F-10108A Support Bracket Fracture
Kelly McMullen
PostPosted: Sat Apr 15, 2017 5:15 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall.  I'm thinking about using some angle aluminum to replace that bend, at least for now.  I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part.  Just wondering if anyone else has had a failure there
Kelly-sent from the I-droid implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
jesse(at)saintaviation.co
PostPosted: Sat Apr 15, 2017 5:38 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
This is very common and your proposed fix is exactly what I do.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Kelly
Tim Olson
PostPosted: Sat Apr 15, 2017 5:48 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
I used screws and plates and mine has never fractured that part. Frankly I surprised of that. Just a data point.
Kelly
philperry9
PostPosted: Sat Apr 15, 2017 6:17 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
I've noticed that mine will fold up under the cowling if I'm not careful when sliding the lower cowl on. Then it takes some effort to get into out of a bind and into the right position.
It's certainly a bracket prone to eventually failing on my plane at least. If I'm careful it will be fine, but it's hard to be careful when you're wrestling that lower cowling around 3 blades and a nose gear. Practice makes closer to perfect anyway.
Phil
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> Kelly
partner14
PostPosted: Sat Apr 15, 2017 6:55 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
Never even installed it on my 10. Looked like the weak link to me. So I made my own. A little wider at the small bend end, and slightly heavier gauge.
Don McDonald
Sent: Saturday, April 15, 2017 9:29 AM
Subject: Re: F-10108A Support Bracket Fracture
--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
Phil
On Apr 15, 2017, at 8:36 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> On Apr 15, 2017, at 9:15 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
> Kelly
" target="_blank">http://www.matronics.com/Navigator?RV10-List
http://forums.matronics.com
<= Add some info to the Matronics Email List Wiki!
Don A. McDonald
40636
carl.froehlich(at)verizon
PostPosted: Sat Apr 15, 2017 7:36 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
+1.
And slightly modified for the James Cowl.
Carl
On Apr 15, 2017, at 10:45 AM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
Don McDonald
From: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
Phil
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> Kelly
Lenny Iszak
PostPosted: Sat Apr 15, 2017 7:58 am    Post subject: Re: F-10108A Support Bracket Fracture Reply with quote
I had to make a new one, because my James cowl has a slightly taller exit area. Used a bit thicker aluminum and angles on both top and bottom. Much sturdier and so far no signs of issues in 280 hours. Here's a picture.
I also have camlocks on the bottom of the cowl, the floating ones too.
Lenny
 Filesize:  76.56 KB
 Viewed:  9587 Time(s)
Mauledriver(at)nc.rr.com
PostPosted: Sat Apr 15, 2017 10:33 am    Post subject: F-10108A Support Bracket Fracture Reply with quote
I copied Tim's solution during the build. No problems at 900hrs other
than a smoking rivet.
> Kelly
rvdave
PostPosted: Sun Apr 16, 2017 5:49 am    Post subject: Re: F-10108A Support Bracket Fracture Reply with quote
What are the two lines adelled to the bracket?
Dave Ford
Cadillac, MI
Lenny Iszak
PostPosted: Sun Apr 16, 2017 6:13 am    Post subject: Re: F-10108A Support Bracket Fracture Reply with quote
Fuel pump overflow and FAB drain line.
