kearney
Posted: Mon Aug 14, 2017 10:05 am Post subject: Alternator Question - Redux |
Thank you for your comments and explanations they were most helpful.
I have started another thread just so things aren't too cluttered. I would like to a follow up questions just to make sure I understand things so please forgive me if it seems repetitive.
To clarify I was wondering what would happen if the Bat/Alt Master Switch failed completely. Would this not immediately remove all power to the main bus on the Z12? If so, how would the aux alternator field be energized if located on the main bus?
Cheers
Les
donvansanten(at)gmail.com Guest
Posted: Mon Aug 14, 2017 10:37 am Post subject: Alternator Question - Redux |
Les,I added a PC 310 battery through a 40 amp relay to my main bus on the Z12. It is switched by the switch that fed my e bus. I no longer have the e bus but still have dual power feeds to the main bus.
On Aug 14, 2017 11:13 AM, "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote: | Quote: | --> AeroElectric-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=471857#471857
Posted: Mon Aug 14, 2017 11:17 am Post subject: Alternator Question - Redux |
At 01:05 PM 8/14/2017, you wrote:
| Quote: | --> AeroElectric-List message posted by: "kearney" <kearney(at)shaw.ca>
To clarify I was wondering what would happen if the Bat/Alt Master Switch failed completely. Would this not immediately remove all power to the main bus on the Z12? If so, how would the aux alternator field be energized if located on the main bus? |
But how does it fail completely? Get one of these
switches, choose any combinations of force/tools
you choose to disassemble/emulate a 'failure'.
Once your switch is sufficiently 'failed', then
deduce how the same condition can be repeated in
your airplane.
Most 'failures' are soft and progressive. Something
becomes intermittent or quits and is usually a function
of age and environmental conditions . . . not service
stresses.
I have only once in my lifetime had to diagnose and
deal with 'failure' of a Honeywell toggle switch in
an airplane. It was a spring loaded toggle used as
press to test on BeechJet ground fault system.
The OPERATING current carried by this switch was
a few tens of milliamps. Upon opening the panel
and testing the switch with a meter, it was indeed
found to be open circuit on the normally open
side.
The tech I was working with was ready to start
filling out the paperwork to bet a new switch.
I asked him to hold off for a few minutes. I
got a small bench supply out of the lab and
drug an extension cord into the airplane. I
unhooked one wire from the switch so as not
to 'power the airplane' and put 28v at 10A
current limit on the switch. I then
wiggled the switch until it suddenly began
to show continuity across the 'failed' contacts.
In this case, the relatively high-current,
silver-cadmium contacts of the power rated
switch had never been blessed with enough
current flow to keep its contacts clean!
After a few dozen 10A whacks to the switch,
I put the wire back on and we signed off
the squawk. Didn't get to charge the customer
$200 for a new switch.
We have seen some switch failures on the
List.
http://tinyurl.com/yapmtot4
http://tinyurl.com/yd4tz8qd
We also had a rash of loose terminals
at the riveted joints on the Carling
toggle switches.
But none of those failures manifested as
a sudden hazard to flight.
the point is, be cautious about stirring
the worry-pot with "what ifs?" The the vast
majority of what ifs thrashed around on the
various forums are not well understood nor
backed up with historical data.
I wouldn't hazard a guess as to how many
GA aircraft have been flown over the last 100
years . . . certainly hundreds of thousands
if not millions. Yet system architectures and
materials used have not materially changed.
From the time they put the first battery in
a C120 to make it a C140 . . . up through the
pressurized 1986 P210, the battery contactors
have been made on the same, commercial grade
production lines.
[img]cid:.0[/img]
The rocker switches have the same back-side
guts as the toggle switches sold by B&C and
made by Carling.
[img]cid:.1[/img]
I'm certain that this same constellation
of components persisted for a decade or
two after 1986.
The point is, there is a field history in both
hardware and architectures that makes our
job here on the List easier . . . it suggests
that we need not waste a lot of time hypothesizing
and mitigating every conceivable component failure
while concentrating on failure tolerant architectures.
Z-12 as published represents a well considered
and field proven solution to the single battery,
two-alternator option for a light airplane.
69.59 KB |
4780 Time(s) |
61.83 KB |
4780 Time(s) |
Posted: Mon Aug 14, 2017 6:08 pm Post subject: Re: Alternator Question - Redux |
After the engine is started and running, the battery is no longer supplying electrical power to the aircraft. The alternator is. And the alternator is supplying power to its own field. If the battery is then disconnected, nothing changes. The alternator continues to power the electrical system including the alternator field. Without the battery, the voltage might be unstable and vary plus and minus one volt or so from the voltage regulator set point. But electrical loads will still work.
If both halves of the Master/Alternator switch fail simultaneously, then yes, the electrical system will go down. But that switch would have to completely fall apart inside in order for that to happen, which is unlikely. If it did fall apart, it would most likely happen when the switch is turned on or turned off, not during cruise. I would not worry about it. There are other things more likely to fail, like the engine or prop or a pilot.
You could use Bob's favorite electrical architecture , Z-13/8. The aux alternator output connects to the battery, not directly to the bus.
_________________ Joe Gores |
