Aluminium Elbow
Goto page 1, 2  Next
ward.t(at)xtra.co.nz
PostPosted: Sun Dec 17, 2017 12:23 pm    Post subject: Aluminium Elbow Reply with quote
EUROPA ALUMINIUM FUEL FILLER PIPE
*Aluminium pipe is used to join the roto-polyurethane “cobra� fuel inlet tube to the fuel tank inlet.
*The Aluminium pipe is bent to 55 degrees
*The pipe is supplied with added length so it can be cut to the desired length.
*Clean inside of pipe with a mild solvent or Motor gas.
*Cut fuel resistant rubber hose to join at both ends with Hose clamps.
Supplied by Tim Ward.
12 Waiwetu Street
Fendalton
Christchurch
New Zealand
Phone 0064 3 3515166
[img]cid:BD0E2CFA2D8B4A2F978FE2D6B20BF094(at)WaiwetuFamily[/img][img]cid:C185E8288DED4CA89CDFDCA98FF10D47(at)WaiwetuFamily[/img]
2 Hose Clamps
[img]cid:4B920650CC6A4CAEAB0134504314DD0E(at)WaiwetuFamily[/img]
Rubber Hose
2 Hose Clamps
[img]cid:9244B8C5AC6B4DD281DACBEB0AA68131(at)WaiwetuFamily[/img][img]cid:0A7D7EF6ED1045FD9467E74A39B5C2B1(at)WaiwetuFamily[/img][img]cid:968A9B8A7B5A456AAB703230DDF3536A(at)WaiwetuFamily[/img]
Fuel Tank inlet
[img]cid:AE0DC9DDE6D1473398290A179082550F(at)WaiwetuFamily[/img]
Aluminium Pipe
[img]cid:E0FF51E32E3244E8A3756F76E1650295(at)WaiwetuFamily[/img][img]cid:B39E5B6A1C9D4245AD5E8E878C3D68EE(at)WaiwetuFamily[/img][img]cid:A20B8644FB964A7B9478FBD9409BEFEA(at)WaiwetuFamily[/img][img]cid:5D3799F50E9F4E398273992882BA51BA(at)WaiwetuFamily[/img][img]cid:84B7D865E7714286A462657F8AC91C44(at)WaiwetuFamily[/img]
Fuel Tank
[img]cid:F6A2D93BAD2740258D5898FEE9FB3297(at)WaiwetuFamily[/img][img]cid:66E37AC3941C40E3864A38CAF92C37AF(at)WaiwetuFamily[/img][img]cid:AE0C13E531224BB7B8470078D62F8743(at)WaiwetuFamily[/img][img]cid:78D2A0E263614D9693F406FB7AAC7910(at)WaiwetuFamily[/img][img]cid:6E90D1CC31ED4131A866788C4E47CE2F(at)WaiwetuFamily[/img][img]cid:847F99BDC928462E8A67A9292CC6FEDB(at)WaiwetuFamily[/img][img]cid:298EDCBCF6DC44668A7C494235BD2AA8(at)WaiwetuFamily[/img]           Plastic Fuel Filler
 Filesize:  180 Bytes
 Viewed:  21265 Time(s)
 Filesize:  174 Bytes
 Filesize:  209 Bytes
 Filesize:  269 Bytes
 Filesize:  199 Bytes
 Filesize:  251 Bytes
 Filesize:  280 Bytes
 Filesize:  273 Bytes
 Filesize:  278 Bytes
 Filesize:  312 Bytes
 Filesize:  310 Bytes
 Filesize:  183 Bytes
 Filesize:  445 Bytes
 Filesize:  454 Bytes
 Filesize:  461 Bytes
 Filesize:  1.04 KB
 Filesize:  393 Bytes
 Filesize:  740 Bytes
 Filesize:  980 Bytes
Wardery.vcf
 Filename:  Wardery.vcf
 Filesize:  85 Bytes
 Downloaded:  671 Time(s)
peterz(at)zutrasoft.com
PostPosted: Sun Dec 17, 2017 2:07 pm    Post subject: Aluminium Elbow Reply with quote
I'm in, although being in canada, I guess mailing it USPS would be the best way.
Please let me know the cost, and ill forward you my addess etc.
Cheers and thx,
Pete Smile
A239
On Dec 17, 2017, at 3:22 PM, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
12 Waiwetu Street
Fendalton
Christchurch
New Zealand
 <clip_image001[2].gif><clip_image002[2].gif>
2 Hose Clamps
<clip_image004[2].gif>
Rubber Hose
2 Hose Clamps
<clip_image005[2].gif><clip_image006[2].gif><clip_image007[2].gif>
Fuel Tank inlet
<clip_image008[2].gif>
Aluminium Pipe
<clip_image009[2].gif><clip_image010[2].gif><clip_image011[2].gif><clip_image012[2].gif><clip_image013[2].gif>
Fuel Tank
<clip_image014[2].gif><clip_image015[2].gif><clip_image016[2].gif><clip_image017[2].gif><clip_image018[2].gif><clip_image019[2].gif><clip_image020[3].gif>         Plastic Fuel Filler
<Wardery.vcf>
alan.twigg775(at)gmail.co
PostPosted: Sun Dec 17, 2017 11:15 pm    Post subject: Aluminium Elbow Reply with quote
Tim I do not need one just yet but put me down for one, I am sure I will need it in due course.
Alan Twigg
Motorglider kit 463
Oxfordshire UK
On 17 Dec 2017, at 22:06, Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Cheers and thx,
Pete Smile
A239
12 Waiwetu Street
Fendalton
Christchurch
New Zealand
2 Hose Clamps
Rubber Hose
2 Hose Clamps
Fuel Tank inlet
Aluminium Pipe
Fuel Tank
<Wardery.vcf>
carlp101
PostPosted: Mon Dec 18, 2017 3:03 am    Post subject: Re: Aluminium Elbow Reply with quote
Here is a pic of the elbow in place.
Carl
 Filesize:  1.18 MB
 Viewed:  21239 Time(s)
Burrilla
PostPosted: Mon Dec 18, 2017 3:07 am    Post subject: Re: Aluminium Elbow Reply with quote
Carl
No Picture?
Burrilla
PostPosted: Mon Dec 18, 2017 3:11 am    Post subject: Re: Aluminium Elbow Reply with quote
I'm interested please.
Although subject to the LAA Standard Mod outcome obviously.
Alan Burrill
G-CDPY
12 Waiwetu Street
Fendalton
Christchurch
New Zealand
2 Hose Clamps
Rubber Hose
2 Hose Clamps
PostPosted: Mon Dec 18, 2017 9:50 am    Post subject: Aluminium Elbow Reply with quote
Hi there,
The elbow is not welded to create angle. It is bent at the manufacturing stage to the required angle. It is long enough to be cut to fit.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 19/12/2017, at 12:07 AM, Burrilla <alanb(at)dpy01.co.uk> wrote:
> Regards
> Carl
No Picture?
http://forums.matronics.com/viewtopic.php?p=476553#476553
dpark748(at)me.com
PostPosted: Mon Dec 18, 2017 9:56 am    Post subject: Aluminium Elbow Reply with quote
Put me down for one pending new Mod. Just in case my installation is not approved with welded alloy angle?
Dave Park
On 18 Dec 2017, at 17:49, Tim Ward <ward.t(at)xtra.co.nz> wrote:
Hi there,
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
>> Regards
>> Carl
> No Picture?
PostPosted: Mon Dec 18, 2017 10:03 am    Post subject: Aluminium Elbow Reply with quote
Pete,I also fly to Vancouver so will post it from there if it goes ahead.
Tim Ward12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 18/12/2017, at 11:06 AM, Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
Cheers and thx,
Pete Smile
A239
12 Waiwetu Street
Fendalton
Christchurch
New Zealand
2 Hose Clamps
Rubber Hose
2 Hose Clamps
Fuel Tank inlet
Aluminium Pipe
Fuel Tank
<Wardery.vcf>
Kelvin Weston
PostPosted: Mon Dec 18, 2017 11:31 am    Post subject: Re: Aluminium Elbow Reply with quote
Hi All
Damn! Just fitted Tim's pipe and now it looks like I will have to remove and replace the rubber hose with something else, yet to be decided by the LAA.
Two steps forward and one back!
Picture attached - the pipe supplied by Tim is bent not welded.
 Filesize:  53.83 KB
 Viewed:  21166 Time(s)
Kelv Weston
Kit 497
kelv@kdweston.co.uk
gilles.thesee(at)free.fr
PostPosted: Mon Dec 18, 2017 11:53 am    Post subject: Aluminium Elbow Reply with quote
Le 18/12/2017 à 20:31, Kelvin Weston a écrit :
Picture attached
Hi Kevin,
Out of curiosity, what are those lines visible in the composite, I suppose it's not a variety of peel ply ?
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
PostPosted: Mon Dec 18, 2017 11:59 am    Post subject: Aluminium Elbow Reply with quote
Hi All,
Here is a LAA Mod Approval for this Aircraft only. I think it must be the
old "Classic" fuel system?
Hope this attachment comes through.
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
Europa_Aluminum_Pipe_UKCAA_MOD_APPROVAL.pdf
 Filename:  Europa_Aluminum_Pipe_UKCAA_MOD_APPROVAL.pdf
 Filesize:  328.83 KB
 Downloaded:  647 Time(s)
Dave Disney
PostPosted: Mon Dec 18, 2017 1:22 pm    Post subject: Re: Aluminium Elbow Reply with quote
Hello Tim,
I would like to join the list of people who want an aluminium elbow, looks like you might need a suitcase full of them when you visit the UK.
I'll supply my details in a PM.
Dave
PostPosted: Mon Dec 18, 2017 2:37 pm    Post subject: Aluminium Elbow Reply with quote
Hi Dave,
Ok I will put you on the list.
Will keep in touch.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 19/12/2017, at 10:22 AM, Dave Disney <davedisney(at)yahoo.co.uk> wrote:
Hello Tim,
Dave
http://forums.matronics.com/viewtopic.php?p=476582#476582
Kelvin Weston
PostPosted: Mon Dec 18, 2017 2:41 pm    Post subject: Re: Aluminium Elbow Reply with quote
Hi Gilles
No, it's not peel ply. I think it is a tracer thread woven into the glass fabric to ensure the glass is laid up in the correct orientation during the moulding lay-up.
Here is a picture of the inside of the rear fuselage.
 Filesize:  50.63 KB
 Viewed:  21132 Time(s)
Kelv Weston
Kit 497
kelv@kdweston.co.uk
Kelvin Weston
PostPosted: Mon Dec 18, 2017 2:45 pm    Post subject: Re: Aluminium Elbow Reply with quote
Hi Gilles
 Filesize:  50.63 KB
Kelv Weston
Kit 497
kelv@kdweston.co.uk
PostPosted: Mon Dec 18, 2017 2:47 pm    Post subject: Aluminium Elbow Reply with quote
Hi All,
Just been down to see the manufacturer of the elbow. They said there would be no problem in setting up the jig again. They are going to come back with a price for 10 and 20 pipes.
Will keep you informed. Will not give the go ahead until we have enough orders and the LAA Mod. approval is through. Is has already been approved with one builder in 2011 but I am sure that was the Classic Fuel System with the centre roof inlet. However no real difference.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 19/12/2017, at 11:35 AM, Tim Ward <ward.t(at)xtra.co.nz> wrote:
Hi Dave,
Will keep in touch.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
> Hello Tim,
> Regards
> Dave
pete(at)lawless.info
Hi All
This 13070 is for the Classic long long rubber pipe.  Watch this space
for shortly to be released Standard Mod SM 13070.
Pete
G-RMAC Classic # 109
On 18/12/17 19:58, Tim Ward wrote:
Hi All,
the old "Classic" fuel system?
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
Matt Dovey
PostPosted: Mon Dec 18, 2017 3:02 pm    Post subject: Re: Aluminium Elbow Reply with quote
Not sure if I need one bit put me down any way
Matt
hpreusser(at)vtxmail.ch
PostPosted: Mon Dec 18, 2017 10:42 pm    Post subject: Aluminium Elbow Reply with quote
Hi Tim
I need one, can you pur me on the list?
Hans-Peter
Kit 498, still building
Hans-Peter Reusser
Spiezbergstrasse 13
3700 Spiez, Switzerland
Von meinem iPad gesendet
[quote] Am 18.12.2017 um 19:02 schrieb Tim Ward <ward.t(at)xtra.co.nz>:
Pete,
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
> Cheers and thx,
> Pete Smile
> A239
Goto page 1, 2  Next
Page 1 of 2
