BobbyPaulk(at)comcast.net Guest
Posted: Mon Apr 24, 2017 12:13 pm Post subject: Wing Atttach bolts |
Where has every one gone to for information??
I am doing my conditional on 601 XL B ( 2007 Model ) and found the right upper outboard wing attach bolt took 90 drgrees to tighten to 125 in./ lbs.
I have found one or two needed 45 to 60 deg. to meet the torque requirements several years before but this year only the one was needing re-torqued.
Has anyone experienced this??
Is there a more active list for maintenance information.
I would appreciate a heads up.
Thanks.
Bobby ( age 79 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 plus .002 Needle Jet
Status - Flying 274 hrs.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
psm(at)att.net Guest
Posted: Mon Apr 24, 2017 12:51 pm Post subject: Wing Atttach bolts |
I'm still here and have a similar model plane. I don't recall torquing the attach bolts. I just felt them and they were tight. Remember the only real load on those bolts is in shear on the bolt shaft rather than tension on the nuts.
I had difficulty drilling the holes for those bolts so I wound up using larger diameter bolts. My situation may be different from yours.Â
Perhaps you should put some medium (blue) loctite on those bolts to keep the nuts in place?
Paul
Camas, WA
N773PM finished phase I flight test.
On 4/24/2017 1:12 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
Thanks.
Bobby ( age 79 )
Zodiac 601 XL "B"
stephencliverichards(at)g Guest
Posted: Tue Apr 25, 2017 2:27 am Post subject: Wing Atttach bolts |
Bobby you should also look on www.zenith.aero site 601 forum
Clive
From: BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Sent: ‎24/‎04/‎2017 21:15
To: Zenith List (zenith601-list(at)matronics.com)
Subject: Wing Atttach bolts
Thanks.
Bobby ( age 79 )
Zodiac 601 XL "B"
