Baby's got some new shoes
lcottrell
PostPosted: Sat Apr 15, 2017 3:48 pm    Post subject: Baby's got some new shoes Reply with quote
I finally got my new rims from Matco. They had been on back order for
almost a month, at least it seems that way. I had already ordered the
8.50 X 6 tundra tires and tubes.
Today dawned cold, 22 degrees but calm for a change. It eventually
warmed up to 44 degrees and I went to the hanger to start my tire
mounting. I drilled 6 holes in the rims to screw the tires to the
rims. The tires fit tight enough that it takes about 20 lbs of air to
make them pop out on the rims. That is unlike the Azusa rims that
depend on small flanges on the inside of the rims to keep them from
spinning. Since I want to run 5 lbs or less I am still not going to
take a chance on shearing off the valve stem, thus 6 screws per side.
Before I changed from the 8.00 X6 tires, I rolled the plane out and
flew all four corners of the compass with a vid camera to monitor my
airspeed. The speed averaged out to be about 66 MPH indicated. The
same on the ground speed depending on with or against the wind. There
was little wind, and my ASI and Ground speed are really close under
those conditions.
I drilled and cut threads in the rims, and then mounted the tires.
Since the 8.00 x 6 tires are on Matco rims as well, I just changed the
three bolts that held the bearings in the other tires and changed them
to the new tundras.
The wind was still holding its breath, so I rolled the plane back out
to check the difference. It seems to roll better with the tundra's on
it. I taxiied to the other end of the runway, and began my take off. I
cannot be sure, but the tires with 5 lbs of air, seemed to bounce a
bit on take off, but I could not be sure. When I pulled back on the
stick it flew quickly. I tend to push the stick forward to pick up
speed, so it could have been trying to fly, while I was pushing it
back on the ground. I will be doing a lot more testing when the
weather again cooperates. My take off seemed to be quite a bit shorter
than normal.
In essence there was no indication that my air speed suffered at all.
It was quite turbulent so I only made a circuit and half. While I
seemed to bounce a bit on take off, I bounced not at all on landing.
The tires at 5 lbs are really nice. They appear to not need balancing,
unlike the 8.00X6's.
Larry
The older I get, the less tolerant I am of those who are intolerant of others.
If you forward this email, or any part of it, please remove my email
address before sending.
 Filesize:  743.33 KB
 Viewed:  8836 Time(s)
 Filesize:  742.42 KB
 Filesize:  219.81 KB
 Filesize:  172.47 KB
stuart(at)harnerfarm.net
PostPosted: Sat Apr 15, 2017 4:52 pm    Post subject: Baby's got some new shoes Reply with quote
Larry,
Are you using tubes in these tires? If so, how do you keep the screws from puncturing the tubes?
Just curious as I am happy with my Black Max brakes, tubeless tires and aluminum wheels on my Firefly. Apples and oranges, I know....
Stuart
lcottrell
PostPosted: Sat Apr 15, 2017 5:19 pm    Post subject: Baby's got some new shoes Reply with quote
You wrote: Are you using tubes in these tires? If so, how do you
Yes these are tube type tires. The screws don't go all the way through
the inside rim of the tire. The screws are 3/4, so I put a washer on
them and they are just right for length that way.
Larry
PostPosted: Sun Apr 16, 2017 3:27 pm    Post subject: Baby's got some new shoes Reply with quote
Sounds good.
Reckon sitting more nose high helped with your takeoff?
lcottrell
PostPosted: Sun Apr 16, 2017 3:53 pm    Post subject: Baby's got some new shoes Reply with quote
On Sun, Apr 16, 2017 at 5:27 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
Sounds good.
I think that it did, seems a lot shorter. I just went back and looked
at the video and as near as I can tell I lifted off at 34 MPH
indicated. Stall is 29-30 . With the taller tires it is sitting at the
angle that it is when it actually stalls, so it would appear to be at
optimum attitude.
I am experiencing some bouncing at the same time that it wants to fly.
Not sure if it is dribbling or, starting to bounce. Need more take
off's to tell. Actually an observer would be just the thing.
Larry
russk50(at)gmail.com
PostPosted: Sun Apr 16, 2017 4:00 pm    Post subject: Baby's got some new shoes Reply with quote
Hey, Larry, you got an interesting problem. I’d be gad to observe & photograph your TO’s
Just pay my travel from Maine!
Fair winds,
Russ K
On Apr 16, 2017, at 7:53 PM, Larry Cottrell <lcottrell1020(at)gmail.com> wrote:
> Sounds good.
optimum attitude.
Larry
lcottrell
PostPosted: Sun Apr 16, 2017 4:15 pm    Post subject: Baby's got some new shoes Reply with quote
Fair winds,
Russ K
Sounds good, but after buying all those rims, tires and tubes, my
slush fund is a bit under the weather. However if you toss your stuff
in your plane and start out now, you could be here in a week or two.
Larry
PostPosted: Sun Apr 16, 2017 4:25 pm    Post subject: Baby's got some new shoes Reply with quote
Would love to fly out to you but I’m plane-less at the mo.Have made 6 coast-coast trips in Cessnas, GREAT fun &
would love to do another.
I’ll work on the Lotto
Good luck,
Russ
On Apr 16, 2017, at 8:15 PM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
--> Kolb-List message posted by: Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)>you wrote: --> Kolb-List message posted by: Russ Kinne <russk50(at)gmail.com (russk50(at)gmail.com)>Hey, Larry, you got an interesting problem. I’d be gad to observe &photograph your TO’sJust pay my travel from Maine!Fair winds,Russ KSounds good, but after buying all those rims, tires and tubes, myslush fund is a bit under the weather. However if you toss your stuffin your plane and start out now, you could be here in a week or two.Larryhttp://www.matronics.com/Navigator?Kolb-Listhttp://wiki.matronics.com
PostPosted: Sun Apr 16, 2017 4:50 pm    Post subject: Baby's got some new shoes Reply with quote
Maybe you are trying to make the airplane fly too soon. Keep the nose down until you get well stall, then pull the nose up.
It gets light, but not light enough to fly. 5 psi in big tires have a lot of reflex.
Just the thoughts of a guy that has never flown anything bigger than an 8x6, which seemed huge for a short time after upsizing from 6x6. Now they are just regular tires.
PostPosted: Sun Apr 16, 2017 5:10 pm    Post subject: Baby's got some new shoes Reply with quote
I'm tired and can't type.
I meant to say "keep the nose down until you get well "above" stall."
lcottrell
PostPosted: Sun Apr 16, 2017 5:19 pm    Post subject: Baby's got some new shoes Reply with quote
-> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
Actually it was the "bouncing" that prompted me to pull it up.
Something similar happened on the first take off, so I was prepared
for it. Just don't know what causes it. I am wondering if a bit more
air might clear it up. The first time I can fly, I will set another
camera up to film the take off as it happens from in front. It is
nothing more than a curious occurrence.
Larry
victorbravo(at)sbcglobal.
PostPosted: Sun Apr 16, 2017 11:18 pm    Post subject: Baby's got some new shoes Reply with quote
Wow ! Now I'm suffering from "Tire Envy" ! The airplane looks mighty serious with those tires.
Bill Berle
On Sun, 4/16/17, Larry Cottrell <lcottrell1020(at)gmail.com> wrote:
Subject: Re: Baby's got some new shoes
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Sunday, April 16, 2017, 6:15 PM
pull the nose up.
occurrence.
Larry
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
