motodd(at)frontier.com Guest
Posted: Mon Apr 03, 2017 9:35 pm Post subject: old B and C SD-8 Dynamo failure |
Well, after 27 years and 2300+ hours, my good old SD-8 dynamo finally
gave me a problem. It was installed in my day/VFR RV4 in 1989 as the
only charging source. It could produce up to 8.6 amps at high RPM and
met my modest electrical load requirements (<4 amps in cruise) for all
these years. Of course, I could expect my low voltage light to come on
(at 12.5V) at low rpms depending on the loads. I didn't mind. It made
for a nice reminder to turn off my boost pump as I exited the runway on
landing.
On a recent flight, I noticed that the low voltage light came on a
little earlier than I expected on landing. At high RPM, the voltage
was only going to 13.9 instead of the usual 14.1V. A quick run through
my switchable loads showed they were pulling their expected currents.
I have a switchable volt/amp gauge on my panel so I can look at one or
the other but not both simultaneously. The amp readings are taken off
my B lead and it takes several seconds for the amp reading to stabilize
on my gauge after it's selected. I never saw an unexpectedly high amp
reading on the gauge. Back at the hangar, a brief look at my B lead
connections didn't reveal any problems. On the next flight, the low
voltage light came on even sooner and the voltage only got to 13.7V.
A more detailed inspection was made of the wiring, including
micro-ohming some connections (using Bob's 100mA current clamp
micro-ohmmeter design I've enjoyed using for several years). I thought
I detected a little bit of a burnt electrical smell near the dynamo
housing where the armature leads pass through a clip screwed into the
rim of the housing. Using a cheap digital multimeter, I checked the
resistance across the disconnected dynamo leads and got 5.6 ohms. Not
sure what it's suppose to be.
I flew the plane again and this time, I got a low voltage light in
cruise and zero B lead amps when checked. I checked the resistance
across the dynamo leads again with the same meter.. and got a reading of
zero. My micro-ohm meter said it was about 700 milliohms. I bought a
new SD-8 and am back in the air trouble free. Since removing the
problem unit, I removed the clip that held the leads at the rim of the
dynamo housing and slid the protective sheathing back. The lead wires
look fine, including the half-inch of wire I can see inside the
housing. The resistance across the leads remains 'zero' when checked
with another cheap digital mulitmeter.
I concluded that I had probably experienced a progressive short within
the dynamo, probably in the windings themselves. This dynamo was from
the 1980's and the exterior design has changed a lot since then. This
includes a protected routing of the leads out of the dynamo housing with
a better clamping system. The insides have probably changed as well.
Lord knows the new unit is easier to install with much better access to
the mounting nuts.
I have no complaints about this SD-8 failure. I certainly got a
reasonable service life out of this unit. I just thought I'd share my
story as just one more data point, although I appreciate it's kinda
ancient history. I'm planning on taking the dynamo apart (curiosity)
and maybe salvaging the magnets.
Bob, if you wanted to look at this dynamo for some reason, I'll be happy
to mail it to you. I suspect you've got much better things to do than
'paleo-forensics' on this dated item.
Mark
Posted: Tue Apr 04, 2017 3:04 am Post subject: Re: old B and C SD-8 Dynamo failure |
The saying, "Ring it out", when referring to electrical testing, got its beginnings when troubleshooters used a doorbell for testing electrical motors. There is not much difference in resistance between a good motor and one with a shorted winding. But there is a difference in the inductance. An experienced electrician could tell the difference in doorbell sound when connected in series with a shorted motor winding compared to a good winding. Modern doorbells are not suitable for this task. The doorbell must be of the old fashioned clanger and bell type.
This information might be of use to you 27 years from now when your new SD-8 dynamo malfunctions.
_________________ Joe Gores |
Posted: Tue Apr 04, 2017 3:50 am Post subject: old B and C SD-8 Dynamo failure |
and maybe salvaging the magnets. |
Are the windings smoked? Do they smell bad?
The DC resistance of this product is less than
0.25 ohms. So if you had a shorted turn or two,
you could not resolve it with jelly-bean test
equipment. The magnets are ferrites . . . rather
brittle. You probably couldn't get them loose
without breaking them up.
| Quote: | Bob, if you wanted to look at this dynamo for some reason, I'll be happy
Mark |
Actually, I would like to see it. I have
a drive stand running that fits the SD8
and I'm equipped to test/inspect it in
detail. Getting a close up look at a sample
with this kind of service on it would be
illuminating.
Send the rectifier/regulator too. I'll
get them checked out and repaired/replaced
as needed.
ashleysc(at)broadstripe.n Guest
Posted: Tue Apr 04, 2017 6:43 am Post subject: old B and C SD-8 Dynamo failure |
Hi Mark;
Hi All;
I read this as an endorsement, not a complaint. Who gets 27 years of operation from a car, washing machine, or computer? It gives me great confidence in B & C products.
Cheers! Stu.
Posted: Wed Apr 05, 2017 4:08 pm Post subject: old B and C SD-8 Dynamo failure |
| Quote: | Are the windings smoked? Do they smell bad?
I thought there was a burnt smell from the dynamo before I pulled it off
the engine. Here at my bench, is smells fine. Now I wonder if that
burnt smell was from something else in that 2300+ hour engine compartment.
OK.
> Mark
illuminating.
as needed.
I'll get the dynamo and regulator off to you within the next couple of
days, using your PO Box 130 address unless you instruct otherwise.
Thanks for looking at this. If it checks out OK, I guess it'll mean
that I missed a faulty connection somewhere that got cleared up with the
replacement. After all these years of flawless service, I can't decide
whether I'm rooting for the dynamo or me!
Mark
Posted: Thu Apr 06, 2017 6:02 am Post subject: old B and C SD-8 Dynamo failure |
whether I'm rooting for the dynamo or me! |
Thank YOU for making it available. It's a rare
treat to get field returns on mature designs
for evaluation. Products I designed at Electro-Mech
were routinely serviced in house as E-M was the only
FAA qualified overhaul and repair shop for those
products . . . I was able to visit my former
colleagues at E-M and look through the R/R
records.
In the OBAM aviation world it's more difficult
to access such data.
Posted: Wed Apr 12, 2017 3:20 pm Post subject: old B and C SD-8 Dynamo failure |
| Quote: | | Quote: | Bob, if you wanted to look at this dynamo for some reason, I'll be happy
Mark |
illuminating.
as needed. |
Got Mark's SD8 and R/R from the post office
today. Ran the SD8. As I would have predicted,
it runs just fine.
The construction of these machines doesn't have
much of a wear-out mode. The bearings
are VERY lightly loaded. There are no brushes
or slip rings. The stationary windings might
be a some risk for aging were they operated
at temperatures that pushed the insulation
limits on the magnet wire.
The numbers on Mr. Todd's SD8 track very
closely with those from a new, current protection
unit.
I've got some wiring details to fiddle with
before I can add the R/R to the bench setup . . .
perhaps tomorrow.
Watch this space . . .
Posted: Mon Apr 17, 2017 10:31 am Post subject: old B and C SD-8 Dynamo failure |
Got Mark's SD-8 and original stock R/R running
on the bench. The R/R seems to be fine too. I
initially used a LiFePO4 battery (ETX36) in the
test setup and observed some unexpected behaviors.
Got a small lead-acid from the store a few minutes
ago and put it on a maintainer. Will resume the
experiment when the battery tops off . . .
Posted: Mon Apr 17, 2017 2:37 pm Post subject: old B and C SD-8 Dynamo failure |
'paleo-forensics' on this dated item. |
I've finished some preliminary operations on the
as received SD8 and companion R/R. They seem to
function pretty much as designed.
2800 RPM produces 3+ amps at 14.4v
3300 RPM produces 4+ amps at 14.3v
3800 RPM produces 8+ amps at 14.1v
At the final load setting, current
in the SD8 windings was 10.5 A(rms)
I can return this hardware if you'd like to
have it around for spares. At the same time,
it would be interesting/useful to add it to
the constellation of test tools I'm
building around a 2HP drive-stand with
and AND20000 spline pad on it.
[img]cid:.0[/img]
As an interesting aside, test data were taken
without a battery on line . . . this prevented
pollution of current values dialed into the dynamic
load bank. I was able to 'tickle' the dynamo-r/r
into operation with a momentary application of battery
power. On one fire-up/shut-down cycle, the capacitor
was still charged to about 3 volts and the system came
on-line with only a small fraction of start up
excitation offered by the ship's battery.
353.51 KB |
8583 Time(s) |
Posted: Tue Apr 18, 2017 12:40 pm Post subject: old B and C SD-8 Dynamo failure |
Bob, I'm happy to contribute them to the cause. BTW, I never had a big
cap or OVP module until I installed the new dynamo and regulator.
After just a couple of flights with the replacement hardware, I've had
no indication of a return of the problem. To be at ease, I'll just have
to go fly some more!
Mark
