ralph.covington(at)hotmai Guest
Posted: Sat Dec 30, 2017 4:13 pm Post subject: Kolb-List Digest: 16 Msgs - 12/29/17 |
Pls delete from this list
Get Outlook for iOS
From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server(at)matronics.com> on behalf of Kolb-List Digest Server <kolb-list(at)matronics.com>
Sent: Friday, December 29, 2017 11:37:42 PM
To: Kolb-List Digest List
Subject: Kolb-List Digest: 16 Msgs - 12/29/17
Today's complete Kolb-List Digest can also be found in either of the
of the Kolb-List Digest and can be viewed with a generic text editor
HTML Version:
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fdigest%2Fdigestview.php%3FStyle%3D82701%26View%3Dhtml%26Chapter%3D2017-12-29%26Archive%3DKolb&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=pl8lPFIqgTjnjsqXxcYwOU6nBipgDjjW368j%2FFHeUPs%3D&reserved=0
Text Version:
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fdigest%2Fdigestview.php%3FStyle%3D82701%26View%3Dtxt%26Chapter%3D2017-12-29%26Archive%3DKolb&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=uSwPQtEz6FidZIL77Avg2%2FYm5x66Zw67jB7LzgblgOY%3D&reserved=0
Kolb-List Digest Archive
Total Messages Posted Fri 12/29/17: 16
Today's Message Index:
1. 12:06 AM - Re: Re: My Firestar Project Update (Bill Berle)
2. 12:48 AM - Flying Adventures of the Eager Beaver (JC Gilpin)
3. 04:14 AM - Re: Flying Adventures of the Eager Beaver (Lanny Lambdin)
4. 04:58 AM - Re: Flying Adventures of the Eager Beaver (George Helton)
5. 05:42 AM - Re: Flying Adventures of the Eager Beaver (John Hauck)
6. 07:01 AM - Re: Flying Adventures of the Eager Beaver (B Young)
7. 09:14 AM - Re: My Firestar Project Update (Denny Baber)
8. 09:41 AM - Re: My Firestar Project Update (Bill Berle)
9. 09:48 AM - Re: Flying Adventures of the Eager Beaver (Bill Berle)
10. 03:31 PM - best props (japowell)
11. 04:40 PM - Re: best props (japowell)
12. 05:23 PM - Re: Re: best props (Bill Berle)
13. 05:44 PM - Re: best props (George Helton)
14. 09:07 PM - Re: Re: best props (John Hauck)
15. 10:56 PM - Re: best props (Gerry in Va.)
16. 11:28 PM - Gap Seal...? (Nick Cassara)
Time: 12:06:26 AM PST US
Subject: Re: Re: My Firestar Project Update
Richard thank you for your observation and compliments. My work is nowhere near
the quality and finish of champion trophy airplane builders. 90% of what I am
doing is not for "show quality", but simply to remove as many failure points
and potential rubbing, chafing, scratching and abrasion between parts. I spent
a lot of time putting pieces of split rubber tubing over the steel frame tubes
where I want to attach something with a Ty-Rap (zip-tie), so nothing would
start eating into the steel tubes. Hours were spent on this kind of stuff while
I was building the fuel system. I used HDPE plastic tube everywhere I could
run the lines fairly straight, and used the blue urethane tube only where it needed
to make bends or flex a little. Lots of "EAA homebuilder standoff" assemblies
in the engine area. These are short lengths of tube with a zip-tie through
the tube and around something on either end,which basically prevents lines,
wires, tubes, etc. from "whipping" and waearing out prematurely. No rocket science
whatsoever, but it makes everything last longer.
The direct answer to your suggestion about joining the exhaust pipes behind the
main keel tube is that the HKS engine importer told me that the length of the
tubes should be 22-24 inches before they join together. That distance, while
not "critical" by any means, gives you the best "tuning" of the exhaust pulses
helping pull the exhaust gas out of the cylinders. I used this as a starting
point, knowing full well that to get the last percentage pof power form the engineyou'd
have to do a bunhc of testing and dyno work like race engine builders
do. I have no need for that, but I figured if the engine mfg. can give me a
basic deimension then I can at least roll the dice on that.
BTW today I finished most of the fuel system. I madeup webbing strap and buckle
assemblies to tie the fuel jugs down to the fuselage tube. I had glued a rubber
strip on the top of the fuselage tube in the fuel tank bay, so the furl jug
and aluminum tube would not start working on each other due to normal vibrations.
Then, after scratching my head for a while and thinking about what could
possibly wear, chafe, rub, or grind... I realized that the nylon webbin strap
was directly rubbing on the bottom of the fuselage tube, and eventually might
wear through something. So I took it apart and ran the webbing through two short
pieces of foam rubber tubing, and reinstalled everything with the foam rubber
tubing on the bottom, putting a layer of foam between the webbing and the bottom
of the fuselage tube. So now the webbing can't rub through the paing on
the fuselage tube, and the fuselage tube can't wear away any of the nylon webbing.
THEN, after more insane asylum paranoia, I realized that the plastic buckles that
I put on the webbing wereplenty strong enough for any negative G loads on the
fuel jugs... but the buckles were too easy to un-lock if someone brushed against
them at the wrong angle. So after more head scratching, I figured out a
way to use small zip ties as locking devices, preventing anyone from accidentally
(or intentionally) squeezing the buckles to un-lock the fuel tank retaining
straps.
I know that this is paranoid "certified airplane overkill" thinking, but I come
from the certified airplane world as much as I come from the experimental world.
So I take a LOT longer to be convinced somehting is safe.
Bill Berle
https://eur02.safelinks.protection.outlook.com/?url=www.ezflaphandle.com&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=Tynd0mJ6BqSbXkrmJpOiz1q%2BCbVbL7F8K3vkigHnBYU%3D&reserved=0 - safety & performance upgrade for light aircraft
https://eur02.safelinks.protection.outlook.com/?url=www.grantstar.net&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=sJ%2BfKsPMweVIWcHQQ9t0aFi5w73JyVVwgdMB0l7hei4%3D&reserved=0 - winning proposals for non-profit and for-profit entities
On Thu, 12/28/17, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Re: My Firestar Project Update
Date: Thursday, December 28, 2017, 8:58 PM
Pike" <thegreybaron(at)charter.net>
I hate to sound critical because I
always have to redo all my stuff 3 times before I can get it
to work right, so that says a lot for my eyeball
engineering... (Starting the redo on the gap seal for the
forth time tomorrow) And meanwhile all your work in those
pictures is way ahead of anything I can do in terms of
quality control. So I feel like a shade tree mechanic
telling a pro how to do his stuff.
But - just looking at your pictures, if
it was me, I would have your two exhaust pipes come together
right behind the rear main fuselage tube, because that is
almost exactly aligned with the center of pivot of the
engine on its motor mounts. Yours extend down way beyond
that. If it were me, I would terminate them there with a Y
into a ball joint.
By doing that, all the radial movement
of the engine would sort of focus at that point. So if you
had your ball joint there, with just one pipe going down to
the rest of the exhaust assembly, now you have isolated the
engine movement from the main mass of the exhaust system,
and taken a lot of stress off the upper exhaust pipes. And
possibly eliminated some vibration, because you have also
removed some exhaust system mass from the engine and it's
associated movements, and what movement there is, is now
minimized by having it aligned with the center axis of the
motor mounts, at which point you have a movable ball joint.
Worth what ya paid for it...
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Forgiving is tough, being forgiven is
wonderful, and Grace really is amazing.
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D476847%23476847&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=zB8BJx9s7elQ4ogof2d0QDcFj39Z0ih9gir2YAbvr3U%3D&reserved=0
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
- MATRONICS WEB FORUMS -
via the Web Forums!
- NEW MATRONICS LIST WIKI -
Email List Wiki!
- List Contribution Web Site -
support!
-Matt Dralle, List Admin.
Time: 12:48:40 AM PST US
Subject: Flying Adventures of the Eager Beaver
Gday All,
Not Kolb related, but definitely flying related.
Flying Adventures in my Beaver ultralight in the 90's.
Priceless memories, almost as good as my memories of flying Kolbs in the
USA.
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fflyingadventureseagerbeaver.blogspot.com.au%2F&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=F5lr85PIwtzUEuiNfCKhJ7dTb%2FagmDhhG%2B88yeaiYWw%3D&reserved=0
Wishing everyone great flying adventures in the year to come.
JG
Time: 04:14:04 AM PST US
Subject: Re: Flying Adventures of the Eager Beaver
JC,
You are quite the adventurer! Congrats on the aircraft design and build! Y
our
activities put you in a very small, elite group of human beings. Thanks for s
haring!
Safe flying in 2018!
Lanny Lambdin
Sent from my iPad
> On Dec 29, 2017, at 3:47 AM, JC Gilpin <j.gilpin(at)bigpond.com> wrote:
> Gday All,
> Priceless memories, almost as good as my memories of flying Kolbs in the U
SA.
> JG
________________________________ Message 4 _____________________________________
Time: 04:58:16 AM PST US
Great story. I=99m sure they are to be had here in the states too. I
=99m looking forward to a few more this coming year in my Firestar. I
=99m using the long winter months here in northern Michigan to install a new
engine, landing gear and hyd.disc brakes. I flew a RX35 Spectrum Beaver ba
ck in the mid 80=99s and gave Flight instruction in a Beaver RX 550 ta
ndem two seater for a couple of years out in California. Good times! But, an
ytime I=99m flying is a good time. =9CTrue dinkun!=9D I ha
ven=99t heard that in a while. Made me smile. Have great day! George
George Helton
1986 Firestar, FS100
14GDH
Mesick, Michigan
gdhelton(at)gmail.com
> Gday All,
SA.
> JG
________________________________ Message 5 _____________________________________
Time: 05:42:32 AM PST US
Subject: RE: Flying Adventures of the Eager Beaver
John Gilpin is a man after my own heart. He has had more flying
adventures than you can shake a stick at. He has a knack for getting
into trouble and getting out just as easy.
A few years back John G spent a couple weeks with the gang at the Rock
House. He held my attention the whole time I was there. He has a lot
of stories to share about his flying adventures. One of the best is
when you clipped a power line and crashed somewhere Outback.
Few will fully understand the experience of flying solo, completely self
supported, in truly remote areas. John G has been there and done that
many times.
In addition, John G has made several trips to the US to travel and
explore extensively in our country in a Kolb. He finds it difficult to
sit still very long.
Thanks for sharing, John G.
[mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of JC Gilpin
Sent: Friday, December 29, 2017 2:47 AM
Gday All,
USA.
JG
________________________________ Message 6 _____________________________________
Time: 07:01:46 AM PST US
Gday back at ya.
I'm with John. Fun memories from the rock house. Also when you stopped
by Brigham City for a visit.
Boyd Young
On Dec 29, 2017 1:50 AM, "JC Gilpin" <j.gilpin(at)bigpond.com> wrote:
> Gday All,
> USA.
> JG
________________________________ Message 7 _____________________________________
Time: 09:14:50 AM PST US
Two-cycle engines have their exhaust "tuned" to have a low-pressure wave
at the exhaust port when the piston moves below the port. This helps pull
fuel-air mixture into the cylinder while pulling the burnt gases out. I
think it is determined by the length and size of the exhaust pipe so be
careful you don't lose a lot of horsepower.
Respectfully,
Dennis Baber
Cape Coral, Fl
baberdk(at)gmail.com
Stay Curious
________________________________ Message 8 _____________________________________
Time: 09:41:33 AM PST US
The HKS is a four stroke, but I am using this same tuning principle anyway, based
on the recommendations of the engine manufacturer.
Bill Berle
Date: Friday, December 29, 2017, 9:14 AM
Two-cycleengines
wave at the exhaustport when the piston moves below the
port. This helps pull fuel-air mixture into the cylinder
while pulling the burnt gases out. I think it is determined
by the length and size of the exhaust pipe so be careful you
Respectfully,
Dennis BaberCape Coral,
Flbaberdk(at)gmail.com
Stay Curious
________________________________ Message 9 _____________________________________
Time: 09:48:02 AM PST US
JG and any other Kolbers,
If your travels ever bring you to the Southern California area, look me up and
stop by for a visit. I don't have a fabulous private airport or a big rock house,
and our "wilderness" here in LA is a different kind of adventure to say the
least. But we do have some damn good flying weather, and I'd be happy to share
some flying stories with you.
Bill Berle
To: "Kolb List" <kolb-list(at)matronics.com>
Date: Friday, December 29, 2017, 7:01 AM
Gday back at
ya.
I'm with John.
Boyd Young
wrote:
Gday All,
Not Kolb
related, but definitely flying related.Flying
90's.Priceless memories, almost as good as my
memories of flying Kolbs in the USA.http://
flyingadventureseagerbeaver. blogspot.com.au/
Wishing
come.
JG
________________________________ Message 10 ____________________________________
Time: 03:31:28 PM PST US
Subject: best props
I sent the 503 out for a zero time rebuild to Heaven Bound Aviation in Johnstown.
After looking at the prop, I found a few nicks and bruises on it and would
like to replace it. What is the best prop for the 503? I have researched the
achives and am still confused.
Thanks.
Jim P
WAR EAGLE
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D476873%23476873&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=OuyuIQBh%2Bp3sOdUPlkU3lqvRa%2FQpd5z7HXb6j%2Bn4fDk%3D&reserved=0
________________________________ Message 11 ____________________________________
Time: 04:40:32 PM PST US
Subject: Re: best props
Forgot to mention, I am running a b-redrive with 2:58 reduction/
. I know John likes the warp and several others like Ivo but what is the real difference.
Jim
Jim P
WAR EAGLE
https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D476874%23476874&data=02%7C01%7C%7C1948b6b566434fd6b33908d54f58ba64%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636502164871128570&sdata=Didoen2Qgew3ejsUkbaoFqze25BFOkNfLx3wye2xc3w%3D&reserved=0
________________________________ Message 12 ____________________________________
Time: 05:23:14 PM PST US
Subject: Re: Re: best props
The Duc brand of propeller from Europe is supposedly one of the more efficient,
delivering the most thrust. Definitely not the least expensive route however.
Bill Berle
Date: Friday, December 29, 2017, 4:40 PM
"japowell" <japnmjp(at)twc.com>
Jim
Jim P
WAR EAGLE
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
________________________________ Message 13 ____________________________________
Time: 05:44:53 PM PST US
Props are one of those things that require a lot of thought. Ive run two blade
wooden props. (Tennessee propeller) very good at matching prop to specific engines.
Real good composite leading edges are available. Reasonably priced.
Ive run Ivoprops in both two and three blade configurations with good results,
very adjustable. They held up well in sandy and decomposed granite runway conditions.
The only downside was that theyre heavy and seem to take a little longer
to wind up. The blades do flex a lot and on some Kolb models require a prop
extension. Added cost.
At the present time Im liking Powerfin propellers. Beautifully CNC machined hubs
and light very stiff composite blades. Ceramic leading edges are available.
Im sure theyd be great in really abrasive conditions. Extra cost though. They
come in two and three blade versions. They are expensive, but worth the it I think.
Warp Drives are really good looking props. They look really well made. Ive heard
that they are great propellers. Ive been told that theyre on the heavy side
too. But, thats hearsay. I have no experience with them, so I have no opinion.
I think the two blade props are more efficient for around performance. But, I like
three blades simply because I like the climb power and smoothness. I think
that I will loose a little on cruise with a three blade. But, Im all about takeoff
and clearing trees up here. Just my input. Its worth what it cost you. Just
opinions. Have a great day! George
George Helton
14GDH
Mesick, Michigan
> Thanks.
> Jim P
> WAR EAGLE
________________________________ Message 14 ____________________________________
Time: 09:07:41 PM PST US
Subject: RE: Re: best props
Warp Drive blades are solid carbon fiber. Each fiber runs from tip to grip
and back to tip. They are tough, efficient, reliable, and perform. Wish
you could see all the places my Warp Drive Props have pushed me. Would not
have attempted many of those flights with anything but Warp Drive.
Most of the other composite props are fiberglass/plastic over a foam core.
They won't stand up to the punishment a Warp Drive will.
