JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Fri Dec 08, 2017 1:05 am Post subject: Lamp Dimmer |
Hi Guys
Can someone recommend a 'dimmer' for the instrument lights, that will achieve this: three position switch - Off- On -Dim
John
Sent from my iPad
----x--O--x----
argoldman(at)aol.com Guest
Posted: Fri Dec 08, 2017 5:24 am Post subject: Lamp Dimmer |
You could always get a Lucas automobile dimmer. It has 3positions— OFF DIM and FLICKER
Rich
| Quote: | On Dec 8, 2017, at 3:04 AM, John Tipton <jmtipton(at)btopenworld.com> wrote:
Hi Guys
John
Sent from my iPad
----x--O--x----
Eric Page
Posted: Fri Dec 08, 2017 10:02 am Post subject: Re: Lamp Dimmer |
Do you mean that you want off and two fixed brightnesses (dim and full) or do you want off and an adjustable brightness up to full?
If the former, then you just need a SPDT [OFF-ON-ON] switch and a high wattage resistor of a value that gives the brightness you desire. “Dim” goes through the switch then through the resistor, bright just goes through the switch. We can help with resistor value and wattage if you can post specifics about your installation.
If you want adjustable brightness, then Eric Jones makes/sells a linear dimmer unit here...
http://www.periheliondesign.com/egpavr.htm
Eric
