Heat Shrink Labels for 20 AWG Wire
art(at)zemon.name
PostPosted: Sun Sep 03, 2017 7:13 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Of the label printers that we have talked about, will the heat shrink tube labels get small enough to label 20 gauge wire?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donvansanten(at)gmail.com
PostPosted: Sun Sep 03, 2017 7:22 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
I label #22 tefzel all the time with the Epson.
On Sep 3, 2017 20:18, "Art Zemon" <art(at)zemon.name (art(at)zemon.name)> wrote:
    -- Art Z.
rlborger(at)mac.com
PostPosted: Sun Sep 03, 2017 7:29 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Art,
The DYMO RHINO 4200 that I illustrated certainly will do 20 ga wire. The LR3C-14 was wired with both 20 and 18 ga wire.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Sep 3, 2017, at 10:11 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
-- Art Z.
-- https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donjohnston
PostPosted: Mon Sep 04, 2017 3:33 am    Post subject: Re: Heat Shrink Labels for 20 AWG Wire Reply with quote
I used the Rhino 4200 to label wires down to 24awg. Works great. No fading after 4 years.
 Filesize:  181.48 KB
 Viewed:  14032 Time(s)
art(at)zemon.name
PostPosted: Mon Sep 04, 2017 3:57 am    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Ah! Google finally surfaced the answer: K-Sun's 1/8" and 3/16" tubing will hold on 20 AWG tefzel wire.K-Sun Shrink Tube Instruction Manual gives the wire diameters in mm that each tubing size will fit.
The MIL-W-22759/16 spec 20 AWG tefzel wire that I got from Aircraft Spruce is about 1.74 mm in diameter.
22 AWG is about 1.34 mm in diameter so K-Sun 1/8" tubing will work on that, too.
Assuming that Dymo's 3:1 heat shrink tubing has approximately the same specs as K-Sun's 3:1 tubing, it will not work as well in my application. The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wire. (According to the specs. Maybe it will work anyway but I don't know.)
    -- Art Z.
On Sun, Sep 3, 2017 at 10:11 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
ribrdb(at)gmail.com
PostPosted: Mon Sep 04, 2017 7:13 am    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Has anyone looked into custom printed heatshink? I wonder if that's more economical than buying the labeler? I found several places that do it, but only one has a price listed:$29 for 100 pieces of 1/8 3:1 heatshrink. That's for .75"-1" length. They say they can print serial numbers, not sure how much control you have over the serial numbers.
https://www.shrinkshop.com/collections/custom-cut-printed-thermafix/products/custom-cut-heat-shrink-3to1-shrinkratiodual-wall-printed-1-8?variant=40161312967
On Mon, Sep 4, 2017 at 6:02 AM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
    -- Art Z.
ceengland7(at)gmail.com
PostPosted: Mon Sep 04, 2017 7:29 am    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
If I were buying a tubing printer, I wouldn't be overly concerned about it 'grabbing' the wire after shrinking. In fact, I wouldn't even worry about shrinking at all, in most cases. If the wire is in a bundle, the label isn't going far, and as long as it can't get past the terminator, it won't get lost. And there will be times when moving the label could have its advantages. Ex: when the printing is on the 'back side' of a wire in a bundle, or aligned with a half-dozen other labels in the bundle.
On 9/4/2017 6:55 AM, Art Zemon wrote:
Ah! Google finally surfaced the answer: K-Sun's 1/8" and 3/16" tubing will hold on 20 AWG tefzel wire. K-Sun Shrink Tube Instruction Manual gives the wire diameters in mm that each tubing size will fit.
    -- Art Z.
https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donjohnston
PostPosted: Mon Sep 04, 2017 3:14 pm    Post subject: Re: Heat Shrink Labels for 20 AWG Wire Reply with quote
The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On 22AWG will, you will have to encourage it to move. On 20AWG wire, you will have to really encourage it to move.
PostPosted: Mon Sep 04, 2017 6:30 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
I am confused. K Sun sells many different diameters of tubing. Does Dymo only sell one diameter?
On Sep 4, 2017 16:19, "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
http://forums.matronics.com/viewtopic.php?p=472492#472492
rlborger(at)mac.com
PostPosted: Mon Sep 04, 2017 6:58 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
1/4” 3/8” 1/2” & 3/4”
https://smile.amazon.com/DYMO-RHINO-Label-Maker-1801611/dp/B005MR516Y/ref=sr_1_2?ie=UTF8&qid=1504450593&sr=8-2&keywords=dymo+rhino+label+maker
On Sep 4, 2017, at 9:28 PM, don van santen <donvansanten(at)gmail.com (donvansanten(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>art(at)zemon.name wrote:> Assuming that Dymo's 3:1 heat shrink tubing has approximately the same specs as K-Sun's 3:1 tubing, it will not work as well in my application. The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wire.The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On 22AWG will, you will have to encourage it to move. On 20AWG wire, you will have to really encourage it to move.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=472492#472492
PostPosted: Mon Sep 04, 2017 7:11 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Got it. The Epson and K Sun ztaft at 3 mm. Guss I would not recommend the Dymo.
On Sep 4, 2017 20:03, "Robert Borger" <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
donjohnston
PostPosted: Tue Sep 05, 2017 4:32 am    Post subject: Re: Heat Shrink Labels for 20 AWG Wire Reply with quote
They also sell 3/8", 1/2", 3/4" and 1".
You were asking about heat shrink tubing that would work on 20AWG wire. The Dymo 1/4" shink tubing works fine on 20AWG.
jim(at)PoogieBearRanch.co
PostPosted: Tue Sep 05, 2017 6:43 am    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Better URL for the DYMO-RHINO shrink-tube: http://tinyurl.com/ydc642nj
Jim Parker
ronburnett(at)charter.net
PostPosted: Tue Sep 05, 2017 5:12 pm    Post subject: Heat Shrink Labels for 20 AWG Wire Reply with quote
Art,
If you go to Gateway Electronics in Maryland Heights, you will walk out with all the clear shrink wrap you need at very low prices. They also have three sizes of clear spiral wrap for under the panel work. It is in a room to the right as you walk in and they cut it for you. Very inexpensive. They also have ready made molex connectors that come in nearly any count.
Good luck,
Ron Burnett
May you have the Lord's blessings today!Sent from my iPad
On Sep 3, 2017, at 10:20 PM, don van santen <donvansanten(at)gmail.com (donvansanten(at)gmail.com)> wrote:
-- Art Z.
