Mcabbage
Posted: Tue Aug 08, 2017 2:59 pm Post subject: Gap seal |
Hi to all.
A buddy is looking for ideas as to the best way/method to install gap seals on his Firestar2
Thanks in advance for any help.
_________________ 2007 Firestar 2 503 N203SD
Moster 185 Flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike & Northwing Stratus XP |
byoungplumbing(at)gmail.c Guest
Posted: Tue Aug 08, 2017 3:22 pm Post subject: Gap seal |
Ideas to install gap seal.
I have a vls brs.   The tray for the brs is mounted to the motor mount tube...  I've riveted a  7/8 tube to the brs mounting plate... As I built ribs for the gap seal they were built in a manner that I could rivet an internal brace to the 7/8 tube...   Then built a faring between the top of the windshield and bottom of the gap seal,  riveting in place....   The sides of the gap seal are 1/4 to 3/8 inches from the wings..
I can fold the wings without removing the gap seal. Â Â
Boyd Young
1.79 MB |
18576 Time(s) |
lcottrell
Posted: Tue Aug 08, 2017 5:51 pm Post subject: Gap seal |
It would appear that Boyd and I are the only ones awake today. I purposely waited for someone smarter than myself to give you guidance. I suppose he is out flying.
I have seen three ways to do a gap seal. One is using the fabric that Kolb gives you. It works, but I never liked it.Â
The Mark III's all seem to build a solid gap seal such as described by Boyd. It works well, but I was either never smart enough to build one or too lazy. I couldn't say for sure which. It works well
The method that I used for my Firestar II is a bent tin front secured to a piece of lexan with a cut out for a motor or any thing else in the way such as my muffler. It is secured to the wings with velcro. When you take it off, just slide a towel or a piece of lexan or cardboard between the two pieces of velcro and lift it off..Â
Larry
On Tue, Aug 8, 2017 at 4:59 PM, Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Mcabbage" <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)>
Hi to all.
2007Â Firestar 2 503Â N203SD
http://forums.matronics.com/viewtopic.php?p=471635#471635
The older I get, the less tolerant I am of those who are intolerant of others.
1.37 MB |
18570 Time(s) |
1.35 MB |
18570 Time(s) |
1.26 MB |
18570 Time(s) |
gdhelton(at)gmail.com Guest
Posted: Tue Aug 08, 2017 5:54 pm Post subject: Gap seal |
Call Helen at Kolb Aircraft. She will make you a fabric gap that is held in place with super 2" wide Velcro. They work great. They hold up well. I had the old zipper type originally and these work and hold up just as well or better.
George H.
Firestar, FS# 100
14GDH
Mesick, Michigan
Have a great day!
| Quote: | On Aug 8, 2017, at 6:59 PM, Mcabbage <Mc(at)americanbuilding.com> wrote:
Hi to all.
100.43 KB |
18570 Time(s) |
Mcabbage
Posted: Thu Aug 10, 2017 10:35 am Post subject: Re: Gap seal |
Thanks guys
I'm sorry I wasn't more clear in my post.
I was looking for info on sealing the gap between the
wing and airilons. My friend said some folks are using
some kind of new strechy material that is easier to remove
if needed.
Thanks Mike
Richard Pike
Posted: Thu Aug 10, 2017 3:23 pm Post subject: Re: Gap seal |
Oh. <Grin> You want packaging tape. Check the archives, tons of entries.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu Aug 10, 2017 3:35 pm Post subject: Gap seal |
I guess some use book binding tape? I did mine per Kolbs plans using 2" Stitts polyfiber tape and polybrush. It has lasted since 1986. Still looks great! Do you want fast and easy or quality?
Have a great day! George H.
| Quote: | On Aug 10, 2017, at 2:35 PM, Mcabbage <Mc(at)americanbuilding.com> wrote:
Thanks guys
if needed.
Thanks Mike
http://forums.matronics.com/viewtopic.php?p=471716#471716
skydiveal(at)aol.com Guest
Posted: Thu Aug 10, 2017 3:51 pm Post subject: Gap seal |
Per kolb if going the fast way
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
Date: 8/10/17 7:23 PM (GMT-05:00)
Subject: Kolb-List: Re: Gap seal
--> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net>
Oh. You want packaging tape. Check the archives, tons of entries.
Richard Pike
Kingsport, TN 3TN0
Forgiving is tough. Being forgiven is wonderful.
http://forums.matronics.com/viewtopic.php?p=471724#471724
_-============================================================
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
1.71 MB |
18456 Time(s) |
Posted: Thu Aug 10, 2017 3:52 pm Post subject: Gap seal |
Works great
Richard Pike
Kingsport, TN 3TN0
_-=
_-=
_-=
_-=
1.71 MB |
18456 Time(s) |
wakataka
Posted: Fri Aug 11, 2017 5:22 pm Post subject: Re: Gap seal |
Brian Carpenter has come up with a great way to make gap seals from foam pool noodles. He pulls the noodles through a heated die.
https://electricmotorglider.com/2017/07/15/57-80-10-large-gap-seal/
The resulting foam shape fits snugly between the aileron tube and the trailing edge of the wing and completely fills in the profile of the wing shape between the trailing edge and the aileron.
I've also used a urethane tape designed for sealing gaps in doors and windows. I think I got it at Ace Hardware. It's slightly stretchy and very sticky. I've had it in place for over 5 years and none of it has fallen off. The gap on the airplane I have it on may be smaller than on the Kolb.
_________________ There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact.
Mark Twain |
Mcabbage
Posted: Sat Aug 12, 2017 4:18 am Post subject: Re: Gap seal |
Pretty interesting.
Thank you guys.
mojavjoe
Posted: Sat Aug 12, 2017 4:28 am Post subject: Gap seal |
I tried making the noodle gap seals but because of the way Kolb ailerons are hinged they pop out.
Joe
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Friday, August 11, 2017 9:22:48 PM
Subject: Re: Gap seal
--> Kolb-List message posted by: "wakataka" <wakataka(at)charter.net>
Mark Twain
http://forums.matronics.com/viewtopic.php?p=471770#471770
ceengland7(at)gmail.com Guest
Posted: Sat Aug 12, 2017 5:11 am Post subject: Gap seal |
They *look* like they would cause significantly increased control system drag, due to friction between/among the fixed & moving surfaces and the noodle. I guess that in some a/c designs, it might not be noticeable.
On Sat, Aug 12, 2017 at 7:28 AM, <mojavjoe(at)comcast.net (mojavjoe(at)comcast.net)> wrote:
| Quote: | I tried making the noodle gap seals but because of the way Kolb ailerons are hinged they pop out.
Joe
From: "wakataka" <wakataka(at)charter.net (wakataka(at)charter.net)>
To: "kolb-list" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
--> Kolb-List message posted by: "wakataka" <wakataka(at)charter.net (wakataka(at)charter.net)>
Mark Twain
