gear retraction problem
Goto page 1, 2  Next
airmanv2
PostPosted: Sat Aug 19, 2017 8:00 pm    Post subject: gear retraction problem Reply with quote
Hello
yesterday I've intended to make a fly and clean the plane in preparation for Saturday airshow . ...
I had a major problem with the gear: just after take off it was not possible to retract.....
Move up the gear handle and only the left green light switch off, and no red light switch on. the 3 external red gear indicators stay out....
so i moved down the handle and i got the " greens.
the air pressure was enough at 25/30 Atm.
so i move up again the gear handle and nothing happens. 3 greens remains. So i put the handle on down position and land again without problem.
Guy on the ground reported that they saw the gear retraction non completed after take off . for them, the main gear only move for about 30° from vertical position before to come back at vertical position. Because of distance and position they were unable to give information for the nose gear position .
So what can be done . I can't fly any more with no gear retraction ...
please help
best regards
Bruno
Fly safe
draftsjust417(at)gmail.co
PostPosted: Sat Aug 19, 2017 8:28 pm    Post subject: gear retraction problem Reply with quote
Good morning Bruno...
Several years ago I had a very similar problem with my CJ6A, except I (apparently) had NO movement in my gear when I moved the handle up.
It turns out, the check valve for my emergency gear extension was corroded, and leaking "down air" from the emergency bottle/supply. This prevented my gear from coming up.
Installing a new check valve (from Doug Sapp) was not difficult, and the problem disappeared.
Perhaps this will help?
Justin
N280NC
On Aug 20, 2017 12:08 AM, "airmanv2" <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)> wrote:
--> Yak-List message posted by: "airmanv2" <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)>
Hello
please help
best regards
Bruno
Fly safe
http://forums.matronics.com/viewtopic.php?p=471988#471988
cerveirapinto(at)gmail.co
PostPosted: Sun Aug 20, 2017 3:29 am    Post subject: gear retraction problem Reply with quote
Hi BrunoProbably you have a air leak somewhere in the system . Probably on gear handle valve.
Put the airplane on jacks and fill the system with 45 kg/cm2 from a exterior botlle of air.
Listen to air leaks first. If no leaks heard ..
Test gear.
If  all the air in the system goes away and gear not moving completely up, the gear handle valve need to be fixed.
Cheers
2017-08-20 4:00 GMT+00:00 airmanv2 <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)>:
Hello
please help
best regards
Bruno
Fly safe
Pedro Cerveira Pinto
dsavarese0812(at)bellsout
PostPosted: Sun Aug 20, 2017 6:53 am    Post subject: gear retraction problem Reply with quote
Highly probable it is a bad check valve as previously described.
Dennis
From: Pedro Cerveira Pinto <cerveirapinto(at)gmail.com>
To: yak-list(at)matronics.com
Sent: Sunday, August 20, 2017 7:33 AM
Subject: Re: gear retraction problem
Test gear.
Cheers
Hello
please help
best regards
Bruno
Fly safe
http://forums.matronics.com/ viewtopic.php?p=471988#471988
List" rel="noreferrer" target="_blank">http://www.matronics.com/ Navigator?Yak-List
rel="noreferrer" target="_blank">http://www.matronics.com/ contribution
dantpayne(at)icloud.com
PostPosted: Mon Aug 21, 2017 1:45 pm    Post subject: gear retraction problem Reply with quote
Call me
423-682-1408
-Dan
On Aug 20, 2017, at 12:00 AM, airmanv2 <bruno.blanchard2(at)gmail.com> wrote:
Hello
please help
best regards
Bruno
Fly safe
wlannon(at)shaw.ca
PostPosted: Mon Aug 21, 2017 5:39 pm    Post subject: gear retraction problem Reply with quote
Hi Bruno;
As Dennis and others have already suggested your problem is very likely a
check valve on the LH firewall that is leaking internally and allowing
normal operating system air pressure to pressurize the emergency system
which of course goes directly to Gear Down.
Not an unusual failure and, as Bob Schroeder noted, could be an indicator
of other moisture related problems as well.
See the attached schematic for location.
A good practice to avoid moisture related failure of course is to replace
your water filter innards on a regular basis. That periodicity will be
dependent to a large degree on relative humidity in your operating area.
Also a very good practice to check your brake system moisture trap (snot
valve) on a regular basis, preferably after every flight. If you find
moisture here your water filter servicing period is not adequate.
Walt
 Filesize:  643.81 KB
 Viewed:  23487 Time(s)
airmanv2
PostPosted: Tue Aug 22, 2017 10:37 pm    Post subject: Re: gear retraction problem Reply with quote
Hi ,
thank you for your advices.
we raise the plane and tested the gear retraction.
it was ok with the remaining air at 25 atm, we tested up and down 4 times till the air remains at about 10 atm.
it works well that is strange.....
i ve noticed an air leak inside the main corp of the front gear handle when gear up position,
perhaps the front gear handle to replace ?
what do you think about that Doug?
Best regards
Bruno
Fly safe
PostPosted: Wed Aug 23, 2017 12:31 am    Post subject: gear retraction problem Reply with quote
3 questions.
- did you do and emergency gear extension test? From your description of how you accomplished the gear retraction test, you did not mention you tested the emergency gear extension.
- did you try retracting and extending the gear from the rear cockpit?
- if you did attempt to retract and extend the gear from the rear cockpit, did you listen for for the same air leak you heard coming from the front cockpit?
Dennis
On Aug 23, 2017, at 1:37 AM, airmanv2 <bruno.blanchard2(at)gmail.com> wrote:
Hi ,
Best regards
Bruno
Fly safe
http://forums.matronics.com/viewtopic.php?p=472081#472081
dougsappllc(at)gmail.com
PostPosted: Wed Aug 23, 2017 8:54 am    Post subject: gear retraction problem Reply with quote
What do I think???  I think you seem to be a person willing to take risks which are way out of proportion to the reward.  However that being said, it would appear that you are in need of replacing your QSF-2A valve---OR---- you have a gear actuator leaking and that air is venting out of your front gear valve.  Dennis asks good questions, answers will help sort this all out.
Doug
Virus-free. www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Tue, Aug 22, 2017 at 11:37 PM, airmanv2 <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)> wrote:
Hi ,
Best regards
Bruno
Fly safe
Dawg
PostPosted: Wed Aug 23, 2017 9:22 am    Post subject: gear retraction problem Reply with quote
when u have lemons u make lemonade. We do the best we can with what we have.
Creative.
On Aug 24, 2017, at 01:53, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Doug
Hi ,
Best regards
Bruno
Fly safe
Dawg
wlannon(at)shaw.ca
PostPosted: Wed Aug 23, 2017 9:38 am    Post subject: gear retraction problem Reply with quote
Cute!! Of course you do this every year to comply with your Annual
Inspection requirements.
Walt
airmanv2
PostPosted: Wed Aug 23, 2017 11:38 am    Post subject: Re: gear retraction problem Reply with quote
Hello again,
so I've made a flight this evening and the same problem appears again: after take off the gear do not retract.., visualy from outside, the main gear moved about 30° from vertical position. Gear handle was positionned down , 3 greens and land safely .
yesterday evening when acft was raised, I've done 4 test up/down and its look like good. pressure at the beginning was 25 and at the 4th 12 remaining .`
I do not test the emergency extension.
its is not possible to move the rear gear handle as the UK CAA blocked it as also for the Flaps rear handle.. (Im under UK registration)
this morning i refiled the air bottle at 45atm before this evening start up, i took off with 35 and landed also with about 35 atm
the QS2 valve isn't for the brake repartition?
thanks for help
Bruno
Fly safe
PostPosted: Wed Aug 23, 2017 11:58 am    Post subject: gear retraction problem Reply with quote
Bruno,The correct p/n is QSF-2A of which there are three in your aircraft, both flap valves and the fwd gear valve.
You are correct the QS2 is the brake differential valve in the belly.
Doug
On Wed, Aug 23, 2017 at 12:38 PM, airmanv2 <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)> wrote:
Hello again,
thanks for help
Bruno
Fly safe
http://forums.matronics.com/viewtopic.php?p=472104#472104
hkgibby(at)yahoo.com
PostPosted: Wed Aug 23, 2017 12:38 pm    Post subject: gear retraction problem Reply with quote
Bruno-
Recommend you pull and check all 8 diverter valves (2 per gear and two for flap control) and rebuild or replace as necessary. Most likely your issue.
Hoot
On Aug 23, 2017, at 3:38 PM, airmanv2 <bruno.blanchard2(at)gmail.com> wrote:
Hello again,
thanks for help
Bruno
Fly safe
jblake207(at)comcast.net
PostPosted: Thu Aug 24, 2017 5:02 am    Post subject: gear retraction problem Reply with quote
Sounds like the same issue I had... turned out to be main gear actuators. Doug Sapp rebuilt them and no problems since. JB
Sent: Wednesday, August 23, 2017 2:57:55 PM
Subject: Re: Re: gear retraction problem
Bruno, The correct p/n is QSF-2A of which there are three in your aircraft, both flap valves and the fwd gear valve.
Doug
Hello again,
thanks for help
Bruno
Fly safe
PostPosted: Thu Aug 24, 2017 5:21 am    Post subject: gear retraction problem Reply with quote
Hi again Bruno. As I anticipated you have a leak in the gear handle valve. Dismount and replace the O Ring inside. Simple as that.
Em 23/08/2017 07:41, "airmanv2" <bruno.blanchard2(at)gmail.com (bruno.blanchard2(at)gmail.com)> escreveu:
Hi ,
Best regards
Bruno
Fly safe
Ernie
PostPosted: Thu Aug 24, 2017 5:27 am    Post subject: gear retraction problem Reply with quote
That simple huh?
On Thu, Aug 24, 2017 at 9:25 AM Pedro Cerveira Pinto <cerveirapinto(at)gmail.com (cerveirapinto(at)gmail.com)> wrote:
Hi ,
Best regards
Bruno
Fly safe
PostPosted: Thu Aug 24, 2017 5:29 am    Post subject: gear retraction problem Reply with quote
Pedro,
I'm assuming you've disassembled a gear/flap selector valve beforesince
you said to replace the O-ring?
If Bruno hasn't tested the system the way I suggested, he may be just
spinning his wheels. ie: did he do a gear retraction test with the rear
gear selector (with the front in neutral of course) and was there air
leaking from the rear gear selectorwhen he did this test? If yes, the
problem is not the front gear selector.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 8/24/2017 9:21 AM, Pedro Cerveira Pinto wrote:
Hi again Bruno.
<mailto:bruno.blanchard2(at)gmail.com>> escreveu:
<bruno.blanchard2(at)gmail.com <mailto:bruno.blanchard2(at)gmail.com>>
Hi ,
Best regards
Bruno
Fly safe
<http://forums.matronics.com/viewtopic.php?p=472081#472081>
marty.jpm(at)gmail.com
PostPosted: Thu Aug 24, 2017 5:56 am    Post subject: gear retraction problem Reply with quote
Hi,
The same for me on my YAK 52 in France few weeks ago.  Bruno DUCREUX fixed it the same way.
JP
Le 24 août 2017 15:08, "JON" <jblake207(at)comcast.net (jblake207(at)comcast.net)> a écrit :
From: "doug sapp" <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)>
Subject: Re: Yak-List: Re: gear retraction problem
Doug
Hello again,
thanks for help
Bruno
Fly safe
Harv
PostPosted: Tue Aug 29, 2017 9:36 am    Post subject: Re: gear retraction problem Reply with quote
Bruno
I have the sister of your aircraft and of course served together in the PLA and also have the restricted rear gear and flap function as its a mandatory modification required by the UK CAA.
I would remove the rear cockpit gear restrictor plate and do the test Dennis has given as the will test both gear handle valves. It's good practice to excercise the rear cockpit one periodically, refit handle restrictor plate after tests.
Doug sells kits to rebuild the diverter valves and I did all mine when we brought the a/c onto the UK register. There was corrosion in about three of them so they were replaced and upgraded.
Good luck
Goto page 1, 2  Next
Page 1 of 2
