jrevens
Posted: Fri Oct 27, 2017 8:30 pm Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
Can someone on this list tell me definitively how the Rotax/Ducati regulator/rectifier as used with the 912 series engines actually works? There is so much conflicting info on the internet about it. I don't believe it is a shunt or series type, and might be a switching type regulator, but I'd like to know for sure just to educate myself. I've read so many comments from folks who state emphatically that it is this or that, but there is only one correct answer of course. Also, I know that many of the frequent failures of these units are being attributed to excess temperature by many. Now I recently read that these units actually create more heat when operating with a small electrical load on the system versus fully loaded closer to the maximum rating. Others say just the opposite. I know that there are many contributors to this forum who really know what they are talking about, and I sure would appreciate knowing the actual facts.
In the same vein, I was wondering if Bob N. or anyone else ever fully investigated or tested the Silent Hektik unit. I was able to get one from a friend in Europe and I'm going to use it on my new Kitfox. It's a very nice looking piece.
Thanks in advance for any information or comments relating to these questions.
_________________ John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying) |
jan_de_jong(at)casema.nl Guest
Posted: Sat Oct 28, 2017 1:09 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
I attach a pdf presuming to depict R/R principle of operation.
I await (dis)agreement.
I hope that will help.
Jan de Jong
John Evens
Thorp T-18 N71JE (built & flying)
Kitfox SS7 N27JE (building)
Description: |
 Download |
Filename: |
rectifier-regulator-2017.pdf |
Filesize: |
24.35 KB |
Downloaded: |
729 Time(s) |
gilles.thesee(at)free.fr Guest
Posted: Sat Oct 28, 2017 2:08 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
Le 28/10/2017 à 06:30, jrevens a écrit :
Quote: | Quote: | --> AeroElectric-List message posted by: "jrevens" <jrevens(at)comcast.net> (jrevens(at)comcast.net)
Also, I know that many of the frequent failures of these units are being attributed to excess temperature by many. Now I recently read that these units actually create more heat when operating with a small electrical load on the system versus fully loaded closer to the maximum rating. Others say just the opposite. | |
Hi John,
FWIW, here is a brief article on what we found when conducting an actual lab study of the Rotax and Schicke GR4 voltage R/R during the build of our project some 14 years ago.
I drew the schematics after opening a couple of failed Rotax regulators. My friend Jerome had to run some component on an industrial bench to determine their characteristics.
http://contrails.free.fr/elec_ducati_en.php
My buddy's students also conducted a thermal study of the regulator. Their - unpublished- 48 page report is only in French, though.
Hop this helps,
Best regards,
Gilles
http://lapierre.skunkworks.free.fr
Posted: Sat Oct 28, 2017 5:04 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
At 04:06 AM 10/28/2017, you wrote:
Quote: | I attach a pdf presuming to depict R/R principle of operation.
I hope that will help. |
Here's a real schematic to go with it . . .
http://tinyurl.com/ybvvwy9s
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Sat Oct 28, 2017 5:53 am Post subject: Re: Rotax/Ducati Voltage Regulator/Rectifier |
My RV-12 with a Rotax 912ULS came with the Ducati rectifier/regulator. The Ducati is switching type regulator. It obeys ohm's law. The more current that flows, the warmer it gets. Mike Miller is very knowledgeable about the Ducati. He has posted on VansAirforce and also on this website, if I remember right. There are different opinions about why the Ducati fails including heat, poor thermal design, and poor manufacturing practices.
I and others have had success using a lawnmower regulator. Search eBay for AM101406, or MIA881279, or JDR1406. No matter what brand regulator is installed, keep it cool and mount it using heat conductive paste.
_________________ Joe Gores |
kenryan
Posted: Sat Oct 28, 2017 8:57 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
Joe,
Regarding your statement:
"No matter what brand regulator is installed, keep it cool and mount it using heat conductive paste"
Does that apply to the Ducati?Â
I ask because mine does not have a metal back. The backside of mine is that potting material, and it is set back from the case by almost 1/16". The only thing making contact are the tiny ears with the mounting holes.
Ken
On Sat, Oct 28, 2017 at 5:53 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=473912#473912
Posted: Sat Oct 28, 2017 10:48 am Post subject: Re: Rotax/Ducati Voltage Regulator/Rectifier |
Yeah, the small mounting contact area will not conduct much heat. But even so, every little bit helps. Use heat conductive grease. A shroud with attached blast tube will help also.
You might already have thermal grease for spark plug threads.
Below is a quote from Jim Weir. Quote: | go down to the drugstore and get a small tube of that white stuff you rub on your nose in the summertime (zinc oxide). It isn't the BEST thermal conductor you can find, but it will do a fine job in most instances. |
A wise man once said that anything will conduct heat better than air. You do not have to buy the expensive stuff containing silver.
Description: |
 Download |
Filename: |
Reg Shroud.pdf |
Filesize: |
41.28 KB |
Downloaded: |
684 Time(s) |
Posted: Sun Oct 29, 2017 1:56 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
Le 28/10/2017 à 20:48, user9253 a écrit :
Hi all,
You can also use a computer fan attached to the Voltage R/R.
Best regards,
Gilles
kenryan
Posted: Sun Oct 29, 2017 8:27 am Post subject: Re: Rotax/Ducati Voltage Regulator/Rectifier |
Thanks. I will probably sand the rough casting smooth and flat (at the mounting ears) and use the paste. I've got some temp monitoring strips so I'll determine how hot things get and then make a decision on dedicated cooling air. I will only be using under 5 amps under normal circumstances so I'm hoping the thing lasts.
Sidenote: I have a German friend who is an avid aviation enthusiast and the last time he went over there he tried to get me a Silent-Hektik regulator. Unfortunately the company was non-responsive to his telephone calls. They never answered their phone nor returned his messages.
graemeh
Posted: Mon Oct 30, 2017 11:45 am Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
I was able to order a regulator from Silent Hektik around this time last year. I had it shipped to a UK based re-shipping service that I used to get the regulator to NZ as Silent Hektik don't appear to ship outside of EU.
There was a delay of about a month as they were on holiday but their website told me this before I placed the order.
On Mon, Oct 30, 2017 at 5:27 AM, kenryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "kenryan" <keninalaska(at)gmail.com (keninalaska(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=473933#473933
kenryan
Posted: Mon Oct 30, 2017 12:20 pm Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
Great info Graeme. Do you have a link to the re-shipping service?
On Mon, Oct 30, 2017 at 11:44 AM, Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)> wrote:
Quote: | I was able to order a regulator from Silent Hektik around this time last year. I had it shipped to a UK based re-shipping service that I used to get the regulator to NZ as Silent Hektik don't appear to ship outside of EU.
graemeh
Posted: Mon Oct 30, 2017 12:35 pm Post subject: Rotax/Ducati Voltage Regulator/Rectifier |
It was Youshop which is a NZ only service so unlikely to be of use to you.
Others may be able to recommend a service that ships to your location.
On Tue, 31 Oct 2017, 09:29 Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
Quote: | Great info Graeme. Do you have a link to the re-shipping service?
