rv10free2fly(at)yahoo.com Guest
Posted: Fri May 26, 2017 6:19 pm Post subject: Control Surface Weights |
Hi team
I would like to know if the weights installed during the build on the elevators and rudder need to be adjusted?
I ask this question on the basis of, do I go ahead and install the tip fairings on this control surfaces using the pop rivets indicated, or do I for platenuts?
Your advice would be greatly appreciated please.
Warm regards
Patrick Pulis
Adelaide, South Australia
Bob Turner
Posted: Sat May 27, 2017 1:34 pm Post subject: Re: Control Surface Weights |
You should be good to close it up, if built to plans. If you are adding weight to the control surface (trim servo, more than normal paint, ...) you may want to hold off on closing it in. Balance info comes with the final kit, iiirc.
_________________ Bob Turner
RV-10 QB |
kearney
Posted: Wed May 31, 2017 6:48 am Post subject: Re: Control Surface Weights |
Patrick
FWIW, I used nutplates for all the f/g tips. That way you can remove for paint or repair in the case of hanger rash.
As sure as God made little green apples, when you make something difficult to remove, you will want to remove it.
Just saying...
Les
C-GCWZ Flying
C-GROK Some assembly required
Posted: Wed May 31, 2017 1:16 pm Post subject: Control Surface Weights |
Les
We are aligned in our thinking mate. Thank God for the Commonwealth!
Warm regards
Patrick
| Quote: | On 1 Jun 2017, at 00:18, kearney <kearney(at)shaw.ca> wrote:
Patrick
Just saying...
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=469749#469749
