New Cylinder heads temperature sensors and matching Tempera
Lcfittlcfitt3@gmail.com
PostPosted: Fri Jun 09, 2017 3:09 pm    Post subject: New Cylinder heads temperature sensors and matching Tempera Reply with quote
Hugh,The question was posted.  For me, though, I don't have an answer you could depend on.
Lowell
On Jun 9, 2017 6:21 PM, <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
I’m not sure the following question was received on the Matronics forum so I am sending it again. Hope some one can tell me what VDO coolant Temperature gauge is compatible with the sensors in the new Rotax 912 UL cylinder heads. I can be reached at hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
I have new the cylinder heads on my 912 UL. I need to know what VDO coolant temperature gauges are compatible (Temperature Range) with the new cylinder head temperature sensors. In other words will the output of the new 912 UL cylinder head sensor fall within the temperature range of the VDO Temperature gauge?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. [url=tel:(704)%20661-8271]704-661-8271[/url]
Fax [url=tel:(704)%20483-5466]704-483-5466[/url]
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
http://www.wwegeo.com
rickofudall
PostPosted: Sat Jun 10, 2017 4:23 pm    Post subject: New Cylinder heads temperature sensors and matching Tempera Reply with quote
Have you looked in the IPC to compare old part number to new?
Rick Girard
On Sat, Jun 10, 2017 at 6:54 PM, h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> RotaxEngines-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Hugh,
Compare the numbers on the new temp senders with those on your old ones.  The numbers will be stamped on the flats of the sender.
If they are the same, you are good to go.  If different, you need to get into the specifications.  You can find VDO information on the web.  Or post here and I can help.
What are you using to display temp?
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=469948#469948
xEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
“Blessed are the cracked, for they shall let in the light.”   Groucho Marx
