Europa Tri-Gear Trailer
Lurcher
PostPosted: Sat Oct 07, 2017 11:01 am    Post subject: Europa Tri-Gear Trailer Reply with quote
Hi Guys
Does anybody know roughly what a trailer for a Tri-Gear costs please? And is there anything special that I would need to know about using one? All information and ideas gratefully received!
Many, many thanks
Hazel
stevenwpitt(at)me.com
PostPosted: Sat Oct 07, 2017 12:49 pm    Post subject: Europa Tri-Gear Trailer Reply with quote
A closed trailer is likely to be £7500 and upwards. There is a bespoke trailer company in West Sussex that I used www.kompak.co.uk
Contact me off list for more
Steve Pitt
On 7 Oct 2017, at 20:00, Hazel Jackson <hj(at)motorcycleresults.com> wrote:
Hi Guys
Many, many thanks
Hazel
ptag.dev(at)talktalk.net
PostPosted: Sat Oct 07, 2017 12:56 pm    Post subject: Europa Tri-Gear Trailer Reply with quote
Hi! Hazel Jackson.
I have a covered box type trailer to transport a Europa TRigear.  It needs the maingear spats removed to enable the fuselage to be winched up ramps into the transportation position. The wings and tailplanes stow within the trailer.
I do not hire the trailer out but I am able to give you prices for an aircraft move if you advise from where to where? With you assisting and your insurance provision.
Just prior to last October  I recovered a trigear from  Troyes and delivered it to Fenny Compton  Via The Chunnel  then about  a month later removed it back to Nottingham for the owner.
Drop me a line and I may be able to assist. I strongly advise a discussion your aircraft is worth more than to be damaged.
Bob Harrison   Europa G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Hazel Jackson
Sent: 07 October 2017 20:00
Subject: Europa Tri-Gear Trailer
Hi Guys
Many, many thanks
Hazel
Virus-free. www.avg.com
 Filesize:  1.83 KB
 Viewed:  8549 Time(s)
r.vogel(at)ggs.ch
PostPosted: Sun Oct 08, 2017 9:51 am    Post subject: Europa Tri-Gear Trailer Reply with quote
Hi Hazel
I bought an excellent trailer by
http://avionic.pl/index.php/pl/kontakt-2/ Laszek Matuszek
from Poland. It's special made for mine Europa Classic. The only information
he had for construction were some photos and the drawing from the AFM.
Price was about € 12'000.- in 2013.
For the Tri-Gear it must be a little wider and the fuselage should turned
to prop side back, giving enough space for the wings.
I don't know where you live, but the best way would be visiting Laszek
with your Europa
for discussion and planing.
Best regards
Ruedi Vogel
Wiesenweg 6
CH-3380 Wangen a.A.
Switzerland
Am 07.10.2017 um 21:00 schrieb Hazel Jackson:
Hi Guys
Many, many thanks
Hazel
 Filesize:  19.74 KB
 Viewed:  8526 Time(s)
 Filesize:  78.29 KB
Roland
PostPosted: Sun Oct 08, 2017 9:05 pm    Post subject: Re: Europa Tri-Gear Trailer Reply with quote
Hello,
I have one from https://www.anschau.de/english-version/ . It costs some 17k EUR. The Wheel-pants don't have to be removed and I use it for 6,5 years now to transport my Europa anywhere I want.
I add a photo.
Roland
PH-ZTI
XS TG 914
 Filesize:  105.92 KB
 Viewed:  8512 Time(s)
dpark748(at)me.com
PostPosted: Tue Oct 10, 2017 5:22 am    Post subject: Europa Tri-Gear Trailer Reply with quote
Last time i asked Europa they said they mo longer proce it as other manufacturers are more competitive??
I am trying to find out who?
Where are you based Hazel?
Dave Park G-LDVO
Hi Guys
Many, many thanks
Hazel
danny shepherd
PostPosted: Tue Oct 10, 2017 7:45 am    Post subject: Europa Tri-Gear Trailer Reply with quote
Hi , what type of trailer do you need ? if it's an eclosed
then the one's others have surjested look ideal. In my case I only need
a basic trailer to take my a/c home once a year for it's annual. I was
fortuneate to have a friend (aircraft fitter) who worked at Manchester
airport who inturn had a friend who designs trailers for racing cars. It
was a few years ago.
If you do some research you should find some metal fabricaters who could
make one up for you. I've attached a couple of pics. I think it cost about
 £ 2.500 . the only thing they needed was the wieght and balance of the
a/c.
Danny shepherd g-ceri
Dave Park G-LDVO
> Hi Guys
> Many, many thanks
> Hazel
This email has been checked for viruses by AVG.
http://www.avg.com
 Filesize:  2.02 MB
 Viewed:  8467 Time(s)
 Filesize:  2.08 MB
