject: diode on starter contactor Reply with quote
Eric,
I see great marketing (FUD) in that document but no actual information.
What do you believe to be the problem with a regular diode?
My opinion and what I have suggested for years is that the current best practice is to use bidirectional zener diodes. Regular diodes are problematic. See attached.
You can use what I suggest or slightly heavier ones for better mechanical properties. (I am currently shipping the 5KE20CA parts).
Eric M. Jones
<SnapJacks.pdf>
kenryan
Eric, is it okay to solder a wire to your snapjacks?
On Thu, Jan 18, 2018 at 12:38 PM, Eric Jones <emjones(at)charter.net (emjones(at)charter.net)> wrote:
Eric M. Jones
PostPosted: Thu Jan 18, 2018 2:01 pm    Post subject: diode on starter contactor Reply with quote
[img]cid:7.1.0.9.0.20180118155821.0661d178(at)aeroelectric.com.0[/img]
Can you demonstrate this? "Excessive" is non-quantified.
Was my bench top study flawed in some way?
 Filesize:  59.17 KB
 Viewed:  18315 Time(s)
PostPosted: Thu Jan 18, 2018 2:39 pm    Post subject: diode on starter contactor Reply with quote
I’m trying to work out why a diode has *any* significant effect on release time compared to a tranzorb or similar, and if it did, why you might care.
Also, why should it have any effect on relay life reduction …?
My skeptical self needs help to get beyond merely “more expensive therefore must be better”.
On Jan 18, 2018, at 5:01 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
<f1b501.jpg>
PostPosted: Thu Jan 18, 2018 4:50 pm    Post subject: Re: diode on starter contactor Reply with quote
A capacitor opposes any change in voltage.
An inductor (coil) opposes any change in current.
When the switch is closed (Figure 1), positive
current flows from left to right through the coil.
The diode does not conduct because positive
current can not flow against the arrow.
_
When the switch is opened (Figure 2), the
coil opposes any change and tries to
maintain the current. The coil is no longer a load.
The coil is now a source, like a battery.
Induced current still flows in the same direction
through the coil from left to right.
But the polarity has changed because
because the coil is now a source, not a load.
The diode now conducts because positive on
the right side flows with the arrow. Current
always tries to return to the source, the coil in
this case. It takes the path of least resistance,
which is through the diode, not across the open
switch contacts. The induced voltage is limited
to the forward voltage drop across the diode.
 Filesize:  68.61 KB
 Viewed:  18301 Time(s)
Joe Gores
cluros(at)gmail.com
PostPosted: Thu Jan 18, 2018 5:09 pm    Post subject: diode on starter contactor Reply with quote
Last year I put a lighter AGM battery in my aircraft and moved it to the
firewall along with the master contactor and made some new diodes for the
contactors (one was broken). Saved about 4 pounds in wiring alone! Only
problem afterwards was that if the battery was even slightly down sometimes
the starter would turn a split second and then nothing. Repeated attempts
usually ended up with the starter eventually running fine until the engine
started. Putting a voltmeter on the starter confirmed that the problem was
a lack of power to the starter, not the starter itself. I had a battery
problem later on and replaced the battery, no change. Thinking I had messed
up the starter contactor while tightening nuts on it I swapped it out, no
change. At this point I started to suspect my diode so I disconnected it:
Problem gone! I suspect I installed it backwards. Going to make the new one
with clear shrinkwrap tubing so it can't happen again.
PostPosted: Fri Jan 19, 2018 8:00 am    Post subject: diode on starter contactor Reply with quote
At 04:37 PM 1/18/2018, you wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com>
When mechanical contacts are opened, an electric
arc forms in the air gap. With low voltages and
currents, the fire may be small, but it is never
zero. In one of my articles, I mentioned and experiment
when a microswitch was biased up with a dry cell
and resistor. The contacts were observed
through a microscope in the dark (the side was opened
up on the switch for the experiment).
Even at these very low power levels, a BLUE arc
could be observed. The temperature of blue is
HOT. This suggests that no matter what the power
level, every opening even will transfer molecules
of metal between contacts.
Again, not a lot of metal but never zero.
As energy levels go up and particularly
at higher voltages, the intensity and DURATION
of the arcing event increases. This is an expected
condition. Relays are designed to meet life cycle
ratings at specific power levels and circuit
characteristics by adjusting contact material,
closing forces, opening velocities, opening
gaps, etc. Conditions are important . . . switches
and relays will have AC, DC and LAMP ratings
applied to their service life limits.
https://goo.gl/CPtPYJ
If you've ever tried to do any stick-welding, you
understand the need for (1) making initial cold
contact, (2) breaking that contact to form an
arc, then maintaining an optimum distance between
rod and work-piece to achieve a SUSTAINED fire
at a temperature conducive to the TRANSFER
of metal from rod to work-piece.
If the contacts of a switch or relay do not spread
fast enough, wide enough and with sufficient
thermal mass in contacts, then the TRANSFER of
metal will exceed that which meets design goals
for service life.
This lays the groundwork for a notion that relay
contacts will accelerate open at some rate which is
a function of spring, mass and decay of the
magnetic field which was originally applied to
close the contacts.
It's easily demonstrated that rate of decay for
this magnetic field is strongly influenced by
the choice of suppression for energy stored in
the coil at the time it is de-energized.
A totally open-circuit coil is the fastest, but
transient voltage during field collapse is greatest.
You can drive a coil with a current limited source
and the throw a dead short across the coil, reducing
its excitation current to zero thus initiating
the contact opening sequence. In this condition,
the field collapse transient voltage will be zero
and time to decay will be a whole lot longer.
Hence, there is a range of decay rates offered by
the array of suppression techniques.
I've have yet to discover a paper that describes
the behavior of relay magnetic holding force
in detail . . . many papers that jump to an
'obvious' conclusion that if decay rate in
the coil is extended by factors of 10 or more,
then opening velocity of the contacts is similarly
depressed.
What I observed (in 45 years of herding electrons
in airplanes and conducting numerous relay and
switch failure studies) is that as a relay closes,
the CONTACTS CLOSE before the magnetic armature
BOTTOMS OUT. There is a spring rate associated
with this extra motion that sets the contact
closed holding force.
This leads us to the idea that as the magnetic
field in the device decays, there is a period
of time from first motion the of armature off
the bottomed-out position until closing force
on the contacts drops to zero and they begin
to move. This means that there is a GROWING
AIR GAP in the magnetic circuit holding the
contacts closed.
This air gap has a profound suppressing effect
on that magnetic force. It's an effect that
grossly over-rides the decay rate of the magnetic
from the coil.
Magnetic decay rate does indeed affect drop-out
time for the relay . . . this was demonstrated in
the data collected during my bench-top experiments.
Decay rate adds a time delay between de-energizing
of the coil and first opening of the contacts.
However, by the time the contacts see first motion,
the magnetic air gap is established and growing.
The air gap has much more control over contact
acceleration than does coil current. Hence, the
duration of arc between spreading contacts showed
only a slight difference between diode-suppressed
and non-suppressed contactor.
The case for 'supper suppressors' is further
weakened by the fact that starter and battery
contactors on our airplanes are considered very
busy if they get a few operations per week.
The average light aircraft flies 50 hours
a year. If you install switches and relay rated
for tens of thousands of operations, it stands to
reason that benefits gained by going-the-extra-mile
on coil suppression yields no measurable benefit.
Then, there is the study of contact erosion during
closure as influenced by the physics of the switched
circuit. This is due to arcing that occurs during
contact BOUNCE. Many closures and openings per
operation . . . much smaller gap during the bounce . . .
but exceedingly unfriendly to relay life under
some conditions.
But that's a totally different story . . .
PostPosted: Fri Jan 19, 2018 8:08 am    Post subject: diode on starter contactor Reply with quote
At 07:09 PM 1/18/2018, you wrote:
Last year I put a lighter AGM battery in my aircraft and moved it to the firewall along with the master contactor and made some new diodes for the contactors (one was broken). Saved about 4 pounds in wiring alone! Only problem afterwards was that if the battery was even slightly down sometimes the starter would turn a split second and then nothing. Repeated attempts usually ended up with the starter eventually running fine until the engine started. Putting a voltmeter on the starter confirmed that the problem was a lack of power to the starter, not the starter itself. I had a battery problem later on and replaced the battery, no change. Thinking I had messed up the starter contactor while tightening nuts on it I swapped it out, no change. At this point I started to suspect my diode so I disconnected it: Problem gone! I suspect I installed it backwards. Going to make the new one with clear shrinkwrap tubing so it can't happen again.
If your diode is installed backwards, it will conduct
HARD while the starter button is depressed. Plastic
diodes generally smoke for a few seconds and split,
some will literally explode. I've seen a few cases
where they simply fused short and tripped the starter
control circuit breaker.
If removing the diode cured your problem, then it
probably was 'backwards'. Do you have a breaker
or fuse on your starter control line? That shorted condition
should have opened the circuit protection.
kenryan
PostPosted: Fri Jan 19, 2018 8:45 am    Post subject: diode on starter contactor Reply with quote
I'm confused. It seems like you are now saying that because the relays are rated for far more cycles than they will ever see, there is no reason to bother with diodes.
Sent from my Android. Sorry Steve.
On Jan 19, 2018 7:06 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
My skeptical self needs help to get beyond merely “more expensive therefore must be better†.
  for service life.
  close the contacts.
  depressed.
  contacts closed.
  from the coil.
  some conditions.
bob.verwey(at)gmail.com
PostPosted: Fri Jan 19, 2018 8:57 am    Post subject: diode on starter contactor Reply with quote
Does the risk not lie in having contacts that weld together or overheat?
On 19 Jan 2018 6:49 PM, "Ken Ryan" <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
  for service life.
  close the contacts.
  depressed.
  contacts closed.
  from the coil.
  some conditions.
yellowduckduo(at)gmail.co
PostPosted: Fri Jan 19, 2018 9:14 am    Post subject: diode on starter contactor Reply with quote
For all intents and purposes the diode ONLY protects the switch that
controls the relay.
So it does improve system reliability.
Ken
ceengland7(at)gmail.com
PostPosted: Fri Jan 19, 2018 9:22 am    Post subject: diode on starter contactor Reply with quote
I think y'all are a bit confused on what the diodes actually do. The diode across the relay coil is there to protect the controlling *switch's* low current contacts; not the relay contacts. Now, since TANSTAFL (there's no such thing as a free lunch), the  downside (of questionable significance) to the diode being in the circuit is that it *can* slow the collapse of the magnetic field in the relay, leading some to think (evidenced by the link to back-to-back zeners) that it puts the *relay* contacts at more risk.
Not to speak for Bob, but his latest post(s) address that  slowing of the magnetic field collapse (of questionable significance), and tell us that his testing has shown that with most relays, the contacts don't actually start to separate until after that slowed magnetic field decay isn't having any influence.
So....The bottom line is that the diode *is* needed to protect *switch* contacts, and its presence has *minimal to zero* real world impact on the *relay's* contacts. The takeaway is that you do need the diode, and nothing more elaborate than a standard diode is needed.
Those of us who made our living playing with these components have an easy time seeing what he's describing. It might serve you well to visit some appliance/electrical repair facility & talk them out of a couple of open frame relays so you can play with them & see what he's describing.
  for service life.
  close the contacts.
  depressed.
  contacts closed.
  from the coil.
  some conditions.
Eric M. Jones
PostPosted: Fri Jan 19, 2018 9:42 am    Post subject: diode on starter contactor Reply with quote
I am reluctant to get into another long discussion on the subject of
coil suppression but I encourage Googling the various extensive
resources on this subject.
Note that there are many techniques tuned to specific application on
this subject, but three things are true:
1) The use of a simple diode is contraindicated.
2) The use of a simple bidirectional zener is a good way to go.
3) MOVs are a good way to go, but they have a discrete lifetime...I was
never comfortable with that. MOVs are usually what fails in
surge-suppression computer multi-outlets.
One COULD use a zener and a regular diode in series, but a bidirectional
zener is polarity insensitive and stone simple.
Kilovac and Gigavac both use bidirectional zeners inside their
contactors for coil supression. What does these people know that you don't?
Eric
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
kenryan
PostPosted: Fri Jan 19, 2018 10:03 am    Post subject: diode on starter contactor Reply with quote
Thanks Charlie. That does clear things up for me as to what Bob was saying.
I am no longer confused (temporary condition I am sure).
On Jan 19, 2018 8:26 AM, "Charlie England" <ceengland7(at)gmail.com> wrote:
[quote] I think y'all are a bit confused on what the diodes actually do. The diode
any influence.
>> might care.
>> for service life.
>> close the contacts.
>> depressed.
>> contacts closed.
>> from the coil.
>> some conditions.
>> Bob . . .
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> Virus-free
PostPosted: Fri Jan 19, 2018 10:32 am    Post subject: diode on starter contactor Reply with quote
No . . . .
I am saying that 'optimized' coil spike suppression
has a perhaps a tiny benefit for contactors in
heavy usage applications and no benefit in our
airplanes (very low duty).
Spike suppression is (and always has been) indicated
for enhancing LIFE OF THE DEVICE THAT CONTROLS
the contactor. E.g. AD against key-switch. The
plain-vanilla diodes have been installed on TC aircraft
for decades. See item 29 in screenshot of 1969
C172 service manual. Couldn't put my hands on my
copy of the Beechjet manual . . . but the little
critters are sprinkled about that airplane as well.
[img]cid:.0[/img]
The diode has (1) no practical effect on service life
of contactor and (2) demonstrable benefit on service life
of the controlling switch . . .
 Filesize:  77.81 KB
 Viewed:  18283 Time(s)
PostPosted: Fri Jan 19, 2018 10:43 am    Post subject: diode on starter contactor Reply with quote
Contacts 'weld' on closure. The risk of welding
begins with deformation of contact surfaces due
to combinations of age and service conditions (extra
ordinary inrush current), low energizing current.
Contact welding can also be a function of unanticipated
behaviors due to aircraft wiring. See this study on
'sticking' roll trim relays on the Beechjet:
https://goo.gl/QcfSYo
Spike suppression on the at-risk relay/contactor
has no effect on conditions that promote contact
sticking/welding.
'Overheating' contacts are either too small for
the service or so badly worn as to degrade
conductivity across the contacts.
https://goo.gl/1BJP7y
Note that this victim of severe overheat still
carries remains of its coil suppression diode.
This contactor was used to control power to a
3 horsepower, 28v motor used in the air conditioning
system of a King Air. The diode was there . . .
but the contactor simply got 'tired'.
PostPosted: Fri Jan 19, 2018 10:53 am    Post subject: diode on starter contactor Reply with quote
Kilovac and Gigavac both use bidirectional zeners inside their contactors for coil supression. What does these people know that you don't?
Not a thing I can see . . . the bidirectional zener
performs as advertised. No reason to avoid it or to change
it out in favor of an alternative.
By the same token, there's no demonstrable benefit
for any extra effort to steer clear of
the lowly diode that has also performed as advertised
in literally billions of applications for a
very long time.
My complaint is with publications that make
sweeping assertions that are demonstrably
short on physical evidence or experimental
confirmation.
cluros(at)gmail.com
PostPosted: Fri Jan 19, 2018 7:13 pm    Post subject: diode on starter contactor Reply with quote
I was wondering the same thing Bob so I had a look, no fuse or breaker in that line. I guess the builder thought it didn't need one since it connects to ground 8(. I think I should install an inline fuse?
Thank you,
Sebastien
On Fri, Jan 19, 2018 at 8:07 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
PostPosted: Sat Jan 20, 2018 6:50 am    Post subject: diode on starter contactor Reply with quote
Not sure which 'same thing' you're citing . . .
Fuse in which line, bust thru starter button to starer contactor
or battery to starter contactor?
The CONTROL line from bus to starter switch is
classically protected. No protection is indicated
for the cranking current feeder from battery to
starter contactor.
Suggest you browse the various power distribution
diagrams (Z-figures) at https://goo.gl/kovZJX
While these cover a broad range of applications,
there are features common to all of them that
illustrate both legacy and modern but field
proven techniques for architecture.
Page 2 of 2
