Z13/8 VS Z12
donvansanten(at)gmail.com
PostPosted: Tue Aug 15, 2017 4:00 pm    Post subject: Z13/8 VS Z12 Reply with quote
Listers,
Roughly eight months ago I asked a question relating to the Z12 diagram. I stated that I have Z13/8 system and was considering changing to the Z12 to take advantage of the additional power that the SD20 alternator offers.
Bob responded that he would not recommend this as the Z13/8 offers more levels of protection. I decided to try to add the added layers of protection to the Z12.Battery
I am using two PMAGS, the second edition versions that are powered by their internal alternators as long as the engine rpm remains above 700.
My dual EFIS system uses the TCW backup battery system. The backup functions as a third power source for the EFIS system. More importantly it acts as a brown out battery to avoid EFIS rebooting which would cause me to have no oil pressure information immediately after engine start.
In the end I decided to build the Z12 without the E Bus or the Battery Bus. I would like to know what failure modes the Z13/8 would handle that the Z12 as described would not.
Thanks in advance for the information as well as any constructive
criticism.
Don
PostPosted: Tue Aug 15, 2017 7:15 pm    Post subject: Re: Z13/8 VS Z12 Reply with quote
I do not know the answer to your question, but I see nothing wrong with your plan, which is how many aircraft are wired except with the addition of a second alternator.
Joe Gores
rick(at)beebe.org
PostPosted: Wed Aug 16, 2017 7:56 am    Post subject: Z13/8 VS Z12 Reply with quote
A timely question for me. I have a 2001 GlaStar that is about to get a
glass panel upgrade. I bought a B&C BD410-H alternator to replace the
vacuum pump. Since I believe that would easily be able to power the
entire plane and I don't have an engine with electronic ignition I was
leaning toward Z12 with no endurance bus. However I've also been
studying Z13 to see if it makes more sense. I'm open to opinions on what
to do in this relatively green-field application.
--Rick
On 8/15/2017 4:59 PM, don van santen wrote:
Listers,
offers.
criticism.
Don
PostPosted: Thu Aug 17, 2017 8:28 am    Post subject: Z13/8 VS Z12 Reply with quote
At 06:59 PM 8/15/2017, you wrote:
Listers,
I'm trying to recall the context of that recommendation . . .
but let's pretend like it didn't happen and start from
scratch . . .
I am especially fond of Z13/8 because it offers the lowest
cost, lightest weight, failure tolerant architecture
that exploits the oft-ignored vacuum pump drive pad
on aircraft engines.
Like ALL constellations of hardware, Z13/8 is not without
limits. The major feature being the limits of an SD8 alternator
to carry anticipated endurance loads.
I am using two PMAGS, the second edition versions that are powered by their internal alternators as long as the engine rpm remains above 700. My dual EFIS system uses the TCW backup battery system. The backup functions as a third power source for the EFIS system. More importantly it acts as a brown out battery to avoid EFIS rebooting which would cause me to have no oil pressure information immediately after engine start.
Z12 is a derivative of a band-aid pasted
onto the architecture of TC aircraft that
left the factory with one battery and one
alternator. It too depends on the availability
of a AND20000 drive pad turning at some useful
RPM.
The only difference is the AeroElectric addition
of an E-bus.
The obvious advantage of Z12 over Z13/8 is the greater
support for endurance loads. Unlike Z13/8 + Ebus
combination even allows you to eliminate battery
contactor current from endurance loads. Extra
snort available from the SD20 makes contactor load
insignificant in the endurance equation.
In my mind, the major driver for upgrading to Z12
is the size of your endurance loads. Just how
much 'stuff' needs to stay lit up during the
EN ROUTE phase of a flight that cannot be
carried by an SD8?
Recall that the first goal for adding a second alternator
is to conserve stored energy in the battery for descent,
approach and landing phase. Once you have the
airport in sight, you should be able to run a whole
panel of electro-whizzies with the battery making
up the difference.
What does your load analysis dictate? Is there no
comfortable way you can sustain en route flight
on an 8-10A endurance budget?
If not, then Z12 is the next step up . . . a
decision that totally unrelated to my personal
fondness for any other architecture.
PostPosted: Thu Aug 17, 2017 1:31 pm    Post subject: Z13/8 VS Z12 Reply with quote
Thanks for the reply.
There are many things that I find important when picking an electrical
architecture. In addition to cost, weight and failure tolerance. The
normal mission for the aircraft is more a deciding point than cost or
weight. Failure tolerance is vital.
I fly in and around four different class B air spaces. Twenty percent
of the flights involve IFR conditions anywhere from departing and
approaches only to four plus hours in hard IMC.
The cost difference is roughly $330. This is less than the cost of two fill ups.
The weight difference is roughly 3 pounds.
Therefore I will loose the 20 pounds that I put on while recovering
from an injury. I know that there would still be three extra pounds on
board, but I can live with the very slight extra cost of dragging the
extra weight around.
Now to what i consider the most important point which is failure tolerance.
After you recommended not switching from the Z13/8 to the Z20 I spent
a great deal of time/energy trying to make the Z20 as failure tolerant
as the Z13/8. I was able to find one possible area of concern,
It is my belief based only on my experience that most primary
alternator failures are the result of belt drive failures. Most FBO's
only change the belt when it breaks. I do not know any experimental
owner that routinely changes out the belt.
So if a Z20 system looses its battery for and reason as per Joe Gores,
nothing happens as the primary alternator is already running. If
during the same flight the alternator belt breaks does the secondary
come on line?
It seems to me that the bus voltage would go to zero immediately. As
the SB voltage regulator needs voltage to provide field current to
make the SD20 run I think the SD20 would not come online. (If this is
incorrect please inform me.)
If the above is correct I came up with two solutions. One is to wire
one of the TCW standby battery leads to my E BUS switch which is not
currently connected to anything and the switch to the bus connector on
the SB regulator to provide voltage until the SD20 comes online.
After that the E BUS switch would be opened.
The other option added cost and weight so it was abandoned. It was to
add an Odyssey PC310 battery switched through a 40 amp relay to the
main bus. This system would always be off during start.
Sorry for being so wordy. Do you see any serious problems with this
design excepting the possibly misunderstanding of the SB regulator
behavior under the described conditions.
Thanks again.
On Thu, Aug 17, 2017 at 9:27 AM, Robert L. Nuckolls, III
Listers,
to the Z12.Battery
scratch . . .
RPM.
of an E-bus.
carried by an SD8?
up the difference.
PostPosted: Thu Aug 17, 2017 4:44 pm    Post subject: Re: Z13/8 VS Z12 Reply with quote
Don,
It is highly unlikely that two failures will occur on the same flight: battery contactor and alternator belt, especially since battery contactors rarely fail. But let's suppose it happens. Assume the voltage regulator for the main alternator is set at 14.4 and the voltage regulator for the smaller alternator is set at 13.5 volts. Both alternators are on-line when the failure occurs, but only the main alternator has been supplying power to the aircraft because its output voltage is higher. The smaller alternator has been producing voltage but no current.
When the alternator belt breaks, the system voltage will not immediately drop to zero. It will take time for the alternator to slow down and stop. Let's say it takes 0.5 seconds. During that brief time, the system voltage will fall. When it gets to 13.5 volts, the smaller alternator will start pushing current because the higher voltage from the main alternator is no longer impeding it. The smaller alternator should now supply the aircraft power, even with the battery disconnected. At least that is my theory. It needs to be confirmed with testing or refuted by Bob.
If concerned about battery contactor failure, a 40 amp relay could be connected in parallel with it (disabled during engine cranking).
A concern that I have is activation of the over-voltage protection device. Will it disable both alternators? If so, which is the greater danger, an actual over voltage condition, or the loss of both charging systems? Perhaps the over-voltage set-point for main alternator could be one or two volts less than the set-point for the smaller alternator.
Joe Gores
PostPosted: Thu Aug 17, 2017 5:22 pm    Post subject: Z13/8 VS Z12 Reply with quote
Thanks Joe,
That is what I expected/hoped for. The additional two feet of wire and
1 butt splice that allows the TCW backup (already installed) to add
another layer with less than $5 cost and less than 15 ounces of added
weight.
Anyone interested in why the TCW backup is already installed can me
their phone number to the listed email address and I will call and
explain. The explanation is too long to put it on the list.
On Thu, Aug 17, 2017 at 5:44 PM, user9253 <fransew(at)gmail.com> wrote:
Don,
Joe Gores
http://forums.matronics.com/viewtopic.php?p=471947#471947
PostPosted: Fri Aug 18, 2017 7:55 am    Post subject: Z13/8 VS Z12 Reply with quote
At 10:54 AM 8/16/2017, you wrote:
--> AeroElectric-List message posted by: Rick Beebe <rick(at)beebe.org>
A timely question for me. I have a 2001 GlaStar that is about to get a glass panel upgrade. I bought a B&C BD410-H alternator to replace the vacuum pump. Since I believe that would easily be able to power the entire plane and I don't have an engine with electronic ignition I was leaning toward Z12 with no endurance bus. However I've also been studying Z13 to see if it makes more sense. I'm open to opinions on what to do in this relatively green-field application.
Do your load analysis.
There are examples of Excel spread sheet load studies
along with some paper forms you can use as
tools for crafting your own load analysis.
http://tinyurl.com/9rt6ymn
The critical number for your Z12 vs Z13 decision
is the last column on
http://tinyurl.com/7jqypwj
you fill out TWO of these . . . one for
the battery bus, one for the bus that's
powered during main alternator out operations.
The sum of those numbers needs to be on the
order of 8A or less. The accessories you
choose to operate in this mode depends
on your skills for comfortably sustaining
en route flight to airport of intended
destination.
Once the airport is in sight, you can turn
on any other goodies that improves your
performance during approach phase . . .
you'll have plenty of battery left
to support the op.
PostPosted: Fri Aug 18, 2017 8:06 am    Post subject: Z13/8 VS Z12 Reply with quote
At 07:44 PM 8/17/2017, you wrote:
Don,
In Part 23 aircraft (vast majority of
single engine aircraft), system reliability
studies (statistical analysis) are not required
and stacked failures are never considered.
The likelihood of compounding failures
occurring while consuming one tank full of fuel is
exceedingly remote. Some failures, like
belts breaking, are WWwwaaayyy down on the
list of concerns . . . anyone who suffers
a broken belt has been ignoring it too
long.
