Fuse Blocks
art(at)zemon.name
PostPosted: Sat Aug 05, 2017 2:53 pm    Post subject: Fuse Blocks Reply with quote
Folks,
I need to select fuse blocks for my plane, less than 20 circuits. I found the Littelfuse POWR-BLOCK on Digi-Key and it looks cool but I have to order a zillion pieces to make a complete set of stuff that is ready to go into the plane: fuse blocks, interlocks, mounts, terminals.
Is there an easier way? Something off-the-shelf and maybe available locally? Or should I carefully get together all of the parts that I need and order the POWR-BLOCK from Digi-Key.
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
JohnCiolino(at)carolina.r
PostPosted: Sat Aug 05, 2017 3:36 pm    Post subject: Fuse Blocks Reply with quote
There is something simpler. See www.bandc.aero, look under electrical supplies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30.
Good luck/
Bearhawk Patrol
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Art Zemon
Sent: Saturday, August 05, 2017 6:53 PM
Subject: Fuse Blocks
Folks,
-- Art Z.
kjashton(at)vnet.net
PostPosted: Sat Aug 05, 2017 3:51 pm    Post subject: Fuse Blocks Reply with quote
Something like this can fit right on your panel
http://www.cooperindustries.com/content/public/en/bussmann/transportation/products/power_distribution/fuse_panels/series_15710_rearterminalatcfusepanel.html
Or do a google images search for “ATC fuse blocks” and you’ll see many other styles. Some are available at auto parts stores. I have used the 20 gang version
http://www.ebay.com/itm/NEW-Bussmann-15600-18-20-18-Position-ATC-Fuse-Panel-Block-RV-Trailer-Boat-Solar/272378729318
and also used 12 gang and 8 gang models to set up a main and essential bus.
With the 20 position version, it is also possible to cut the center conductor, silver soldered a extra tab on the end and made a main/essential bus out set up out of it.
-Kent
On Aug 5, 2017, at 6:53 PM, Art Zemon <art(at)zemon.name> wrote:
Folks,
-- Art Z.
art(at)zemon.name
PostPosted: Sat Aug 05, 2017 3:58 pm    Post subject: Fuse Blocks Reply with quote
That's exactly what I need! Thanks.
    -- Art Z.
Sent from my phone. Please excuse brevity and bizarre typos.
On Aug 5, 2017 6:54 PM, "John Ciolino" <JohnCiolino(at)carolina.rr.com (JohnCiolino(at)carolina.rr.com)> wrote:
Good luck/
ronburnett(at)charter.net
PostPosted: Sat Aug 05, 2017 4:17 pm    Post subject: Fuse Blocks Reply with quote
Art,
I got mine at West Marine.
Ron Burnett
May you have the Lord's blessings today!Sent from my iPad
On Aug 5, 2017, at 6:57 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
-- Art Z.
Good luck/
stuart(at)stuarthutchison
PostPosted: Sat Aug 05, 2017 8:32 pm    Post subject: Fuse Blocks Reply with quote
SteinAir has everything - http://www.steinair.com/?search_category=&s=fuse&search_posttype=product
Cheers, Stu
On 6 Aug 2017, at 10:16, Ron Burnett <ronburnett(at)charter.net (ronburnett(at)charter.net)> wrote:
Art,
Ron BurnettMay you have the Lord's blessings today!Sent from my iPad
That's exactly what I need! Thanks. -- Art Z.Sent from my phone. Please excuse brevity and bizarre typos.
Good luck/
JOHN TIPTON
PostPosted: Sat Aug 05, 2017 10:26 pm    Post subject: Fuse Blocks Reply with quote
"SteinAir has everything" - apparently not: they don't seem to to the 16 and 20 fuse sizes !!!
----x--O--x----
On 6 Aug 2017, at 05:31 am, Stuart Hutchison <stuart(at)stuarthutchison.com.au (stuart(at)stuarthutchison.com.au)> wrote:
Cheers, Stu
Art,
Good luck/
PostPosted: Sun Aug 06, 2017 12:12 am    Post subject: Fuse Blocks Reply with quote
Sure, but two 12s = 24 … more than enough Smile
On 6 Aug 2017, at 16:25, John Tipton <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
"SteinAir has everything" - apparently not: they don't seem to to the 16 and 20 fuse sizes !!!Sent from my iPad
----x--O--x----
Cheers, Stu
Art,
Good luck/
art(at)zemon.name
PostPosted: Sun Aug 06, 2017 1:39 am    Post subject: Fuse Blocks Reply with quote
Perfect! I'll drive over soon. Nice 'n' convenient and I can support the local economy with my huge purchase Smile
Thanks, Ron.
    -- Art Z.
On Sat, Aug 5, 2017 at 7:16 PM, Ron Burnett <ronburnett(at)charter.net (ronburnett(at)charter.net)> wrote:
Art,
Mauledriver(at)nc.rr.com
PostPosted: Wed Aug 09, 2017 8:13 am    Post subject: Fuse Blocks Reply with quote
That's what I used and here are some pics of the mounting.  I have a Z-14 design (2 batts, buses, alts) so each fuse block is on a different side.  I should have just put 2 big ones in - handy for loading balancing later when the truth becomes evident.
Fuse Blocks - Mounted
I ordered my interior side panel with 2 cutouts and used a piece of lexan with hook&loop to cover over it.  There's enough room to number fuses on the fuse block.
Bill "electrical fault free 6 years later" Watson
    -- Art Z.
Good luck/
PostPosted: Wed Aug 09, 2017 11:40 am    Post subject: Re: Fuse Blocks Reply with quote
I purchased a Busman 14 fuse block. I did not like the density (fuses too far apart), the way the terminals protruded from the sides taking up panel space, and the way that the fuse sockets grip the fuses (weak grip).
So I made my own fuse block using a PCB and fuse clips. Search the web for "Keystone 3522".
My fuse holder has 18 fuses, 2 of which are spares. The wires exit straight out the back. The 8 small screws define the perimeter of the fuse block behind the panel. My rule is to never replace a fuse while flying and never with the master switch turned on. The fuse block is mounted in the lower right hand corner of the instrument panel in front of the passenger. The fuses glow when blown, except the 2 amp. Vans sells the glow fuses.
 Filesize:  268.71 KB
 Viewed:  12926 Time(s)
Joe Gores
gilles.thesee(at)free.fr
PostPosted: Thu Aug 10, 2017 2:20 am    Post subject: Fuse Blocks Reply with quote
Hi Joe,
Most interesting, congratulations !
I wish I could see the back of your fuseblock !
What did you use for the bus itself ? Metal strip, solid wire ?
Did you use Faston tabs to attach the wires ?
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
chaskuss(at)yahoo.com
PostPosted: Thu Aug 10, 2017 7:32 am    Post subject: Fuse Blocks Reply with quote
I purchased the fuse blocks linked below. The electrical connections are mounted from the rear. The blocks also come with a plastic cover to shield the fuses. This comes in very handy if you decide to mount the fuse block horizontally. I can supply photos of how I mounted them in my RV-8A
See
http://www.mihdirect.biz/
On Thu, 8/10/17, GTH <gilles.thesee(at)free.fr> wrote:
Subject: Re: Re: Fuse Blocks
Date: Thursday, August 10, 2017, 6:20 AM
écrit :
> --> AeroElectric-List message
posted by: "user9253" <fransew(at)gmail.com>
"Keystone 3522".
back.
Hi Joe,
fuseblock !
wires ?
Best regards,
Gilles
The AeroElectric-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
PostPosted: Thu Aug 10, 2017 11:50 am    Post subject: Re: Fuse Blocks Reply with quote
Here you go Gilles, a picture of the rear of the fuse block. Do not let the reflection in the aluminum confuse. In the reflection, the wires can be seen making a 180 degree turn before being soldered to the PCB. No worry about stiff soldered wires breaking because they are no longer stiff where exiting through the holes in the board. The top 3 rows are one continuous copper PCB layer on both sides of the board. The solder mask hides the copper. The top 3 rows really are continuous. The main power bus is nothing more than the copper layers on the circuit board. I had considered soldering a 6 inch long #14 or #12 AWG wire along the bus to increase its capacity. I did not because my RV-12 only uses about 10 amps total. The #12 wire from the aircraft battery contactor is spliced to 4 each of 18 AWG wires that are soldered to the top row of the bus. The alternator (dynamo) is similarly connected with 4 of 18 AWG wires to the bottom of a 30 amp fuse (back fed to the bus). This fuse block has about an hour of Hobbs time. So far no problems.
 Filesize:  213.12 KB
 Viewed:  12891 Time(s)
Joe Gores
PostPosted: Fri Aug 11, 2017 6:36 am    Post subject: Fuse Blocks Reply with quote
Thank you Joe, you gave me ideas !
To everybody, how about installing ANL current limiters on a PCB ?
Along with the ATO fuses, of course.
Thank you,
Best regards,
Gilles
PostPosted: Mon Aug 14, 2017 8:54 am    Post subject: Fuse Blocks Reply with quote
At 09:34 AM 8/11/2017, you wrote:
--> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr>
If you're building a custom power distribution
center, consider the miniature ANL current
limiters like these . . . much smaller
and readily available.
http://tinyurl.com/y9427ggp
PostPosted: Wed Aug 16, 2017 1:25 pm    Post subject: Fuse Blocks Reply with quote
Hello Bob,
Great find, thank you !
I imagine it is possible to solder screws through an extra thick PCB to hold those ANLs.
Thanks again,
Best regards,
Gilles
