john(at)johnkeen.com.au Guest
Posted: Sat May 13, 2017 11:20 pm Post subject: P-leads |
Hi Bob,
I have an engine with the Bendix dual magneto. It came without P-leads, so I’m wondering whether they are something I can fabricate or if I will need to purchase them complete?
Best regards,
John.
John Keen
0412 141 833
15 Scott St
Scone NSW Australia 2337
cbirdsall6(at)cox.net Guest
Posted: Sun May 14, 2017 5:30 pm Post subject: P-leads |
John,
You can build your own - but I'm not aware of anyone other than TCM (Continental owns the Bendix magneto line) that makes the individual parts. To get an idea what's involved, the Service Manual for your magneto will be here, listed by model number:
http://www.continentalmotors.aero/support/maintenance-manuals.aspx#ignition
The p-lead parts are called terminal kits in the manual. The how-to should be in section 9, the parts in section 11. Be sure to watch model number/part numbers and "usable on" codes to make sure you get the right part numbers.
Aircraft Spruce sells the terminal kits for about US$75 each. The kit consists of the nut, stepped bushing, insulator, and a washer.
Aside from a bit of soldering they aren't that difficult to assemble. Care must be taken to keep the overall length of the terminal within the parameters specified. Too long or too short and you may not get good contact.
OR -
Bogert makes pre-made p-leads for about US$80 each depending on length:
https://bogertaviation.com/collections/p-leads/products/p-leads-d-2000-d-3000-magneto
They're available thru Bogert direct or thru Spruce. Bendix p-leads come in two varieties (hex nut and round nut) and the round nut variety comes in two different lengths. Watch the video at the bottom of the Bogert web site. Make sure the version you order matches the model number of your magneto.
Chuck
---- John Keen <john(at)johnkeen.com.au> wrote:
| Quote: | Hi Bob,
Best regards,
John.
John Keen
0412 141 833
15 Scott St
Posted: Mon May 15, 2017 6:10 am Post subject: P-leads |
At 02:18 AM 5/14/2017, you wrote:
| Quote: | Hi Bob,
I have an engine with the Bendix dual magneto. It came without P-leads, so I’m wondering whether they are something I can fabricate or if I will need to purchase them complete? |
I have made these things. They're not hard to
duplicate but you do need a lathe and the
right taps for the cap threads. I may still
have a 3/8-32 tap around here somewhere.
I forget the thread size for the larger cap.
Didn't need to make that one so didn't
acquire the tap. The materials are not critical.
I cut the contact from brass rod, the cap from
aluminum rod and the insulator from delrin rod.
All that stuff was laying around and the tap was readily
available in Wichita so it wasn't a big time-buster
project.
I've lost the sketches I made for dimensions. You
would need to have access to manufactured parts
to acquire the dimensions. I'll have to check
with my buddy in K.C. to see if that part is
still flying on his Mooney.
Posted: Mon May 15, 2017 4:45 pm Post subject: P-leads |
Many thanks to everyone who's replied, fortunately I have access to the materials and original parts as patterns so I think I'll have a go at matching the terminal parts. Pretty sure we'll have a suitable tap here somewhere.
Cheers,
John.
John Keen0412 141 833
On 16 May 2017, at 00:08, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 02:18 AM 5/14/2017, you wrote:
| Quote: | Hi Bob,
project.
Posted: Mon May 15, 2017 6:30 pm Post subject: P-leads |
At 07:43 PM 5/15/2017, you wrote:
| Quote: | | Many thanks to everyone who's replied, fortunately I have access to the materials and original parts as patterns so I think I'll have a go at matching the terminal parts. Pretty sure we'll have a suitable tap here somewhere. |
Good show! Send us some pix of the
finished product!
I got my 3/8-32 off eBay as I recall,
I think I paid more for it than this
http://tinyurl.com/lwav9l3
I think I'm recalling that the larger
p-lead nut on the dual point
mag was 7/16-28
pmather
Posted: Tue May 16, 2017 3:25 am Post subject: P-leads |
John
I’m flying a TB10 while building. This has a O-360 with the Bendix dual mag. These things are a disaster for maintenance – hugely expensive and parts difficult/impossible to buy
Depending on the state of your build I would seriously look at changing the accessory housing and converting to a normal pair of Slicks. Better redundancy, cheap and easy to maintain and solid reliability.
Rgds
Peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Keen
Sent: 14 May 2017 08:19
Subject: P-leads
Hi Bob,
Best regards,
John.
John Keen
0412 141 833
15 Scott St
Posted: Tue May 16, 2017 6:05 am Post subject: P-leads |
At 06:24 AM 5/16/2017, you wrote:
| Quote: | John
I’m flying a TB10 while building. This has a O-360 with the Bendix dual mag. These things are a disaster for maintenance – hugely expensive and parts difficult/impossible to buy<
Rgds
Peter |
Another alternative would be E-Mags
http://tinyurl.com/n5vzcdp
Kellym
Posted: Tue May 16, 2017 12:23 pm Post subject: P-leads |
While you may have flown a plane with a dual mag, that is about
equivalent to a stay with Holiday Inn Express. If it was such a bad
device, why in the heck were you flying behind something depending on
it? Why isn't there an AD requiring removal?
Yes, there were some issues with the dual mag when it was first
introduced, both developmental and caused by mechanics unfamiliar with
its specific needs. That is way in the past. There are numerous magneto
shops that do quality overhauls of dual mags and know what is needed.
PMA parts suppliers make most of the needed replacement parts.
Properly installed and maintained, the dual mag is at least equal to the
Slicks you suggest, perhaps better in terms of reliability.
There are valid reasons to chose to change to individual mags, that have
little to do with maintenance or cost. Parts are available within normal
aircraft pricing. Slick mags may be cheaper than Bendix to purchase, but
they will cost you more in the long run, because after the first
overhaul, they are not economical to do subsequent overhauls. Reliable?
compared to what? Certainly not more reliable than the comparable Bendix
models. A vast majority of mechanics will choose Bendix over Slick any
day. Need less maintenance, need less parts replaced, and deliver a
hotter spark.
Before TCM Bendix dropped its support for the dual mag, Lycoming charged
typically $2500 to supply an engine with two single mags when the core
engine had a dual mag. To make the changes needed, he is probably
looking at similar or greater costs. Especially with shipping down
under. Meanwhile, it is likely that by the time his mag needs an
overhaul, there will be one or two electronic replacements available.
Kelly
A&P/IA
On 5/16/2017 4:24 AM, Peter Mather wrote:
| Quote: | John
Rgds
Peter
*From:*owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
*John Keen
*Sent:* 14 May 2017 08:19
*To:* aeroelectric-list(at)matronics.com
*Subject:* P-leads
Hi Bob,
Best regards,
John.
*John Keen*
0412 141 833
15 Scott St
KCHD |
pmather
Posted: Tue May 16, 2017 1:31 pm Post subject: P-leads |
" If it was such a bad device, why in the heck were you flying behind something depending on it?"
Try reading my post. I said it was "a disaster for maintenance" not that there was anything wrong with it as a functional unit or that it was unreliable.
"Before TCM Bendix dropped its support for the dual mag"
Exactly!
I've owned 8 aircraft with all varieties of mag. The last 500 hr overhaul on a pair of Slicks cost me £240 total (UK price). My dual mag needs a 6yr overhaul this year and will cost me c£2000.
By all means go for a pair of Bendix if you prefer them over Slicks but I stand by my advice to avoid the dual mags if long term budget is important to you
Kellym
Posted: Tue May 16, 2017 4:20 pm Post subject: P-leads |
Just because TCM dropped support for the mag does not mean it doesn't
exist. It also does not mean that in the USA cost is significantly
different than maintaining two separate mags. Disaster for maintenance
implies unexpected failures in my book. Examples done by quality mag
shops in the US are not prone to failure before 500 hours, and are not
out of sight on overhaul cost. Some engines they are used on, such as
the O-320-H2AD, there is no single mag model made, you cannot convert.
Seems you could do an exchange with a US magneto shop for a lot less
than what you are quoting. I'm not a fan of the dual head magneto, but
it isn't nearly as bad as you portray.
Your Slick overhaul, if the price is for both, you can't achieve that in
the US, and overhaul at 1000 hours will exceed the cost of new. In most
any turbo-charged application the Slicks won't make 500 hours. In the US
overhauling a Slick will cost as much or more than overhauling a Bendix.
Exactly!
KCHD |
