Comfortable Cushions?
Rick Moss
PostPosted: Mon Aug 14, 2017 1:21 pm    Post subject: Comfortable Cushions? Reply with quote
Hi all, my XS TG wasn't too comfortably upholstered when I bought it; I replaced the seat cushion foam with fairly expensive Confor memory foam layers as advised by the BGA for gliders; I still find that after a couple of hours, I'm pretty uncomfortable. Can anyone recommend a source of nice thick comfortable seat pads or just the foam to refill my existing ones?
TIA,
Rick
John Wighton
PostPosted: Tue Aug 15, 2017 12:26 am    Post subject: Re: Comfortable Cushions? Reply with quote
A change in seat cushion type may be only part of the issue. I have used the Confur type memory foam but use a profile in the lumbar region to prevent backache. After 3+ hours my bottom goes a bit dumb, this l think would happen whatever the seating arrangement. l don't get the backache now and attribute this to the correct (for me) lumbar shape. I had some additional bolstering added to the back cushion which helps lateral location.
Talk to Wendy at info(at)wstrimmingandupholstery.com about upholstery etc.
JW
John Wighton
Europa XS trigear G-IPOD
h&jeuropa
PostPosted: Tue Aug 15, 2017 3:22 am    Post subject: Re: Comfortable Cushions? Reply with quote
Rick,
We still love our Oregon Aero seat cushions after 12 years and 900 hours.
They are comfortable even on long days with two 3 to 4 hour legs.
Jim & Heather
wdaniell.longport(at)gmai
PostPosted: Tue Aug 15, 2017 3:32 am    Post subject: Comfortable Cushions? Reply with quote
I flew a katana over the weekend with sheepskin and a very thin layer of foam.   Pretty comfortable.Plan to put the same in hj460.
Will
On Aug 15, 2017 03:29, "John Wighton" <john(at)wighton.net (john(at)wighton.net)> wrote:
--> Europa-List message posted by: "John Wighton" <john(at)wighton.net (john(at)wighton.net)>
Talk to Wendy at info(at)wstrimmingandupholstery.com (info(at)wstrimmingandupholstery.com) about upholstery etc.
JW
John Wighton
http://forums.matronics.com/viewtopic.php?p=471871#471871
carlp101
PostPosted: Wed Aug 16, 2017 3:39 am    Post subject: Re: Comfortable Cushions? Reply with quote
I find the same problem with my standard Europa cushions. I was considering using confor foam and found this useful link:
http://www.kitplanes.com/issues/31_9/builder_spotlight/seat_foam_21072-1.html
In the end I found that for me (at 6') the problem is down to the lack of thigh support, resulting in all my weight being supported through my bottom. I discovered that placing a reasonably supportive standard cushion under my thighs (but not under my bottom) helped immensely. It allows my weight to be distributed over a larger area. I now need to replace my standard Europa cushions with something that provides the same solution.
I've attached some pictures from Fred Klein's solution. The "Rolls Royce" of seats in my opinion. You can see the additional thigh support he has.
Hope this helps.
Carl
G-URMS
 Filesize:  70.91 KB
 Viewed:  8856 Time(s)
 Filesize:  75.88 KB
Fred Klein
PostPosted: Wed Aug 16, 2017 2:00 pm    Post subject: Comfortable Cushions? Reply with quote
Cheeks, thigh and lower lumbar support guided my choices…seat w/ 1” green + 1” blue + foam wedges…
[img]cid:ED9F50F5-3A17-418E-B108-A25609017FB2[/img]
[img]cid:A7F65B90-1242-4337-8A31-06D1EE095B49[/img]
[img]cid:BAEBCF6E-3648-4214-A4E4-5F0797F0DCFA[/img]
On Aug 14, 2017, at 2:21 PM, Rick Moss <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)> wrote:
--> Europa-List message posted by: "Rick Moss" <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)>Hi all, my XS TG wasn't too comfortably upholstered when I bought it; I replaced the seat cushion foam with fairly expensive Confor memory foam layers as advised by the BGA for gliders; I still find that after a couple of hours, I'm pretty uncomfortable. Can anyone recommend a source of nice thick comfortable seat pads or just the foam to refill my existing ones?TIA,RickRead this topic online here:http://forums.matronics.com/viewtopic.php?p=471867#471867
 Filesize:  67.96 KB
 Viewed:  8845 Time(s)
 Filesize:  70.91 KB
 Filesize:  63.52 KB
carlp101
PostPosted: Thu Aug 17, 2017 12:45 am    Post subject: Re: Comfortable Cushions? Reply with quote
Hi Fred.
Any chance you could make me a set? I have a Europa Tri-Gear classic.
Carl
Fred Klein
PostPosted: Thu Aug 17, 2017 8:39 am    Post subject: Comfortable Cushions? Reply with quote
On Aug 17, 2017, at 1:45 AM, carlp101 <cparkinson(at)cisc-uk.com (cparkinson(at)cisc-uk.com)> wrote:
Sorry Carl…I appreciate the “Rolls Royce” compliment, but I’m slammed w/ way too many obligations.
I would, however, be happy to share more pixs and particulars…I think the issues of thigh support & lumbar support are key to comfort.
Fred
