Super-cool oil temp
Goto page 1, 2  Next
apatton2
PostPosted: Wed Jan 17, 2018 10:44 am    Post subject: Super-cool oil temp Reply with quote
Hi All,
I recently acquired a Yak-50 from the UK (the former G-JYAK). I continue to work on getting it into tune (have replaced the carburetor and mags with overhauled units).
When warm it runs very smoothly and well, developing at least book power (>=8.85 potatoes MP on takeoff). Engine is the stock M14P... only mods are the auto ignition harness and an intake drain kit.
However, the oil temp takes a very long time to come up to 40degC on start. Overnight temps in my area (NorCal) get as cold as 5degC but are generally warmer. However, upon pulling the airplane out of the hangar and starting it, oil temp reads zero C, and will take 20min to get to 40 degC. In fact, after as much at 5min after engine start, the oil temp indicator still indicates 0degC.
This isn't great as I believe that the prolonged run at low power begins to foul plugs. When it's warmed up and motoring at 82% / 7 potatoes in high-power cruise, oil temp needle tends to "stand straight up" at 70-80deg C.
I'm wondering about 2 potential causes:
1. Is there a variable problem with the indicator? I.e. inaccurate at low power settings/low temps but fine at higher power settings.
2. Could there be some abnormal oil circulation, especially at low power settings, that is allowing cold oil to stagnate around the temp probe for awhile, even after startup.
Every other indication, as far as I can tell, is normal. CHT temps will come up to ~ 75-100degC while waiting for the oil temp to come up.
Any thoughts would be greatly appreciated.
Thanks!
Andrew
Andrew Patton
Yak-50
San Francisco, CA
bmsim
PostPosted: Wed Jan 17, 2018 10:58 am    Post subject: Re: Super-cool oil temp Reply with quote
I'm not an expert, but there's a lot of oil to bring up to temp from those low temps. I don't have to deal with temps quite that low, but I bought an oil heater and a small bathroom heater to help. I turn the heaters on the night before I plan to fly, and oil is much closer to temp when I get ready. I wired the oil heater to a switched female plug that accepts a computer power cord (stays with the Yak), so I just leave the Yak plugged in and switch the heater on and off at the plugin.
For the air heater, I found a small 250 watt heater at a department store (walmart) for $10. It is not much bigger than a brick and with slide in/out of the cowl without opening anything up. It is a bit underpowered, but does significantly raise the temp inside the cowl.
Not a direct answer to your post, but I just wanted to provide some thoughts on heating.
Ernie
PostPosted: Wed Jan 17, 2018 11:04 am    Post subject: Super-cool oil temp Reply with quote
Close the gills.
On Wed, Jan 17, 2018 at 8:47 PM apatton2 <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)> wrote:
--> Yak-List message posted by: "apatton2" <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)>
Hi All,
Thanks!
Andrew
Andrew Patton
Yak-50
http://forums.matronics.com/viewtopic.php?p=477374#477374
richard.goode(at)russiana
PostPosted: Wed Jan 17, 2018 8:01 pm    Post subject: Super-cool oil temp Reply with quote
Hello Andrew,
A number of the oil coolers have a thermostatic bypass, and I suspect yours
is remaining fully open so the entire oil system has to be warmed up before
you start getting an indication on the gauge, which will take far longer.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
 Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel:   +44 (0) 1544 340120
Fax:  +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
apatton2
PostPosted: Wed Jan 17, 2018 8:37 pm    Post subject: Re: Super-cool oil temp Reply with quote
Re: "close the gills" - everything is closed (always is on warmup... I have several hundred hours in 50s and 52s).
Hi Richard - thanks for the note! My last -50 (a 1982 model with series 1 engine) came up to temp very rapidly and would seem to almost always stay cool.
I was wondering if there was any thermostatic regulation function in the oil system other than the manually actuated oil cooler door. Since I haven't seen anything that looked like a bypass valve for the oil cooler, I assumed that wasn't the case (I could be missing it, though). That said, I didn't think it would actually be built into the cooler itself!
I'll look again at some of the translated documents that I have to see if any light can be shed on this. But if that's the case and this valve is "stuck" open, then that would explain the observed phenomena.
Best,
Andrew
Andrew Patton
Yak-50
San Francisco, CA
cjpilot710(at)aol.com
PostPosted: Wed Jan 17, 2018 9:44 pm    Post subject: Super-cool oil temp Reply with quote
You might also put a restrictor plate on the oil cooler intake.
Jim "Pappy" Goolsby
PostPosted: Wed Jan 17, 2018 10:19 pm    Post subject: Super-cool oil temp Reply with quote
Hello Andrew,
I'm in Sri Lanka and therefore don't have access to all my technical papers
in the UK. But I am pretty sure that all or some of the oil coolers have a
thermostatic bypass valve, and until this opens, no oil goes through the oil
cooler. I suspect yours is sticking, and therefore the oil is continuing to
circulate through the oil cooler, and that is your problem.
I will investigate this more and that you know options, but I suspect we
could obtain a new valve.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
apatton2
PostPosted: Thu Jan 18, 2018 2:56 pm    Post subject: Re: Super-cool oil temp Reply with quote
Doing some additional detective work... seems like replacing the "thermo-valve" was one of the very first service bulletins. But the details of this are lost to me (and don't affect my s/n).
Any chance the original SB exists somewhere (and might even be in English Smile )?
 Filesize:  35.65 KB
 Viewed:  23344 Time(s)
Andrew Patton
Yak-50
San Francisco, CA
mark.bitterlich(at)navy.m
PostPosted: Fri Jan 19, 2018 10:08 am    Post subject: Super-cool oil temp Reply with quote
Richard, I happen to have some knowledge on this topic.
Very early YAK-50's came with what guys in this country call a "Veritherm", but in truth is nothing but a thermostat. This device, when the engine was cool, by-passed the oil cooler and warmed the oil up faster of course. It is not binary... meaning just open or closed. It regulates temperature and will actually maintain oil temp where it is supposed to be, usually even with the oil cooler door wide open.
At some point of time, there was a Russian directive, which I am sure you can find, that REMOVED these devices from the oil cooler. The Russian logbooks for my 1985 YAK-50 show this as being done. The result was that my oil cooler did not have the thermostat installed at all, and it took a very long time to warm up the oil in cold weather, just as this person is experiencing. The thermostat itself is set to by-pass the oil cooler, and when it starts seeing warm oil, it then runs the oil THROUGH the oil cooler. If it fails, it usually fails in the by-pass condition, which is... I think... why the Russians removed it. It is failed in that position, it will cook the oil and possibly ruin the engine. In any case, my oil cooler thermostat had been removed and so noted.
I obtained one of these thermostats/veritherms out of a Russian oil cooler for an M-14 helicopter and put it back into my YAK-50 oil cooler (easy job really) where it now operates perfectly. I wrote all this up about a decade ago on the YAK list.
My guess is that he does not have a stuck thermostat, but that instead he has not got one installed at all.
Mark
apatton2
PostPosted: Fri Jan 19, 2018 10:22 am    Post subject: Re: Super-cool oil temp Reply with quote
Hi Mark,
Many thanks for your note. I will correspond with former owner and see if he can tell me anything about typical oil warmup time.
In the meantime, could you point me to any places to check for a thermostat as you suggest? Have written to Avioservice in BG as they have been a good resource for hard to find parts previously, but I've not yet heard back.
Many thanks!
Andrew
Andrew Patton
Yak-50
San Francisco, CA
PostPosted: Fri Jan 19, 2018 11:09 am    Post subject: Super-cool oil temp Reply with quote
Andrew, it has been 10 years ... so my memory is not picture perfect. But I do think you would have to remove the oil cooler to know for sure. As I recall it screws into a hole, and we had to remove a screw in cover, and replace it with the thermostat part. I am at work and do not have access to my manuals which MIGHT show it. I'm afraid that is the best I can do. The person who would know for sure would be Vladimir Yastremski. He is up the street from you in Ramona CA. Or down the street? Whatever.
Mark
wlannon(at)shaw.ca
PostPosted: Fri Jan 19, 2018 11:11 am    Post subject: Super-cool oil temp Reply with quote
Mark;
The same problem was addressed in the Canadian production of the North
American Harvard (predecessor of the T6) to accommodate very cold winter
operation.
A different method was used consisting of what they called a "surge valve"
in the oil out line that opened whenever the scavenge pump pressure reached
83 psi.
and directed oil to the tank rather than the oil cooler.
Scavenge pump pressure is not regulated so temperature is a major factor in
oil out viscosity. I suspect a thermostatic device would be more efficient
but also far more subject to failure.
Walt
apatton2
PostPosted: Fri Jan 19, 2018 7:16 pm    Post subject: Re: Super-cool oil temp Reply with quote
Thanks much, Mark and co, for the further help. I got a picture of the thermovalve today (at least I'm pretty sure this is it).
 Filesize:  765.45 KB
 Viewed:  23292 Time(s)
Andrew Patton
Yak-50
San Francisco, CA
Rob Rowe
PostPosted: Sat Jan 20, 2018 3:11 am    Post subject: Re: Super-cool oil temp Reply with quote
Hi Andrew,
Like Mark I also fitted the original 'thermo(stat)-(safety)valve' back into my -52 in 2010 and it's reduced the engine warm-up time and more importantly got the oil temps into the green to boil off any corrosive moisture (mine's a cool engine in-flight).
I've attached an image of the two units with the thermo-valve (left) and pressure valve on the right.
Sourced the thermo-valve from a one-off surplus Mi-8 helicopter hydraulic inter-cooler in the UK (sometimes used for competition aircraft oil coolers). Given they made 17,000+ Mi-8s you would hope someone somewhere might have spares, but they seem to be like hen's teeth :-(
To follow on from Mark's thoughts ... the very cold weather SOP is to blow ducted hot air into the engine and oil cooler (see other image).
However this causes the original fit cooler thermo-valve to open about 7mm max (it's just a simple expanding paraffin wax device with an over-pressure relief spring at the base) allowing oil through the cooler matrix.
Trouble is the upstream large oil pipes feeding the cooler are still full of unheated congealed (Russian) oil ... that then gets fed into the cooler matrix on engine start with the potential to rupture it.
Now the over-pressure spring in the base is supposed to take care of this and my conjecture is that the limited travel and force required in practice was not always enough to protect the cooler matrix in time.
This is from having compared the operation of the thermo-valve versus the (field replacement) pressure relief valve and the latter takes less effort to operate (simply based on pushing down hard on both with my hand).
Presumably this is not an issue for Mi-8 helicopter cooler usage as the viscosity of cold hydraulic oil is less than aircraft engine oils.
FWIW - I've experienced no issues using the thermo-valve on my -52 over the last 7 years using western oils, albeit in less extreme temperatures (UK is relatively mild). YMMV.
Brgds, Rob R
YAK-52 being pre-heated
 Filesize:  1.29 MB
 Viewed:  23268 Time(s)
Thermo-Valve (left) & Pressure Valve (right)
 Filesize:  794.02 KB
apatton2
PostPosted: Sat Jan 20, 2018 9:26 am    Post subject: Re: Super-cool oil temp Reply with quote
Hi Mark,
Wow. Thanks for the pictures and the additional detail on the thermovalve. I'm still working on finding one. Our typical Northern California temps aren't that extreme, but agree that the thermovalve is a more ideal solution.
Very helpful to see the difference between the PRV and the thermovalve.
I'll keep looking.
Andrew
Andrew Patton
Yak-50
San Francisco, CA
apatton2
PostPosted: Sat Jan 20, 2018 9:33 am    Post subject: Re: Super-cool oil temp Reply with quote
Hi Mark - just a shot - do you have a part number for this valve?
Many thanks
Andrew
Andrew Patton
Yak-50
San Francisco, CA
PostPosted: Sun Jan 21, 2018 2:29 am    Post subject: Super-cool oil temp Reply with quote
Andrew - for my interest, what would you do with a part number if you had
one? I don't know of anyone in this little business who catalogues anything
by part numbers!
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
McFly
PostPosted: Sun Jan 21, 2018 7:08 am    Post subject: Super-cool oil temp Reply with quote
Doug Sapp does! Wink
Todd
[quote] On Jan 21, 2018, at 2:29 AM, Richard Goode <richard.goode(at)russianaeros.com> wrote:
by part numbers!
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Todd McCutchan
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Email: todd@fastaircraft.com
Skype: tmccutchan
Web: www.fastaircraft.com & www.flyams.com
apatton2
PostPosted: Sun Jan 21, 2018 8:30 am    Post subject: Re: Super-cool oil temp Reply with quote
Hi Richard - in the past it has helped to be able to google search things like this via p/n (especially if there were 20,000 made for Mi-17 helos). Worth a shot.
Best
Andrew
Andrew Patton
Yak-50
San Francisco, CA
dougsappllc(at)gmail.com
PostPosted: Sun Jan 21, 2018 10:15 am    Post subject: Super-cool oil temp Reply with quote
Richard,Amen Todd!!
When I had only 3-400 line items (and was 50 years old) I did it by part name too, but now with over 2,000 line items (and 71 years old)
names don't seem to do the job very well any more.
Doug
On Sun, Jan 21, 2018 at 2:29 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
[quote]--> Yak-List message posted by: "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
by part numbers!
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax: [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
Goto page 1, 2  Next
Page 1 of 2
