LAA Airworthiness Alert. AIL December 2017 All Europas
bobhitchcock(at)icloud.co
PostPosted: Tue Dec 05, 2017 5:09 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Still no further specifics on the failing fuel bend. But much activity in the background
http://www.theeuropaclub.org/news/laa-airworthiness-alert-ail-december-2017-all-europas
Jim Kelly
PostPosted: Tue Dec 05, 2017 6:08 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Many thanks for the info Bob already noted.Is there any proposed flights other than Dave's Spanish adventure.
Best wishes Jim
On 5 Dec 2017 1:28 p.m., "Bob Hitchcock" <bobhitchcock(at)icloud.com (bobhitchcock(at)icloud.com)> wrote:
Jim GBWEG
graeme bird
PostPosted: Mon Dec 11, 2017 1:30 pm    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Checked my 6 year old, rubber conventional filler tube (old style long one from the centre of the fuselage. Looked good as new to me and very flexible, no signs of cracking around the face or inside. Surely first signs would be black bits in the fuel filter.
Was there any progress on the metal filler, did anyone get a batch made? Was it with Nev?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
Ivor
PostPosted: Thu Dec 14, 2017 1:21 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
A picture of two section of original pipe from my aircraft, looked fine on the outside but definitely breaking up on the inside,
the amount of rubber actually exposed to the fuel was very small on my installation,
 Filesize:  1.61 MB
 Viewed:  19451 Time(s)
 Filesize:  1.49 MB
ward.t(at)xtra.co.nz
PostPosted: Sun Dec 17, 2017 11:02 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Europa owners,
It has become evident my aluminium elbow maybe in demand again.
I can ask the manufacturer of the aluminium elbow to make another run. This would require at least ten Europa owners to commit to buying. As I am now flying to Heathrow again I can bring them with me and post them in Londontown to save cost. American builders also, as I am in Los Angeles/San Francisco frequently.
Those builders interested in buying an elbow please email me. If there are enough I will get a price for you before committing.
I have had no problem with this fuel flow connection.
Merry Christmas.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 18/12/2017, at 3:34 AM, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk> wrote:
Just completed the check on G-IRPW. And all is well. Just for info I did fit Tim Wards elbow a few years ago.
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
http://forums.matronics.com/viewtopic.php?p=476460#476460
http://forums.matronics.com//files/58e4a1ae_d8b9_43d9_a5c9_b35c398813c7_133.jpeg
brian.davies44(at)gmail.c
PostPosted: Sun Dec 17, 2017 2:49 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Guys,
Before you all rush to fit aluminium elbows to LAA aircraft please note that
there is not currently an approved mod to do so. This is being worked on by
Andy Draper but until we see what it says, particularly with regard to what
spec joining hose is acceptable, we don't know what to buy. As I fitted one
of Tim's elbows 10 years ago I am hoping this will now get approved quickly
by a standard mod to regularise the situation.
Brian
clivesutton
PostPosted: Tue Dec 19, 2017 3:09 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
As you say Bob, lots of activity behind the scenes.
MOD79 may also bring something to the party for some Europa-owners (LAA aware). The black silicone hoses in that MOD kit have a green fluoro fuel-resistant lining.
http://www.europa-aircraft.com/upload/Modification%20Bulletin%20No%2079%20(Issue%2003).pdf
Liking the new look/feel and regular updates of the website btw . . .
brian.davies(at)clara.co.
PostPosted: Fri Dec 29, 2017 9:33 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Jon,
The standard lengths are 76mm so I have ordered two . You need about 30mm overlap on to each joint surface and there are effectively 4 joint surfaces.
Brian
JonSmith
PostPosted: Fri Dec 29, 2017 2:53 pm    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Many thanks for that Brian, much obliged. I have now also ordered two!
Cheers, Jon
G-TERN
Classic Mono
PostPosted: Tue Jan 02, 2018 9:47 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Update- a formal LAA Mod application for the XS aluminium elbow has now been submitted and is "in the system".
I will let you know when it has been approved.
Brian
JonSmith
PostPosted: Tue Jan 02, 2018 11:49 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Thanks for the update Brian. Just out of interest does the mod call for any special clamps for the silicone hose or are the standard factory jubilee clips suitable? I’ve no experience with silicone hose but I’m led to believe it is softer and have heard you can get clips with rounded edges to suit it better.
G-TERN
Classic Mono
PostPosted: Tue Jan 02, 2018 12:11 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Thanks Brian.
Most appreciated.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
[quote] On 3/01/2018, at 6:46 AM, Brian Davies <brian.davies44(at)gmail.com> wrote:
Brian
PostPosted: Tue Jan 02, 2018 11:48 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Jon,
In order to keep things simple the mod uses the same clamps as the standard installation. Constant pressure spring clamps might be an even better solution if you can get hold of the correct size.
Brian
JonSmith
PostPosted: Wed Jan 03, 2018 1:49 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Thanks Brian, good news!
Cheers, Jon
G-TERN
Classic Mono
craigb(at)onthenet.com.au
PostPosted: Thu Jan 04, 2018 2:44 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
FYIW I installed the alloy elbow at build stage and used a commercial fuel tanker delivery hose to connect each end the supplier was willing
To sell me half a metre, the spec sheet claimed it to be completely impervious to all fuel types including methanol which I believe is the most
Troublesome of fuel types
Craig
Kit 577
pjeffers(at)talktalk.net
PostPosted: Sun Jan 07, 2018 2:40 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Tim,
As and when you get a batch of these metal elbows for Europa XS made up, could you please include one for J Baranski (G-CCJX). John is a Europa Club member in the UK, but has not as yet registered for the Matronics Forum so I am sending this request on his behalf.
Pete Jeffers (Europa Club LAA Inspector)
PS he is currently AOG as he damaged his original whilst trying to inspect it.
PostPosted: Sun Jan 07, 2018 7:24 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Pete,
Sure thing, done.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
[quote] On 7/01/2018, at 2:39 AM, Peter Jeffers <pjeffers(at)talktalk.net> wrote:
Hi Tim,
