dosmythe(at)cox.net Guest
Posted: Thu Jul 13, 2006 5:23 am Post subject: Rotax 532 a Boat Anchor? |
Wayne,
I'm always interested in hearing reports about engine failures and was
wondering what caused your other two engine outs on the 582. I have a 582
in my Classic IV. The engine has approximately 360 hours with a "total"
rebuild around 300 hours. I had the engine rebuilt to try and fix a
totally unrelated problem (another story). At the 300 hour tear down, the
engine spec'd out to still be within all tolerances. In other words, it
didn't need a rebuild. The total rebuild was around $2400 (new crank,
pistons and all).
I've been on the list for about 10 years and always get interested in
the causes of engine out's or other flight safety issues. I used to
document all such items and posted a "KITFOXSAFE" bulletin. Once an item
was documented on the bulletin, we (the list) beat it to death until a
consensus for a field fix or recommendation was reached.
I'm sitting here and can't remember but only a couple cases where the
582 quit in the air. Two that I remember were one had a seizure due to the
absence of the sieve sleeve in the carb bowls and another guy that had a
pump pulse line rupture.
The only time I've had a problem was once due to excessive slow flight
(I think), and managed to foul the plugs. The engine started to sputter but
cleared up after a few minutes of normal cruise.
Don Smythe
kerryskyring(at)hotmail.c Guest
Posted: Thu Jul 13, 2006 10:28 am Post subject: Rotax 532 a Boat Anchor? |
This seems like a good subject line in which to contribute an experience
with the Rotax 912S in the S5 outback which I have helped build and
(hopefully) will soon be flying. Some may remember I reported earlier in the
year that the plane had done some taxying and short hops along the runway
and all was looking good for a summer of flying off the 40 hour test time.
It was not to be. After a number of runs the motor began running roughly. I
consulted the list and we did the obvious things. Carburettors removed,
cleaned, set to factory spec and remounted. Problem remained and time went
by. Eventually a compression check revealed one cylinder low. Removing the
rocker cap it was found that a valve spring retainer had broken and it was
likely that metal had gone into the cylinder. This was a new engine with
just 2.5 hours running time. That's the bad news. The good news is that
Rotax is replacing it with a brand new engine which will be picked up this
week. It helps that the factory is just a couple of hours down the west
autobahn.
But this is just an anecdote and does not constitute a judgement about
Rotax. The experience of our flying club with Rotax is generally good. But I
don't want to start another discussion about which is best, just to say we
had a problem and the factory has done the right thing. And to say that the
Vienna fox will one day fly and in the meantime I keep the frustrations at
bay with an occasional flight along the Danube in the Motorfalke.
Kerry
