galinhdz(at)gmail.com Guest
Posted: Sat Jul 01, 2017 9:23 am Post subject: TR-4 Main Landing Gear Wheel Assembly |
Who manufactured (and model number) the main landing gear wheel assembly for the TR4? It is for a 15X6.00-6 tire. I think it was MATCO but not sure. One of my bearing race is turning on mine and I have some wear on the axle so I may want to replace it.
THANKS!
1.92 MB |
10976 Time(s) |
2.79 MB |
10976 Time(s) |
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Sat Jul 01, 2017 11:28 am Post subject: TR-4 Main Landing Gear Wheel Assembly |
Galin
The specifications indicate Marco wheels and brakes. Pretty sure that is what are on mine.
Bob Reed
| Quote: | On Jul 1, 2017, at 12:22 PM, Galin Hernandez <galinhdz(at)gmail.com> wrote:
THANKS!
<Main Axle.jpg>
<Main Gear.jpg>
wschertz343(at)gmail.com Guest
Posted: Sat Jul 01, 2017 12:28 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
It was Matco, I am away from my documentation , but I think it was there 6” wheel, the number W-600 sticks in my mind.
Sent: Saturday, July 01, 2017 11:22 AM
Subject: TR-4 Main Landing Gear Wheel Assembly
THANKS!
Posted: Sat Jul 01, 2017 12:41 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
Found a folder, it is the W600 wheel assembly, so get the axle for that
Sent: Saturday, July 01, 2017 2:27 PM
Subject: Re: TR-4 Main Landing Gear Wheel Assembly
THANKS!
Posted: Sat Jul 01, 2017 1:45 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
That is what I thought but wanted to make sure others had the same wheels.
On Sat, Jul 1, 2017 at 3:28 PM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
| Quote: | --> KIS-List message posted by: Robert Reed <robertr237(at)att.net (robertr237(at)att.net)>
Galin
Bob Reed
> On Jul 1, 2017, at 12:22 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
> THANKS!
> <Main Axle.jpg>
> <Main Gear.jpg>
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?KIS-List
Posted: Sat Jul 01, 2017 8:26 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
Galin
When I first started taxi tests, I had ‘severe’ lack of stopping power. Couldn’t taxi and steer the airplane. We ‘wore in’ the pads by pulling the plane and riding the brakes, and it became somewhat better but not good enough.
I eventually contacted Matco, when one of my rotors developed a crack, and they had a new owner, and had made some changes from the hardware supplied by KIS. They changed the rotor from a cast material to a machined tool steel. The cast iron has graphite inclusions, which don’t lead to great breaking. I think by your photo that you have the original, since the machined rotors have some surface grooves in them. Might want to talk to them.
THANKS!
pastormac62
Posted: Sun Jul 02, 2017 4:10 am Post subject: TR-4 Main Landing Gear Wheel Assembly |
Hi Bill,
My TR-1 seems to have the same lack of breaking power! I'm wondering if I have the original set on mine as well? I have surface groves in mine as well. What wheels or rotor does Matco recommend?
| Quote: | On July 2, 2017 at 12:26 AM Bill Schertz <wschertz343(at)gmail.com> wrote:
Galin
Subject: KIS-List: TR-4 Main Landing Gear Wheel Assembly
THANKS!
Posted: Sun Jul 02, 2017 5:49 am Post subject: TR-4 Main Landing Gear Wheel Assembly |
The replacement rotor was tool steel, and they had different pads too, I suggest calling them directly.
Sent: Sunday, July 02, 2017 6:10 AM
Hi Bill,
Galin
THANKS!
ftyoder(at)yoderbuilt.com Guest
Posted: Sun Jul 02, 2017 5:57 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
Stephen,
If you have the original kit supplied break peddles you don't get enough pressure at the calipers. The peddles need to be about 2" longer. Measure the hydraulic pressure at the calipers with your normal foot pressure, it will probably be 250-350 lbs. and it needs to be much higher. The low pressure generates allot of heat and poor breaking. Call Matco, they will tell you the pressure you need to see.
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of STEPHEN MCINTOSH
Sent: Sunday, July 02, 2017 5:10 AM
To: kis-list(at)matronics.com
Hi Bill,
Galin
THANKS!
mike(at)vision499.com Guest
Posted: Mon Jul 03, 2017 6:20 am Post subject: TR-4 Main Landing Gear Wheel Assembly |
Thanks Tim
How do you measure the pressure at the calipers
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Tim Yoder
Sent: Sunday, July 2, 2017 6:56 PM
Subject: RE: TR-4 Main Landing Gear Wheel Assembly
Stephen,
From: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com) [mailto:owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)] On Behalf Of STEPHEN MCINTOSH
Hi Bill,
My TR-1 seems to have the same lack of breaking power! I'm wondering if I have the original set on mine as well? I have surface groves in mine as well. What wheels or rotor does Matco recommend? | Quote: |
On July 2, 2017 at 12:26 AM Bill Schertz <wschertz343(at)gmail.com (wschertz343(at)gmail.com)> wrote:
Galin
THANKS!
Posted: Mon Jul 03, 2017 5:57 pm Post subject: TR-4 Main Landing Gear Wheel Assembly |
Disconnect a break line at a caliper and attach a high pressure gauge to the break line, it needs to read more than 2000 lbs. As I recall my stock peddles produced something like 250 lb. and after the mod I think I got 1800 lbs. Check with the owner of Matco and he will give you the correct value. He also has upgraded rotors and linings from the original ones.
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Mike Pienaar
Sent: Monday, July 03, 2017 7:20 AM
Thanks Tim
Stephen,
Hi Bill,
Galin
THANKS!
