broken push rod suberu ea81
Goto page 1, 2  Next
kirkhull(at)sbcglobal.net
PostPosted: Thu Jul 13, 2006 2:29 pm    Post subject: broken push rod suberu ea81 Reply with quote
I had an in flight failure last week of N205AK's Suberu ea81. She was landed
with no problems and everyone is ok. The push rod on the # 4 cylinder (
Front right)snaped. Attached is a picture of the part . it made a clean
break almost dead center on the rod completely in to. With only 20 hrs on
the engine and only 5 in flight this should not have happened. Has anyone
else seen this before and why did it happen? P.S. it is a 100HP Stratus
conversion.
wingsdown(at)comcast.net
PostPosted: Thu Jul 13, 2006 5:12 pm    Post subject: broken push rod suberu ea81 Reply with quote
If it was adjusted to tight, partial bend, stress failure. The are
pretty stout push rods. Did not see the attachment.
Rick
Graeme Toft
PostPosted: Thu Jul 13, 2006 5:18 pm    Post subject: broken push rod suberu ea81 Reply with quote
Kirk, when my NSI EA 81 was pulled apart after an accident, 2 of the push
rods were broken at the ball end. The mechanic who did the work for me said
an engine failure was immanent. Also he was convinced the push rods were
home made. Im not a mechanical person so Im taking his work for it but he
did remove all rods and replace them with off the shelf ones. My engine had
only 130 hours on it and the issues that required repairs or replacement
would be expected of an engine with far greater hours. Valves seats were
also clogged with what he suggested was material from the air filter, and
the bore required honing. Several rings were also imbedded into their
groves.
Graeme
PostPosted: Thu Jul 13, 2006 5:26 pm    Post subject: broken push rod suberu ea81 Reply with quote
sorry I must have forgotten to attach the photo so here it is
 Filesize:  56.59 KB
 Viewed:  416 Time(s)
PostPosted: Thu Jul 13, 2006 6:38 pm    Post subject: broken push rod suberu ea81 Reply with quote
Humm, that looks like an aluminum custom type. Is it? The stock ones, at
least on the turbo engine are steal, fat, real beefy. I don't have
experience with the non-turbo, maybe someone else can comment. I would
change to the tougher style, not good. Let me know.
Rick
janderson412(at)hotmail.c
PostPosted: Thu Jul 13, 2006 8:30 pm    Post subject: broken push rod suberu ea81 Reply with quote
Yes Rick, mine are are much thinker too and non turbo are the same. It  does look like an after market item. John A.
Reply-To:  kitfox-list(at)matronics.com
To:  <kitfox-list(at)matronics.com>
Subject:  RE: broken push rod suberu ea81
Date:  Thu, 13 Jul 2006 19:38:19 -0700
--> Kitfox-List message posted by: "wingsdown" <wingsdown(at)comcast.net>
Rick
PostPosted: Fri Jul 14, 2006 4:25 am    Post subject: broken push rod suberu ea81 Reply with quote
These are not custom parts.  I got the replacement from the auto parts store.  it looks just like the one that broke.  however they are aluminum
[quote] --
PostPosted: Fri Jul 14, 2006 4:27 am    Post subject: broken push rod suberu ea81 Reply with quote
are you using an NSI and if so would you have a push rod handy to photograph?  Please don't remove one but if you have one just laying around I would really like to see a pic.
[quote] --
kingjohne(at)adelphia.net
PostPosted: Fri Jul 14, 2006 10:19 am    Post subject: broken push rod suberu ea81 Reply with quote
Kirk,
Michael Harter had an NSI EA81 in his Model IV several years back.  On takeoff one time he lost power (not all) throttled back and returned to the airport.  He discovered several (not sure how many) broken push rods.  He replaced then with parts from NSI.
John King
Warrenton, VA
kirk hull wrote:
--> Kitfox-List message posted by: "kirk hull" <kirkhull(at)sbcglobal.net> (kirkhull(at)sbcglobal.net)
conversion.
PostPosted: Fri Jul 14, 2006 2:59 pm    Post subject: broken push rod suberu ea81 Reply with quote
thanks .  I am begining to think that NSI uses their own push rods and not the stock sub parts.
[quote] --
PostPosted: Fri Jul 14, 2006 4:55 pm    Post subject: broken push rod suberu ea81 Reply with quote
I will be out to the airport on the 17th and would be most happy to do that.
Rick
PostPosted: Fri Jul 14, 2006 4:59 pm    Post subject: broken push rod suberu ea81 Reply with quote
They used stock I am almost positive, unless it was a special order, don't think so. This engine doesn't spin fast enough to worry about push rod weight and the HP savings I think one would be hard pressed to measure.
Rick
PostPosted: Fri Jul 14, 2006 6:10 pm    Post subject: broken push rod suberu ea81 Reply with quote
thanks
[quote] --
PostPosted: Fri Jul 14, 2006 7:03 pm    Post subject: broken push rod suberu ea81 Reply with quote
I installed the new pushrod today and checked the clearances on all valves. found two that were tight.  Still wandering if that could have caused the problem.  205AK run great again.  put .4 on her today with no problems but I think that I will pull all of the pushrods at the next inspection and inspect them just in case.
[quote] --
PostPosted: Fri Jul 14, 2006 9:51 pm    Post subject: broken push rod suberu ea81 Reply with quote
Was this/these failures with hydraulic or solid lifters. All the original
turbo engines came out with hyd, any faulures in with these? John A.
Kirk,
John King
Warrenton, VA
conversion.
Shop ‘til you drop at XtraMSN Shopping http://shopping.xtramsn.co.nz/home/
PostPosted: Fri Jul 14, 2006 9:52 pm    Post subject: broken push rod suberu ea81 Reply with quote
If you might post a shot to me too Rick, do the NSI turbos have hyd lifters?
that.
Rick
jimlc(at)att.net
PostPosted: Fri Jul 14, 2006 11:57 pm    Post subject: broken push rod suberu ea81 Reply with quote
My understanding from Lance is that the turbos did have hydraulic
lifters and did not require adjustment.
Jim Crowder
lifters? John
that.
Rick
morid(at)northland.lib.mi
PostPosted: Sat Jul 15, 2006 3:26 am    Post subject: broken push rod suberu ea81 Reply with quote
Hello John. All the EA81 NSI normally aspirated engines have solid lifters
and the turbos have hydraulics. I don't know the reason for the difference.
Obviously the solids need to be adjusted properly, especially right at the
beginning and periodically thereafter. One of the most common reasons for
broken pushrods are incorrect adjustment which is an owner requirement.
Deke
PostPosted: Sat Jul 15, 2006 4:54 pm    Post subject: broken push rod suberu ea81 Reply with quote
That is correct, just the initial adjustment which is very important.
Rick
PostPosted: Sat Jul 15, 2006 4:55 pm    Post subject: broken push rod suberu ea81 Reply with quote
Yes they do. Also lifter bores are bronze inserts.
Rick
Goto page 1, 2  Next
Page 1 of 2
