IVO Prop current limiter
Goto page Previous  1, 2, 3, 4
paulf(at)hughes.net
PostPosted: Tue Jul 11, 2017 1:51 pm    Post subject: IVO Prop current limiter Reply with quote
I've got code written for the PIC as well. I may need to tweak the
voltage and time parameters to get exactly 0.5v and 0.5s when we get
down to the actual circuit. But that's easily done in EEPROM values.
Paul
On 7/10/2017 10:11 PM, Robert L. Nuckolls, III wrote:
I proofed the ecb layout I posted. I'll get some
made. I'll have 5 or so boards to 'share' with
anyone who wants to participate in beta-testing
the hardware/software. Boards should be in
about Wednesday.
alec(at)alecmyers.com
PostPosted: Tue Jul 11, 2017 2:03 pm    Post subject: IVO Prop current limiter Reply with quote
can you post your code for review?
On Jul 11, 2017, at 17:50, Paul A. Fisher <paulf(at)hughes.net> wrote:
I've got code written for the PIC as well. I may need to tweak the voltage and time parameters to get exactly 0.5v and 0.5s when we get down to the actual circuit. But that's easily done in EEPROM values.
Paul
about Wednesday.
paulf(at)hughes.net
PostPosted: Tue Jul 11, 2017 2:29 pm    Post subject: IVO Prop current limiter Reply with quote
Certainly. Bob, could you please add the IVO Prop controller software
to your site with the rest of the files? It's currently in our Dropbox
share.
Please be kind on your comments on the code - I haven't tried to clean
it up to make it presentable - it's still at version 0.03, so I may
still do quite a bit of tweaking before we declare v1.0. But I am
interested in anything you see that we could improve on. Thanks!
Paul
Paul
> about Wednesday.
> Bob . . .
PostPosted: Tue Jul 11, 2017 3:31 pm    Post subject: IVO Prop current limiter Reply with quote
At 05:28 PM 7/11/2017, you wrote:
--> AeroElectric-List message posted by: "Paul A. Fisher" <paulf(at)hughes.net>
Certainly. Bob, could you please add the IVO Prop controller software to your site with the rest of the files? It's currently in our Dropbox share.
Sorry for the delay . . . was in Wichita putting the
finishing touches on a staircase to my sister's deck.
Paul's software offering can be found at:
http://tinyurl.com/yby3waw6
You guys might be thinking about how you'd like to
configure the 'elegant' package. The ECB I've
crafted will lend itself to either an open-
to-the-sky style of installation, like our
old AEC9005 . . .
[img]cid:7.1.0.9.0.20170711182114.06b813d8(at)aeroelectric.com.0[/img]
of course, this can be put into some form
of enclosure with the connector extending
through the wall.
There's a kinda cute extruded aluminum
enclosure offered from several sites on
the 'net . . .
[img]cid:7.1.0.9.0.20170711182114.06b813d8(at)aeroelectric.com.1[/img]
The final configuration could be converted to surface
mount components. Connections brought out on flying
leads through a grommet.
The advantages for thru-hole components is that
more people might be encouraged to take on
the project. Anyone spotted another option?
 Filesize:  94.79 KB
 Viewed:  201537 Time(s)
 Filesize:  171.37 KB
papa11(at)centurylink.net
PostPosted: Tue Jul 11, 2017 4:06 pm    Post subject: IVO Prop current limiter Reply with quote
--> AeroElectric-List message posted by: "Paul A. Fisher" <paulf(at)hughes.net> (paulf(at)hughes.net)
  old AEC9005 . . .
[img]cid:part2.25F1FA82.93F971E1(at)centurylink.net[/img]
  through the wall.
  the 'net . . .
[img]cid:part3.D757C768.2989C52D(at)centurylink.net[/img]
-----------------  Hi Bob I would like one of the IVO prop current limiters if you have one left .    Emil Radtke pulsar111 with Jabriu 3300 engine ------------------you can send me info on this page. thank you
 Filesize:  94.79 KB
 Filesize:  171.37 KB
Eric Page
PostPosted: Tue Jul 11, 2017 5:32 pm    Post subject: IVO Prop current limiter Reply with quote
Wow -- I went to work for a two-day trip and you guys have the project all but finished!
I guess with the through-hole PCB layout done and ordered, there's probably little point in me continuing my effort to do it here. I'll lay down my pencil unless there's another way I can assist.
If it's decided to pursue a surface mount version, I'd be happy to work on that. Just say the word...
Eric
PostPosted: Tue Jul 11, 2017 7:06 pm    Post subject: IVO Prop current limiter Reply with quote
At 08:32 PM 7/11/2017, you wrote:
--> AeroElectric-List message posted by: Eric Page <edpav8r(at)yahoo.com>
wouldn't bet on that . . . but it did take a quantum
jump
Let's see how the
The board I have is about 2x the area that
would be required for SM components . . . and
if I were tooling up to build quantities, I'd
go SM. But if we're wanting to maximize penetration
into the DIY community, TH is probably better.
Once the hardware and software are successfully
married, an SM version in the smaller extruded
aluminum enclosure might encourage someone to
build up small quantities for sale . . . to
be sure, the plug-n-play community is larger than
the DIY community.
B&C might be intreseted in adding it to their
stable of products . . . let's see how the
project matures.
PostPosted: Tue Jul 11, 2017 7:10 pm    Post subject: IVO Prop current limiter Reply with quote
Emil, at the moment, this is a spontaneously
organized cooperation to develop the product.
The boards I mentioned are bare boards which
I will make available to individuals who will
be the beta-testers . . . they'll have to
acquire parts and assemble them.
At the moment, I have no plans to produce them
here but somebody on the List might be willing
to help you out.
PostPosted: Sat Jul 15, 2017 6:31 am    Post subject: IVO Prop current limiter Reply with quote
The boards didn't make it here yestereday . . . flight
delay . . . will be here Monday.
How do you guys want to disposition the 5 extra boards?
I'll keep one to play with. If as many as five others
want to build one, it sorta makes sense that one
person in the build group buy parts and split
up into kits.
Saves on postage, procurement $time$ and perhaps
increased opportunity for quantity breaks.
PostPosted: Sun Jul 16, 2017 3:31 pm    Post subject: IVO Prop current limiter Reply with quote
At 11:36 AM 7/15/2017, you wrote:
I would build one of those Prop limiters for my electric adj. IvoProp.
If you need someone to make the initial order for parts, I'd be happy to do that. I could disseminate the parts kits to the interested builders.
I have uploaded an illustrated bill of materials and
a parts locator to . . .
Note that the BOM does not call out a mating D-sub
connector (D15S) since each builder may choose from
either crimp or solder-cup connectors. Also missing
is a callout for a D15H hood. The builder will need
6-32 hardware to fasten the assembly down to the
mounting-surface/heat-sink.
A LED travel limit annunciator is also missing from
the BOM. Something like this might tweak your
fancy . . .
http://tinyurl.com/y8j6qrva
Unless the builder has programming capability for
the PIC chip, I'll suggest the chip not be ordered
from Digikey rather from someone in the project group
with programming tools.
I think the mechanical aspects of the data package are
now complete. I'll assemble one here as well so we can
beta-test software and compare notes.
PostPosted: Tue Jul 18, 2017 9:19 am    Post subject: IVO Prop current limiter Reply with quote
The boards are here. Thought I had all the
parts to stuff one but found a couple
of shortages. On order for delivery by
priority mail . . .
paulf(at)hughes.net
PostPosted: Tue Jul 18, 2017 11:04 am    Post subject: IVO Prop current limiter Reply with quote
Bob and all,
I've got 7 of the PIC chips in inventory today, so I can program them and send them to people who want to do some beta testing.  Or I could send them all to whomever is going to be putting the kits together.  I would suggest we let Bob assemble one of the boards and do a quick check of the software before I program the rest of the chips.
Paul Fisher
  fancy . . .
PostPosted: Fri Jul 21, 2017 8:18 am    Post subject: IVO Prop current limiter Reply with quote
Got the board stuffed.
http://tinyurl.com/ycemckye
I need to get my pic programmer up and running
for a couple other programs. I'll pop a 9023 chip
and see how critter works.
Page 4 of 4
