fishface68
Posted: Wed Sep 27, 2017 8:59 am Post subject: Yak 18T Jacks |
Has anyone got a set of Jacks for sale, preferably in europe, but I will ship from anywhere for the right set. Failing that any drawings or help with dimensions would be super helpful. i.e. diameter of the ACME screw, Height of the jack (extended & retracted) and distance between the feet.
Also can anyone tell me if the Yak18T jacks need an offset like the CJ-6 jacks?
Many thanks Pat
marcusbates(at)att.net Guest
Posted: Wed Sep 27, 2017 10:39 am Post subject: Yak 18T Jacks |
Have a set for 52.........
| Quote: | On Sep 27, 2017, at 11:59 AM, fishface68 <patrick.chriswick(at)gmail.com> wrote:
Many thanks Pat
http://forums.matronics.com/viewtopic.php?p=473167#473167
Posted: Wed Sep 27, 2017 10:41 am Post subject: Yak 18T Jacks |
Have a set of 52 jacks available.
Many thanks Pat
Vic
Joined: 12 Aug 2008 Posts: 117 Location: Southern Bavaria
Posted: Wed Sep 27, 2017 12:51 pm Post subject: Re: Yak 18T Jacks |
Hello Pat,
sorry, no jacks for sale, but maybe a photo will give you an idea. No need for offset design, just some tripods with feet not too wide apart. You just orientate the feet to clear the wheels for retractions. I made the tripods a bit collapsible as the lower joints are movable like some typical car jacks, so the feet fold onto the central tube for storage. I got all material from Ebay, like the trapezoidal thread with bronce nut and the steel profiles and did the arc welding at home. On top of the screw there are big steel balls in their cup that fit into the ball recess on the plane. For lifting you have to wrench the thread by turning at the bit of hex material that holds the ball cup. I got me one meter of thread for three jacks. It is an easy job to do but takes a few hours of course - and I use the jacks for all winter hangarage, so no flats on tires in months of parking.
For sizes: You get the height from your Yak on its wheels from floor to the ball cups and stay a few inches short to be sure you get the jacks plus balls under it with screws down to lower stops. More photos per PM but no sizes for next days.
Vic
627.62 KB |
11449 Time(s) |
fishface68
Posted: Thu Sep 28, 2017 11:13 am Post subject: Re: Yak 18T Jacks |
pm sent
weloveflying
Posted: Wed Oct 04, 2017 8:04 pm Post subject: Re: Yak 18T Jacks |
Have you tried getting parts from companies which offer metal machining services, like this one for example? The said company has lift systems as one of their specialties, but most of these are for automation or motion control; however, they also offer metal machining services which, I think, you can leverage to get a jack made for you according to your needed measurement for your said purpose.
taylor527(at)att.net Guest
Posted: Fri Oct 06, 2017 10:35 am Post subject: Yak 18T Jacks |
Hi all
If the yak owner still needs factory jacks I’ve got a set in my hangar
Pete Taylor
530-200-0144
| Quote: | On Oct 4, 2017, at 9:04 PM, weloveflying <yourordinarybeing(at)gmail.com> wrote:
Have you tried getting parts from companies which offer metal machining services, like this one (http://www.powerjackmotion.com/product-category/metal-maching-service/) for example? The said company has lift systems as one of their specialties, but most of these are for automation or motion control; however, they also offer metal machining services which, I think, you can leverage to get a jack made for you according to your desired measurement.
http://forums.matronics.com/viewtopic.php?p=473358#473358
Looigi
Joined: 20 Apr 2015 Posts: 81 Location: Christchurch, New Zealand
Posted: Fri Oct 06, 2017 11:23 am Post subject: Yak 18T Jacks |
Hi Pete,
Can you please take some pictures of the jacks please? I am gearing up to make some.
Kind regards
Chris
Sent from my iPhone, so typo's are bought to you courtesy of Siri.
| Quote: | On 7/10/2017, at 07:34, Taylor <taylor527(at)att.net> wrote:
Hi all
Pete Taylor
530-200-0144
