Housai Oil Pressure
727gs
PostPosted: Sat Aug 26, 2017 9:58 am    Post subject: Housai Oil Pressure Reply with quote
After starting my stock CJ-6, I noticed that the oil pressure needle on the triple gauge would bounce from normal pressure to 0 and back very quickly, like there was an electrical ground or connection that was intermittent. No real pattern to it and it went away when the power was advanced. All other indications were normal. I reseated the canon plugs on the back of the instrument to no avail and have no idea where the oil pressure probe on the engine is located.
Any ideas? Thanks in advance.
Steve Jones
near Chicago
Steve near Chicago
dsavarese0812(at)bellsout
PostPosted: Sat Aug 26, 2017 10:28 am    Post subject: Housai Oil Pressure Reply with quote
Two things
- Did you check to see if you have the same indication in the rear cockpit?
- The oil pressure senders are on the back side of the firewall. Look for two round devices about 2 1/4" in diameter, painted brown on the side facing away from the firewall.  Those are the oil pressure senders.
I'd recommend removing the inspection cover on the port side between the instrument panel and the firewall to see them.
Dennis
To: yak-list(at)matronics.com
Sent: Saturday, August 26, 2017 1:59 PM
Subject: Housai Oil Pressure
--> Yak-List message posted by: "727gs" <727gs(at)att.net (727gs(at)att.net)>
Steve Jones
near Chicago
Steve near Chicago
http://forums.matronics.com/viewtopic.php?p=472217#472217
http://w===================
http://wiki.matronic=======================
</; &nb -->
Clouddog
PostPosted: Sat Aug 26, 2017 1:36 pm    Post subject: Housai Oil Pressure Reply with quote
Steve, inside the engine compartment on the right side you will see several cannon plugs. My recommendation is u remove them one at a time, and hose them down with an electrical contact spray cleaner. Very few engines are super clean. Over the years oil works itself into cannon plugs and crazy things happen. I had issues with my tach generator plug and a bouncy rpm gage until I cleaned out the oil. Give it a try, can't hurt.
Greg "Clouddog" Wrobel
AA Retired
On Aug 26, 2017 1:08 PM, "727gs" <727gs(at)att.net (727gs(at)att.net)> wrote:
Steve Jones
near Chicago
Steve near Chicago
PostPosted: Sat Aug 26, 2017 2:03 pm    Post subject: Housai Oil Pressure Reply with quote
But the oil pressure sender cannon plugs are behind the firewall. I seriously doubt oil would be getting into those cannon plug connectors. What is in the engine compartment is the oil pressure line to the oil pump.
Dennis
Sent: Saturday, August 26, 2017 5:37 PM
Subject: Re: Yak-List: Housai Oil Pressure
AA Retired
Steve Jones
near Chicago
Steve near Chicago
http://forums.matronics.com/ viewtopic.php?p=472217#472217
List" rel="noreferrer" target="_blank">http://www.matronics.com/ Navigator?Yak-List
rel="noreferrer" target="_blank">http://www.matronics.com/ contribution
n13472(at)aol.com
PostPosted: Sat Aug 26, 2017 4:01 pm    Post subject: Housai Oil Pressure Reply with quote
Oli press sensors are NOT in the engine compartment.
Open the lower right side pnl on the fuselage they are mounted on the back side of the firewall
note the front and rear oil press gauges and sensor are independent of each other.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Greg Wrobel
Sent: Saturday, August 26, 2017 2:35 PM
Subject: Re: Housai Oil Pressure
AA Retired
Steve Jones
near Chicago
Steve near Chicago
This email has been checked for viruses by AVG antivirus software.
www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
wlannon(at)shaw.ca
PostPosted: Sat Aug 26, 2017 5:22 pm    Post subject: Housai Oil Pressure Reply with quote
That certainly sounds like an electrical problem. A defective Cannon plug
is a very real possibility; either dirty contacts, broken wire making
intermittent contact, etc. Could be at the guage or the transmitter. The
oil press. transmitters (one for each cockpit) are mounted on frame 1. The
firewall is frame 0 and the FUEL press. transmitters are mounted on the aft
side of that- see photo. Oil press. units are the same but colour coded
brown rather than yellow. Sorry, no photo for those!
Check continuity to determine correct transmitter. Good luck.
Walt
 Filesize:  1.31 MB
 Viewed:  13681 Time(s)
Harv
PostPosted: Tue Aug 29, 2017 5:06 am    Post subject: Re: Housai Oil Pressure Reply with quote
Tom
Your CJ maybe like mine and the oil pressure senders are not located on the rear of the engine firewall but the secondary frame wall/cockpit area one.
The pic that Walt posted shows the approximate type and shape of the sender's but those I believe are the fuel ones and the oil senders (Transducers if you prefer) have a brown case covers.
On my aircraft they are located in the front cockpit and bolt through the panel (you may call is a secondary firewall or forward frame) just above the STB rudder pedal area.
Now its interesting you mention the issue you are having as my CJ oil pressure went exactly the same in the front cockpit and after alot of messing about I traced it to a faulty sender (swapping cannon plugs identified where the issue lay) which when opened up looked like it had been full of water??. I managed to rinse the muck out of it and clean up the delicate internals and it now works but I had to fabricate a new spring to return the potentiometer arm to zero.
Hope this helps.
GeorgeCoy
PostPosted: Tue Aug 29, 2017 5:22 am    Post subject: Housai Oil Pressure Reply with quote
We have spare transducers if needed.
George Coy
wlannon(at)shaw.ca
PostPosted: Tue Aug 29, 2017 9:18 am    Post subject: Housai Oil Pressure Reply with quote
Harv;
Did you read the text? Or do you just look at pictures?
Walt
Harv
PostPosted: Tue Aug 29, 2017 9:56 am    Post subject: Re: Housai Oil Pressure Reply with quote
Yes I did but making doubly sure the op is without doubt about colours and location of senders as there seems to be some confusion earlier in this post.
Moreover hopefully my matching symptoms/mode of failure will provide a steer as to the possible issue he's having
wlannon(at)shaw.ca
PostPosted: Tue Aug 29, 2017 5:25 pm    Post subject: Housai Oil Pressure Reply with quote
A simple apology would have been in order but you don't appear to understand
that either.
Walt
Harv
PostPosted: Wed Sep 06, 2017 9:03 am    Post subject: Re: Housai Oil Pressure Reply with quote
Sorry Walt,
Rgs
Harv
wlannon(at)shaw.ca
PostPosted: Wed Sep 06, 2017 12:01 pm    Post subject: Housai Oil Pressure Reply with quote
Many thanks Harv.
Best;
Walt
