Red Crimp On Terminal Ring For 5/16 Stud
billhuntersemail(at)gmail
PostPosted: Sun Apr 16, 2017 7:59 am    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Hi and Happy Easter!!!
I am struggling to find a crimp on terminal ring that will work with 20 AWG wire and a 5/16 stud. The Google keeps showing results for 8 AWG wire.
Does anyone have a part number to share?
Bill Hunter
trigo(at)mail.telepac.pt
PostPosted: Sun Apr 16, 2017 8:20 am    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Bilk
That will be SA-044 from SteinAir
Carlos
Enviado do meu iPhone
No dia 16/04/2017, às 16:56, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> escreveu:
Bill Hunter
PostPosted: Sun Apr 16, 2017 8:47 am    Post subject: Re: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Sta-Kon RA18-516
Joe Gores
PostPosted: Sun Apr 16, 2017 9:21 am    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Joe,
I knew I could count on you!!!
I guess I figured out why I could not find them on The Google...all of the
results I found were for around 85 bucks because they only sell them in 100
pc boxes!!!
Cheers!!!
Bill Hunter
PostPosted: Sun Apr 16, 2017 9:36 am    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Amazon Aircraft Supply had a different manufacturer for only 15 bucks!!!
https://www.amazon.com/Terminal-Connectors-Plus-Parts-House/dp/B00N9RYQDI/re
f=sr_1_fkmr0_1?ie=UTF8&qid=1492363881&sr=8-1-fkmr0&keywords=22-16+AWG+5%2F16
%22+Stud+Nylon+Insulated+Double+Crimp+Ring+Terminal
Cheers!!!
Bill Hunter
ceengland7(at)gmail.com
PostPosted: Sun Apr 16, 2017 11:50 am    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Bill,
Just a data point, but that link is for a product with a vinyl
insulator, and it's unlikely to be configured as PIDG (where the crimp
grabs both the wire and a small portion of the insulation). I'm not
saying that it's a deal breaker; I've used a few of those in my build &
I'm not afraid the plane will fall out of the sky because of them. Just
wanted to note that you're not comparing apples to apples. (The 'real'
PIDG terminals are grossly overpriced, in my not so humble opinion. An
order of magnitude price increase to go from vinyl to nylon and a
slightly longer metal barrel is a real stretch.)
A tip for finding products when a google search doesn't instantly find
what you want: If you look on ebay & find something that's similar from
one of the web stores that list there, try clicking on the store's
direct link, then search within that store. You can often find what
you're looking for that way. Bigger ebay sellers rarely list every
product they sell as a separate listing on ebay, but you can still
purchase through ebay by looking within the store's listings.
Cheers!!!
Bill Hunter
donvansanten(at)gmail.com
PostPosted: Sun Apr 16, 2017 12:22 pm    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
I would recommend using only AMP or TE PIDG terminals. They are available from Steinair, Allied Electronics, Mouser and digikey for as little as 37 cents each in lots of 1.
Just my opinion, the junk stuff does not provide insulation support or good material so they tend to fail fairly quickly.
On Apr 16, 2017 12:56, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:[quote]--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
Bill,
Just a data point, but that link is for a product with a vinyl insulator, and it's unlikely to be configured as PIDG (where the crimp grabs both the wire and a small portion of the insulation). I'm not saying that it's a deal breaker; I've used a few of those in my build & I'm not afraid the plane will fall out of the sky because of them. Just wanted to note that you're not comparing apples to apples. (The 'real' PIDG terminals are grossly overpriced, in my not so humble opinion. An order of magnitude price increase to go from vinyl to nylon and a slightly longer metal barrel is a real stretch.)
A tip for finding products when a google search doesn't instantly find what you want: If you look on ebay & find something that's similar from one of the web stores that list there, try clicking on the store's direct link, then search within that store. You can often find what you're looking for that way. Bigger ebay sellers rarely list every product they sell as a separate listing on ebay, but you can still purchase through ebay by looking within the store's listings.
[quote] --> AeroElectric-List message posted by: "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)>
Cheers!!!
Bill  Hunter
PostPosted: Sun Apr 16, 2017 12:44 pm    Post subject: Red Crimp On Terminal Ring For 5/16 Stud Reply with quote
Good information…THANKS!!!
Cheers!!!
Bill  Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of don van santen
Sent: Sunday, April 16, 2017 1:20 PM
Subject: Re: Re: Red Crimp On Terminal Ring For 5/16 Stud
Bill,
On 4/16/2017 12:33 PM, William Hunter wrote:[quote]
Cheers!!!
Bill Hunter
