vernon.franklin(at)gmail. Guest
Posted: Sat Apr 22, 2017 5:56 pm Post subject: Prop Problems |
I started the engine for the first time today
Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle.
I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming.
I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking.
The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture.
[img]cid:ii_15b9881cd1bbd634[/img]
Anyone ever experience this?
Vernon Franklin
553.64 KB |
23045 Time(s) |
Tim Olson
Posted: Sat Apr 22, 2017 6:10 pm Post subject: Prop Problems |
I can't answer about the spacer. It should be easy enough to tell if the splines are meshing. But I can tell you it make take a short bit of running time before there's enough oil in the hub for the prop to cycle. You didn't mention how long you ran it for but maybe you just didn't wait long enough?
| Quote: | On Apr 22, 2017, at 8:55 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
<image.png>
Vernon Franklin
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Sat Apr 22, 2017 6:14 pm Post subject: Prop Problems |
Tim is correct, it takes several minutes of running for the oil to make its way up to the governor.
When I pulled my prop for IRAN last year, it took 3-4 minutes of run time to get enough oil back up there to move the blades.
grumpy
> <image.png>
> Vernon Franklin
Posted: Sat Apr 22, 2017 6:50 pm Post subject: Prop Problems |
It was probably between 3 and 5 minute. How long should it take?
Vernon
On Apr 22, 2017 9:13 PM, "Tim Olson" <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: | Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
> On Apr 22, 2017, at 8:55 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
> <image.png>
> Vernon Franklin
civengpe
Posted: Sat Apr 22, 2017 6:58 pm Post subject: Prop Problems |
Vernon,Have you considered having an a&p looking over you engine Install prior to first flight.?
On Apr 22, 2017 9:53 PM, "Vernon Franklin" <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote: | Quote: | It was probably between 3 and 5 minute. How long should it take?
Vernon
> <image.png>
> Vernon Franklin
Tim Olson
Posted: Sat Apr 22, 2017 7:08 pm Post subject: Prop Problems |
I'm not exactly sure but it would probably depend on the RPM also. If you weren't up to maybe 1800 rpm or so I don't know that you'd get enough pressure to get the oil flowing and make it work. I just know that when I did my IO-390 start last year it did take a bit of time.
On Apr 22, 2017, at 9:49 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
Vernon
On Apr 22, 2017 9:13 PM, "Tim Olson" <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: | Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)myrv10.com)>
> <image.png>
> Vernon Franklin
bhoppe2
Joined: 09 Apr 2015 Posts: 15 Location: Nolensville, TN
Posted: Sat Apr 22, 2017 7:21 pm Post subject: Prop Problems |
Vernon,
I had a similar problem with my Hartzell prop. I checked all the same items, talked to 2 A&P's, and finally called Hartzell. They immediately told me what was wrong.
At what speed were you running the engine when you tried to cycle the prop? I was used to doing a 1800 rpm run up and cycling the prop. That will not work. You need to be at least 2000 rpm.
Bruce Hoppe
<image.png>
Vernon Franklin
_________________ Bruce Hoppe |
Posted: Sat Apr 22, 2017 7:35 pm Post subject: Prop Problems |
Yup. Had two of them out there with me today. We were all stumped.
Vernon
On Apr 22, 2017 10:00 PM, "Shannon Hicks" <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote: | Quote: | Vernon,Have you considered having an a&p looking over you engine Install prior to first flight.?
Vernon
> <image.png>
> Vernon Franklin
Bob Turner
Posted: Sat Apr 22, 2017 8:22 pm Post subject: Re: Prop Problems |
Agree with others. You need to be at over 1700 rpm, prop control pulled back, for up to 45 seconds or so, to get enough oil in there.
_________________ Bob Turner
RV-10 QB |
Posted: Sun Apr 23, 2017 3:53 am Post subject: Prop Problems |
This is a common question I hear. Get it to at least 1800rpm, 2000 is better, then pull the prop control and leave it out. It can take 30-60 seconds to get a reaction in the prop the first time.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
| Quote: | On Apr 22, 2017, at 9:55 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
<image.png>
Vernon Franklin
bhoppe2
Posted: Sun Apr 23, 2017 4:59 am Post subject: Prop Problems |
As I mentioned last night, the governor supplied by Vans with the Hartzell prop needs at least 2000 rpm to control the prop. That is what Hartzell told me and is absolutely true. 1700 rpm does not work, 1800 rpm will not work. You must be over 2000 rpm, which seems high, but your prop will cycle.
Bruce Hoppe
| Quote: | On Apr 23, 2017, at 6:52 AM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> <image.png>
> Vernon Franklin
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sun Apr 23, 2017 7:16 am Post subject: Re: Prop Problems |
One more thing to check.
Have two of you try to change the pitch with your hands manually. This is easily accomplished with two people. Make sure the prop moves full range to the stops. If you can't move it or it is really hard there might be hydraulic lock in the prop due to a bad seal during construction. This happened to me. Usually it's something simple but make sure. In my case it was a prop overhaul and the oring was nicked. The prop cycled at first and then slowly went to a fixed pitch prop in flight. It was bad because it wanted to over rev the engine and I had to limp back to the airport. Luckily, I was close and didn't have to add more power. Just a thought. Usually it is something more simple but an easy check with two people.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rvdave
Posted: Sun Apr 23, 2017 8:53 am Post subject: Re: Prop Problems |
I may be wrong but you said you pulled a plug from the crankshaft, did you mean it had been set up for fp prop before?
_________________ Dave Ford
Cadillac, MI |
Tim Olson
Posted: Sun Apr 23, 2017 9:07 am Post subject: Prop Problems |
If it's a new engine, it will just come that way.
| Quote: | On Apr 23, 2017, at 11:53 AM, rvdave <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=468701#468701
rvdave
Posted: Sun Apr 23, 2017 11:02 am Post subject: Re: Prop Problems |
| Quote: | If it's a new engine, it will just come that way.
Do you mean set up for fp or with a plug in the end?
Cadillac, MI |
Bob Turner
Posted: Sun Apr 23, 2017 2:18 pm Post subject: Re: Prop Problems |
| rvdave wrote: | | Quote: | If it's a new engine, it will just come that way.
Do you mean set up for fp or with a plug in the end? |
Mine was all set up for CS except that there was a plug an inch or so from the forward end of the crankshaft. There are various ways to pull it.
RV-10 QB |
rvdave
Posted: Sun Apr 23, 2017 3:53 pm Post subject: Prop Problems |
Thanks everyone for the suggestions. All of you were correct, it came down to RPM. Alex DeDominicis dropped by earlier as I was outside trying to get things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceeded to jump in and pushed the throttle up beyond were I had gone yet. At around 3800 RPM... The prop finally engaged. After nearly having a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is doubling the RPM for some reason, need to do some more research.
Prop problem solved, on to the next one!
Thanks for the input, you guys nailed it.
Vernon
On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
| Quote: | I started the engine for the first time today
Vernon Franklin
Vernon Franklin
553.64 KB |
22976 Time(s) |
Posted: Sun Apr 23, 2017 4:47 pm Post subject: Prop Problems |
If you go into settings, then to calibration (bottom option on the main settings list), then to EMS Calibration, then to RPM, change the pulses per revolution. Depending on your ignition system, there will be different pulses per revolution. If it's reading double, then double your pulses per revolution and that should fix it. Easy peasy.
Jesse Saint
352-427-0285
On Apr 23, 2017, at 7:52 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
| Quote: | Thanks everyone for the suggestions. All of you were correct, it came down to RPM. Alex DeDominicis dropped by earlier as I was outside trying to get things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceeded to jump in and pushed the throttle up beyond were I had gone yet. At around 3800 RPM... The prop finally engaged. After nearly having a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is doubling the RPM for some reason, need to do some more research.
Vernon
Vernon Franklin
Vernon Franklin
553.64 KB |
22973 Time(s) |
john(at)trollingers.com Guest
Posted: Sun Apr 23, 2017 4:55 pm Post subject: Prop Problems |
How are you getting RPM, a sensor on the mag?
On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
Vernon
Vernon Franklin
Vernon Franklin
553.64 KB |
22973 Time(s) |
