Looking for ideals on landing lights and placement
AirEupora
PostPosted: Thu Nov 23, 2017 8:30 am    Post subject: Looking for ideals on landing lights and placement Reply with quote
I had two HD lights in the cowl of my Jabiru powered Europa, but they turned out to be useless. I'd like to hear or see what others have done for a landing light and placement.
I recently installed a 40amp alternator and electrical power is no problem now that I got rid of the so called 15 amp Jabiru alternator.
AirEupora
PostPosted: Thu Nov 23, 2017 8:52 am    Post subject: Re: Looking for ideals on landing lights and placement Reply with quote
Here a picture of the ole landing light.
Rick Stockton
N120EJ
 Filesize:  61.12 KB
 Viewed:  6556 Time(s)
craigb(at)onthenet.com.au
PostPosted: Fri Nov 24, 2017 2:35 pm    Post subject: Looking for ideals on landing lights and placement Reply with quote
I came up with one idea, look up 5 CREE LED bike headlight on ebay.
The units I got will run on voltage from 8 - 15 volts, one unit is about the
same as my car headlight, they are about 2 inches across and 2.5 inches
deep.
Well made from aluminium with a glass lense and oring seals. The switch is
on the back of the case so that will have to be moved for obvious reasons
Will post a picture later today
craig
carlp101
PostPosted: Mon Nov 27, 2017 6:07 am    Post subject: Re: Looking for ideals on landing lights and placement Reply with quote
Hi,
I fitted a 3846 Lumen 7 LED light in the cowl. It works a treat as a taxi tight and landing light, only pulls 2 Amps and has a 384 meter beam. It has been approved by the LAA. The light comes from Australia and is significantly cheaper than similar lights sold for aircraft. See https://www.jaycar.com.au/3486-lumen-ip68-solid-led-spot-light/p/SL3919
I've attached the doc I wrote that details the installation and a few pics.
Carl
 Filesize:  55.68 KB
 Viewed:  6480 Time(s)
 Filesize:  30.93 KB
 Filesize:  33.85 KB
 Filesize:  36.18 KB
 Viewed:  6478 Time(s)
LLD002.docx
 Filename:  LLD002.docx
 Filesize:  225.2 KB
 Downloaded:  502 Time(s)
